x264 HD Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Mar 15, 2008.
  1. graysky
    graysky ARP Reviewer
    @Photok - got it thanks!
    @samlor - which chip is it? CPUZ couldn't detect :)
  2. SomeoneElse
    SomeoneElse Newbie
    Q9450-X38-8x333
    CPU: Intel Yorkfield Q9450 C1
    FSB: 8x333 (stock)
    CPU Speed: 2660
    Chipset: Intel X38
    Motherboard: Abit X38 QuadGT Bios 12
    Memory Timings: 5-5-5-15 2T @ 400 MHz (2GB DDR2-800)
    OS: WinXP SP2 + Updates
    C1E: Auto
    EIST: Enabled
    Results for x264.exe v0.58.747
    encoded 1442 frames, 58.08 fps, 3904.67 kb/s
    encoded 1442 frames, 58.15 fps, 3904.67 kb/s
    encoded 1442 frames, 58.30 fps, 3904.67 kb/s
    encoded 1442 frames, 58.11 fps, 3904.67 kb/s
    encoded 1442 frames, 16.10 fps, 3952.97 kb/s
    encoded 1442 frames, 16.11 fps, 3952.97 kb/s
    encoded 1442 frames, 16.07 fps, 3952.97 kb/s
    encoded 1442 frames, 16.08 fps, 3952.97 kb/s
    Results for x264.exe v0.59.819M
    encoded 1442 frames, 63.04 fps, 3887.46 kb/s
    encoded 1442 frames, 63.08 fps, 3889.37 kb/s
    encoded 1442 frames, 61.53 fps, 3889.39 kb/s
    encoded 1442 frames, 60.92 fps, 3888.90 kb/s
    encoded 1442 frames, 18.11 fps, 3963.29 kb/s
    encoded 1442 frames, 18.10 fps, 3962.48 kb/s
    encoded 1442 frames, 17.93 fps, 3962.73 kb/s
    encoded 1442 frames, 17.95 fps, 3962.52 kb/s
  3. SomeoneElse
    SomeoneElse Newbie
    Q9450-X38-8x400
    FSB: 8x400 (default is 8x333)
    CPU Speed: 3200
    Chipset: Intel X38
    Memory Timings: 5-5-5-15 2T @ 480.1 MHz (2GB DDR2-800)
    OS: WinXP SP2 + Updates (x86-32)
    C1E: Auto
    EIST: Enabled
    FSB changed from 8x333 to 8x400 in BIOS. No other settings were changed.
    encoded 1442 frames, 69.23 fps, 3904.67 kb/s
    encoded 1442 frames, 70.02 fps, 3904.67 kb/s
    encoded 1442 frames, 70.07 fps, 3904.67 kb/s
    encoded 1442 frames, 19.32 fps, 3952.97 kb/s
    encoded 1442 frames, 19.34 fps, 3952.97 kb/s
    encoded 1442 frames, 19.29 fps, 3952.97 kb/s
    encoded 1442 frames, 75.58 fps, 3886.80 kb/s
    encoded 1442 frames, 75.52 fps, 3889.68 kb/s
    encoded 1442 frames, 75.77 fps, 3890.92 kb/s
    encoded 1442 frames, 75.83 fps, 3868.96 kb/s
    encoded 1442 frames, 21.76 fps, 3963.48 kb/s
    encoded 1442 frames, 21.78 fps, 3962.71 kb/s
    encoded 1442 frames, 21.79 fps, 3962.53 kb/s
    encoded 1442 frames, 21.77 fps, 3964.16 kb/s
  4. Dashken
    Dashken Administrator!
    x264 HD Benchmark Version 2.0
    We have just updated the benchmark! :wave:
    The x264 HD Benchmark is the “High Definition version” of the x264 Benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts.
    The new x264 HD Benchmark ups the ante by using a new 720p24 high-definition video clip. Therefore, it will be a great test of the processor’s ability to encode HD quality video streams. Give it a try and let us know how your processor fares!
    This major revision adds script detection for Windows Vista with UAC enabled and it also allows the user to re-enable UAC (if that is what you REALLY, REALLY want to do) after the benchmark completes.
    Here's a quote from the article :-
    Link : x264 HD Benchmark Version 2.0
  5. graysky
    @someoneelse - got em and will update shortly.
