Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 61.39 fps, 7754.11 kb/s encoded 11812 frames, 61.30 fps, 7754.10 kb/s encoded 11812 frames, 61.51 fps, 7754.10 kb/s encoded 11812 frames, 61.36 fps, 7754.11 kb/s Pass 2 ------ encoded 11812 frames, 16.26 fps, 8002.28 kb/s encoded 11812 frames, 16.34 fps, 8002.26 kb/s encoded 11812 frames, 16.34 fps, 8002.11 kb/s encoded 11812 frames, 16.26 fps, 8002.24 kb/s System Details -------------- Name AMD FX-8120 Codename Zambezi Specification AMD FX(tm)-8120 Eight-Core Processor Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping OR-B2 Technology 32 nm Stock frequency 3700 MHz Core Speed 4640.7 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB950 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Memory Frequency 836.2 MHz (3:10) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows Server 2008 R2 Enterprise Edition (Full) 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 52°C (125°F) [0x34] (CPU) Temperature 1 38°C (100°F) [0x26] (Mainboard)
All you guys seem to have pretty good results.... kind of jealous. I gave it the what the heck and let my pc run for 10 hours or so to do this benchmark. Even exited and shutoff my antivirus and stuff. Meh.... You guys with your i5 and i7s taunting me. Pass 1 ------ encoded 5906 frames, 4.50 fps, 7772.80 kb/s encoded 5906 frames, 5.65 fps, 7772.80 kb/s encoded 5906 frames, 5.58 fps, 7772.80 kb/s encoded 5906 frames, 8.59 fps, 7772.80 kb/s Pass 2 ------ encoded 5906 frames, 0.74 fps, 8005.80 kb/s encoded 5906 frames, 0.86 fps, 8005.80 kb/s encoded 5906 frames, 0.76 fps, 8005.80 kb/s encoded 5906 frames, 0.78 fps, 8005.80 kb/s System Details -------------- Name AMD Turion 64 X2 Mobile TL-56 Codename Trinidad Specification AMD Turion(tm) 64 X2 Mobile Technology TL-56 Core Stepping BH-F2 Specification AMD Turion(tm) 64 X2 Mobile Technology TL-56 Technology 90 nm Stock frequency 1800 MHz Core Speed 798.9 MHz Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 159.8 MHz (CPU/5) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows Vista (6.0) Home Premium Edition 32-bit Service Pack 2 (Build 6002) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket S1 (638)
does not equal the test DGDecode32.dll = v.1.5.0.0 DGDecode64.dll = v.1.5.8.0 download from 05-Jan-2011: http://megui.org/auto/dgmpgdec158_mod_b05.7z http://megui.org/auto/dgmpgdec158_x64.7z
All the x64 results posted so far are arguably invalid, since DGDecode64 is doubling the number of frames, with every other frame being green and corrupt. That's why all the x64 results posted so far have 11812 frames, when the actual AVS should only produce 5906 frames like the x86 results.
Sorry for the late reply, just got back from an outstation trip. Thanks for notifying us. We will look into this ASAP.
the problem with the file test-1080p.mpg. presumably dgdecode64 not working correctly with video files encoded in MPEG1.
Hmm.. Not dgdecode64 itself? Sorry, I've been busy with other work. Haven't had the time to play around and pinpoint the problem yet...
i7 3770k Turbo Boost ON (3920Mhz) Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 72.17 fps, 7754.07 kb/s encoded 11812 frames, 72.71 fps, 7754.00 kb/s encoded 11812 frames, 72.73 fps, 7754.08 kb/s encoded 11812 frames, 72.70 fps, 7754.17 kb/s Pass 2 ------ encoded 11812 frames, 15.30 fps, 8002.16 kb/s encoded 11812 frames, 15.32 fps, 8002.24 kb/s encoded 11812 frames, 15.32 fps, 8002.23 kb/s encoded 11812 frames, 15.33 fps, 8002.24 kb/s System Details -------------- Name Intel Core i7 3770K product System Product Name Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping E1 Technology 22 nm Stock frequency 3500 MHz Core Speed 3920.5 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 804.3 MHz (1:6) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1)
i7 3770K @ 4.4GHz Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 80.68 fps, 7753.94 kb/s encoded 11812 frames, 80.65 fps, 7754.26 kb/s encoded 11812 frames, 80.81 fps, 7754.40 kb/s encoded 11812 frames, 80.57 fps, 7754.30 kb/s Pass 2 ------ encoded 11812 frames, 17.13 fps, 8002.17 kb/s encoded 11812 frames, 17.15 fps, 8002.18 kb/s encoded 11812 frames, 17.22 fps, 8002.07 kb/s encoded 11812 frames, 17.17 fps, 8002.17 kb/s System Details -------------- Name Intel Core i7 3770K product System Product Name Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping E1 Technology 22 nm Stock frequency 3500 MHz Core Speed 4400.1 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1)