    @dash - thanks for the hard work with this. Although I don't have vista to test it, I'm sure you did :)
  6. Dashken
    Yup. It's tested to be working. But I only tested it on Vista Home Premium, Vista Ultimate x64 and Windows XP. :D
    Hehe... you're welcome. :beer:
  7. Mac Daddy
    Tested on Vista Ultimate X64 here great work guys ;)
  8. Dashken
    LOL! Memory 8GB but reported 3GB only... :haha:
    Code:
    encoded 1442 frames, 55.49 fps, 3905.42 kb/s
    encoded 1442 frames, 56.07 fps, 3905.42 kb/s
    encoded 1442 frames, 55.40 fps, 3905.42 kb/s
    encoded 1442 frames, 56.31 fps, 3905.42 kb/s
    encoded 1442 frames, 15.93 fps, 3952.85 kb/s
    encoded 1442 frames, 15.96 fps, 3952.85 kb/s
    encoded 1442 frames, 16.03 fps, 3952.85 kb/s
    encoded 1442 frames, 15.94 fps, 3952.85 kb/s
    encoded 1442 frames, 60.96 fps, 3891.55 kb/s
    encoded 1442 frames, 60.60 fps, 3889.35 kb/s
    encoded 1442 frames, 60.52 fps, 3891.55 kb/s
    encoded 1442 frames, 60.20 fps, 3889.35 kb/s
    encoded 1442 frames, 17.91 fps, 3963.43 kb/s
    encoded 1442 frames, 17.90 fps, 3962.45 kb/s
    encoded 1442 frames, 17.82 fps, 3963.43 kb/s
    encoded 1442 frames, 17.86 fps, 3962.41 kb/s
    System Details
    Name			Intel Core 2 Quad Q9450
    Codename		Yorkfield
    Specification		Intel(R) Core(TM)2 Quad  CPU   Q9450  @ 2.66GHz
    Core Stepping		C1
    Technology		45 nm
    Stock frequency		2666 MHz
    Core Speed		2660.3 MHz (8.0 x 332.5 MHz)
    FID range		6.0x - 8.0x
    Northbridge		Intel P35/G33/G31 rev. A2
    Southbridge		Intel 82801IR (ICH9R) rev. 02
    CAS#			5.0
    RAS# to CAS#		5
    RAS# Precharge		5
    Cycle Time (tRAS)	15
    Command Rate		2T
    Memory Frequency	332.5 MHz (1:1)
    Memory Type		DDR2
    Memory Size		3070 MBytes
    Channels		Dual (Symmetric)
    Windows Version		Microsoft Windows Vista (6.0) Ultimate Edition  Service Pack 1 (Build 6001)
    max VID			1.125 V
    Voltage sensor 0	1.06 Volts [0x42] (CPU VCORE)
    Number of processors	1
    Number of threads	4
    Number of threads	4 (max 4)
    L2 cache		2 x 6144 KBytes, 24-way set associative, 64-byte line size
    Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
    Package			Socket 775 LGA (platform ID = 4h)
    Temperature sensor 0	34°C (93°F) [0x22] (TMPIN0)
    Temperature sensor 1	38°C (100°F) [0x26] (TMPIN1)
    Temperature sensor 2	25°C (76°F) [0x19] (TMPIN2)
    Temperature sensor 0	66°C (150°F) [0x27] (core #0)
    Temperature sensor 1	67°C (152°F) [0x26] (core #1)
    Temperature sensor 2	57°C (134°F) [0x30] (core #2)
    Temperature sensor 3	58°C (136°F) [0x2F] (core #3)
    Temperature sensor 0	50°C (121°F) [0x32] (GPU Core)
  9. graysky
    Got it... is it only Vista 32-bit? Is that why 5/8 of your memory isn't detected?
  10. Dashken
    Nope, it's Vista Ultimate x64. It's detected fine elsewhere but not cpuz it seems. :D
  11. Mac Daddy
    Thats strange man you sure you installed using the 64 bit disk and not Ultimate 32 bit ?