Well i just bought a new laptop. I still have my Pc that got bench marked on the previous page. It sucks, now my new one kicks its butt! BTW that second pass is insane, thats what takes up practically all the time. Took my old pc 10-ish hours, took my new one an hour and a half-ish. I should also add that i really dont know if i have turbo core enabled in this DV6 or not. I cant find anything in the BIOS. Also.... Temp 0, Running too hot? what does temp 0 tell you the temp of? ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 51.26 fps, 7754.16 kb/s encoded 11812 frames, 52.12 fps, 7753.75 kb/s encoded 11812 frames, 51.59 fps, 7753.88 kb/s encoded 11812 frames, 52.13 fps, 7754.17 kb/s Pass 2 ------ encoded 11812 frames, 10.78 fps, 8002.27 kb/s encoded 11812 frames, 10.85 fps, 8002.43 kb/s encoded 11812 frames, 10.83 fps, 8002.30 kb/s encoded 11812 frames, 10.86 fps, 8002.24 kb/s System Details -------------- Name Intel Core i7 Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3612QM CPU @ 2.10GHz Core Stepping E1 Technology 22 nm Manufacturer (ID) Micron Technology (2C00000000000000) Manufacturer (ID) Micron Technology (2C00000000000000) Stock frequency 2100 MHz Core Speed 1198.3 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel ID1E57 rev. 04 CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 11 Cycle Time (tRAS) 28 Command Rate (CR) 1T Memory Frequency 798.9 MHz (1:6) Memory Type DDR3 Memory Size 6144 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 988B rPGA (0x4) Temperature 0 60°C (139°F) [0xD04] (TZS0) Temperature 1 30°C (85°F) [0xBD8] (TZS1)
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 22.16 fps, 7752.54 kb/s encoded 11812 frames, 22.33 fps, 7752.58 kb/s encoded 11812 frames, 22.00 fps, 7752.54 kb/s encoded 11812 frames, 22.29 fps, 7752.52 kb/s Pass 2 ------ encoded 11812 frames, 4.29 fps, 8002.59 kb/s encoded 11812 frames, 4.29 fps, 8002.62 kb/s encoded 11812 frames, 4.30 fps, 8002.62 kb/s encoded 11812 frames, 4.31 fps, 8002.65 kb/s System Details -------------- Name Intel Core i5 450M Codename Arrandale Specification Intel(R) Core(TM) i5 CPU M 450 @ 2.40GHz Core Stepping K0 Technology 32 nm Stock frequency 2400 MHz Core Speed 1463.1 MHz Northbridge Intel Havendale/Clarkdale Host Bridge rev. 18 Southbridge Intel HM57 rev. 06 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 532.0 MHz (4:16) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 989 rPGA (0x4) Temperature 4 59°C (138°F) [0x3B] (PCH) Temperature 5 65°C (148°F) [0x41] (GMCH) Temperature 0 27°C (80°F) [0xBB8] (TZ00) Temperature 1 0°C (32°F) [0xAAC] (TZ01)
Can I swap out x264.exe I used to be able to do this but ran into problems. Should I be able to compile the latest x264 build and just drop it into the test folder and rename? thx adam
You should be able to do that (if they didn't make any setting changes), but the results will NOT be comparable.
Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 24.64 fps, 7775.81 kb/s encoded 5906 frames, 24.79 fps, 7775.81 kb/s encoded 5906 frames, 25.46 fps, 7775.81 kb/s encoded 5906 frames, 25.78 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 5.81 fps, 8004.45 kb/s encoded 5906 frames, 5.81 fps, 8004.45 kb/s encoded 5906 frames, 5.81 fps, 8004.45 kb/s encoded 5906 frames, 5.81 fps, 8004.45 kb/s System Details -------------- Name Intel Core i3 2100 Codename Sandy Bridge Specification Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Core Stepping D2 Technology 32 nm Stock frequency 3100 MHz Core Speed 3093.6 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel H61 rev. B3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 665.3 MHz (1:5) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 33°C (91°F) [0x21] (TMPIN0) Temperature 2 49°C (120°F) [0x31] (TMPIN2) not a great CPU for video encoding unfortunately... need more cores.