    Thats just weird our versions of Vista look the same but cpuz reports my memory properly :think:
    Code:
    CAS#			5.0
    RAS# to CAS#		5
    RAS# Precharge		4
    Cycle Time (tRAS)	17
    Command Rate		2T
    Memory Frequency	522.0 MHz (5:6)
    Memory Type		DDR2
    Memory Size		4094 MBytes
  12. agentshark
    agentshark Newbie
    encoded 1442 frames, 65.78 fps, 3905.42 kb/s
    encoded 1442 frames, 65.64 fps, 3905.42 kb/s
    encoded 1442 frames, 64.99 fps, 3905.42 kb/s
    encoded 1442 frames, 65.22 fps, 3905.42 kb/s
    encoded 1442 frames, 18.06 fps, 3952.85 kb/s
    encoded 1442 frames, 18.07 fps, 3952.85 kb/s
    encoded 1442 frames, 17.97 fps, 3952.85 kb/s
    Q6600 @ 3.2GHz: 9 x 356
    Abit IP35-PRO: Intel P35
    4GB OCZ 5-5-5-12 @ 854MHz
  13. kpfong
    kpfong Newbie
    encoded 1442 frames, 39.49 fps, 3905.42 kb/s
    encoded 1442 frames, 38.94 fps, 3905.42 kb/s
    encoded 1442 frames, 36.36 fps, 3905.42 kb/s
    encoded 1442 frames, 39.30 fps, 3905.42 kb/s
    encoded 1442 frames, 10.54 fps, 3952.85 kb/s
    encoded 1442 frames, 10.74 fps, 3952.85 kb/s
    encoded 1442 frames, 10.35 fps, 3952.85 kb/s
    encoded 1442 frames, 10.57 fps, 3952.85 kb/s
    encoded 1442 frames, 41.45 fps, 3889.35 kb/s
    encoded 1442 frames, 38.72 fps, 3891.55 kb/s
    encoded 1442 frames, 42.17 fps, 3891.55 kb/s
    encoded 1442 frames, 40.15 fps, 3891.55 kb/s
    encoded 1442 frames, 11.39 fps, 3962.47 kb/s
    encoded 1442 frames, 11.14 fps, 3963.43 kb/s
    encoded 1442 frames, 11.19 fps, 3963.44 kb/s
    encoded 1442 frames, 10.98 fps, 3963.43 kb/s
    System Details
    Name AMD Phenom 9500
    Codename Agena
    Specification AMD Phenom(tm) 9500 Quad-Core Processor
    Core Stepping DR-B2
    Technology 65 nm
    Stock frequency 2200 MHz
    Core Speed 2200.2 MHz (11.0 x 200.0 MHz)
    FID range 5.0x - 11.0x
    Northbridge AMD 780G rev. 00
    Southbridge ATI SB700 rev. 00
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 18
    Command Rate 2T
    Memory Frequency 400.0 MHz (1:2)
    Memory Type DDR2
    Memory Size 3326 MBytes
    Channels Single
    Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
    max VID 1.250 V
    Voltage sensor 0 1.21 Volts [0x97] (CPU VCORE)
    Number of threads 4
    L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
    Package Socket AM2+ (940)
    Package Type 0x1
    Temperature sensor 0 39 (102) [0x27] (SYSTIN)
    Temperature sensor 1 58 (135) [0x73] (CPUTIN)
    Temperature sensor 2 55 (130) [0x6E] (AUXTIN)
    Temperature sensor 0 50 (121) [0x18C] (core #0)
    Temperature sensor 1 50 (121) [0x18C] (core #1)
    Temperature sensor 2 50 (121) [0x18C] (core #2)
    Temperature sensor 3 50 (121) [0x18C] (core #3)
  14. kpfong
    kpfong Newbie
    encoded 1442 frames, 50.54 fps, 3905.42 kb/s
    encoded 1442 frames, 51.57 fps, 3905.42 kb/s
    encoded 1442 frames, 51.12 fps, 3905.42 kb/s
    encoded 1442 frames, 51.17 fps, 3905.42 kb/s
    encoded 1442 frames, 12.64 fps, 3952.85 kb/s
    encoded 1442 frames, 12.65 fps, 3952.85 kb/s
    encoded 1442 frames, 12.66 fps, 3952.85 kb/s