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 24.50 fps, 7779.04 kb/s encoded 5906 frames, 25.03 fps, 7779.04 kb/s encoded 5906 frames, 25.62 fps, 7779.04 kb/s encoded 5906 frames, 24.93 fps, 7779.04 kb/s Pass 2 ------ encoded 5906 frames, 9.05 fps, 8003.15 kb/s encoded 5906 frames, 9.07 fps, 8003.15 kb/s encoded 5906 frames, 9.08 fps, 8003.15 kb/s encoded 5906 frames, 9.08 fps, 8003.15 kb/s System Details -------------- Name AMD FX-6100 product System Product Name Codename Zambezi Specification AMD FX(tm)-6100 Six-Core Processor Core Stepping OR-B2 Technology 32 nm Stock frequency 3300 MHz Core Speed 1406.4 MHz Northbridge AMD 780G rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Memory Frequency 669.7 MHz (3:10) Memory Type DDR3 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 32-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 3 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 52°C (125°F) [0x34] (TMPIN0) Temperature 1 33°C (91°F) [0x21] (TMPIN1)
i was doing simple work and browsing while testing.... ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 69.02 fps, 7754.35 kb/s encoded 11812 frames, 68.87 fps, 7754.24 kb/s encoded 11812 frames, 68.32 fps, 7754.30 kb/s encoded 11812 frames, 68.60 fps, 7754.13 kb/s Pass 2 ------ encoded 11812 frames, 14.38 fps, 8002.10 kb/s encoded 11812 frames, 14.34 fps, 8002.08 kb/s encoded 11812 frames, 14.38 fps, 8002.09 kb/s encoded 11812 frames, 14.20 fps, 8002.11 kb/s System Details -------------- Name Intel Core i7 2600K Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Core Stepping D2 Technology 32 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3400 MHz Core Speed 4001.4 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel P67 rev. B2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 22 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 800.3 MHz (1:6) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 43°C (109°F) [0x2B] (Aux) Temperature 1 36°C (96°F) [0x24] (CPU) Temperature 2 30°C (85°F) [0x1E] (Mainboard)
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 20.20 fps, 7772.80 kb/s encoded 5906 frames, 20.21 fps, 7772.80 kb/s encoded 5906 frames, 20.20 fps, 7772.80 kb/s encoded 5906 frames, 20.21 fps, 7772.80 kb/s Pass 2 ------ encoded 5906 frames, 3.91 fps, 8005.80 kb/s encoded 5906 frames, 3.92 fps, 8005.80 kb/s encoded 5906 frames, 3.93 fps, 8005.80 kb/s encoded 5906 frames, 3.93 fps, 8005.80 kb/s System Details -------------- Name AMD Athlon II X2 260 Codename Regor Specification AMD Athlon(tm) II X2 260 Processor Specification PC3-12800 Specification PC3-12800 Core Stepping DA-C3 Technology 45 nm Stock frequency 3200 MHz Core Speed 3214.8 MHz FID range 4.0x - 16.0x Northbridge NVIDIA GeForce 7025 rev. A3 Southbridge NVIDIA nForce 630a rev. A2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 12 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 30 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 669.8 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 33°C (91°F) [0x21] (SYSTIN) Temperature 1 50°C (121°F) [0x64] (CPUTIN) Temperature 2 36°C (95°F) [0x47] (AUXTIN) Simple OC @ 3600Mhz: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 22.57 fps, 7772.80 kb/s encoded 5906 frames, 22.67 fps, 7772.80 kb/s encoded 5906 frames, 22.65 fps, 7772.80 kb/s encoded 5906 frames, 22.64 fps, 7772.80 kb/s Pass 2 ------ encoded 5906 frames, 4.39 fps, 8005.80 kb/s encoded 5906 frames, 4.40 fps, 8005.80 kb/s encoded 5906 frames, 4.41 fps, 8005.80 kb/s encoded 5906 frames, 4.41 fps, 8005.80 kb/s System Details -------------- Name AMD Athlon II X2 260 Codename Regor Specification AMD Athlon(tm) II X2 260 Processor Specification PC3-12800 Specification PC3-12800 Core Stepping DA-C3 Technology 45 nm Stock frequency 3200 MHz Core Speed 3600.0 MHz FID range 4.0x - 16.0x Northbridge NVIDIA GeForce 7025 rev. A3 Southbridge NVIDIA nForce 630a rev. A2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 12 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 30 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 750.0 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 33°C (91°F) [0x21] (SYSTIN) Temperature 1 52°C (125°F) [0x68] (CPUTIN) Temperature 2 36°C (95°F) [0x47] (AUXTIN)
Xeon E5504 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 17.98 fps, 7775.81 kb/s encoded 5906 frames, 18.14 fps, 7775.81 kb/s encoded 5906 frames, 18.06 fps, 7775.81 kb/s encoded 5906 frames, 17.72 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 5.52 fps, 8004.45 kb/s encoded 5906 frames, 5.51 fps, 8004.45 kb/s encoded 5906 frames, 5.50 fps, 8004.45 kb/s encoded 5906 frames, 5.52 fps, 8004.45 kb/s System Details -------------- Name Intel Xeon E5504 Codename Gainestown Specification Intel(R) Xeon(R) CPU E5504 @ 2.00GHz Core Stepping D0 Technology 45 nm Stock frequency 2000 MHz Core Speed 1596.0 MHz Northbridge Intel 5500 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 15 Command Rate (CR) 1T Memory Frequency 399.0 MHz (2:6) Memory Type DDR3 Memory Size 2048 MBytes Channels Single Windows Version Microsoft Windows Server 2003 Standard Edition Service Pack 2 (Build 3790) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 8°C (46°F) [0xAFF] (THM0) Temperature 0 33°C (91°F) [0x4214] (core)