    encoded 1442 frames, 12.63 fps, 3952.85 kb/s
    encoded 1442 frames, 52.55 fps, 3891.55 kb/s
    encoded 1442 frames, 52.91 fps, 3889.35 kb/s
    encoded 1442 frames, 52.51 fps, 3891.55 kb/s
    encoded 1442 frames, 52.66 fps, 3887.30 kb/s
    encoded 1442 frames, 13.54 fps, 3963.43 kb/s
    encoded 1442 frames, 13.48 fps, 3963.50 kb/s
    encoded 1442 frames, 13.52 fps, 3963.43 kb/s
    encoded 1442 frames, 13.54 fps, 3963.30 kb/s
    System Details
    Name AMD Phenom 9750
    Codename Agena
    Specification AMD Phenom(tm) 9750 Quad-Core Processor
    Core Stepping DR-B3
    Technology 65 nm
    Stock frequency 2400 MHz
    Core Speed 2400.2 MHz (12.0 x 200.0 MHz)
    FID range 5.0x - 12.0x
    Northbridge ATI RD790 rev. 00
    Southbridge ATI SB600 rev. 00
    CAS# 6.0
    RAS# to CAS# 6
    RAS# Precharge 6
    Command Rate 2T
    Memory Type DDR2
    Memory Size 8192 MBytes
    Channels Dual (Unganged)
    max VID 1.250 V
    Voltage sensor 0 3.31 Volts [0xCF] (+3.3V)
    Number of threads 4
    Package Type 0x1
    Temperature sensor 0 58°C (136°F) [0x3A] (TMPIN0)
    Temperature sensor 2 30°C (85°F) [0x1E] (TMPIN2)
    Temperature sensor 0 56°C (132°F) [0x1C0] (core #0)
    Temperature sensor 1 56°C (132°F) [0x1C0] (core #1)
    Temperature sensor 2 56°C (132°F) [0x1C0] (core #2)
    Temperature sensor 3 56°C (132°F) [0x1C0] (core #3)
    Temperature sensor 0 58°C (136°F) [0x3A] (GPU Core)
  15. g0tanks
    g0tanks Newbie
    x264 HD BENCHMARK RESULTS
    Please copy/paste everything below the line into the forum post to report your data
    encoded 1442 frames, 57.08 fps, 3905.42 kb/s
    encoded 1442 frames, 57.23 fps, 3905.42 kb/s
    encoded 1442 frames, 56.93 fps, 3905.42 kb/s
    encoded 1442 frames, 56.74 fps, 3905.42 kb/s
    encoded 1442 frames, 16.65 fps, 3952.85 kb/s
    encoded 1442 frames, 16.73 fps, 3952.85 kb/s
    encoded 1442 frames, 16.61 fps, 3952.85 kb/s
    encoded 1442 frames, 16.55 fps, 3952.85 kb/s
    encoded 1442 frames, 60.26 fps, 3891.55 kb/s
    encoded 1442 frames, 61.10 fps, 3891.55 kb/s
    encoded 1442 frames, 60.86 fps, 3891.55 kb/s
    encoded 1442 frames, 60.94 fps, 3891.55 kb/s
    encoded 1442 frames, 18.47 fps, 3963.43 kb/s
    encoded 1442 frames, 18.56 fps, 3963.43 kb/s
    encoded 1442 frames, 18.55 fps, 3963.43 kb/s
    encoded 1442 frames, 18.57 fps, 3963.43 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU @ 2.40GHz
    Core Stepping B3
    Technology 65 nm
    Core Speed 3000.1 MHz (9.0 x 333.3 MHz)
    FID range 6.0x - 9.0x
    Northbridge NVIDIA nForce 650i Ultra SPP rev. A2
    Southbridge NVIDIA nForce 650i Ultra MCP rev. A3
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 400.0 MHz (5:6)
    Memory Type DDR2
    Channels Dual
    max VID 1.250 V
    Voltage sensor 0 1.24 Volts [0x9B] (CPU VCORE)
    Number of threads 4
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
    Temperature sensor 1 57°C (134°F) [0x72] (CPU)
    Temperature sensor 2 25°C (76°F) [0x32] (AUX)
    Temperature sensor 0 78°C (172°F) [0x16] (core #0)
    Temperature sensor 1 74°C (165°F) [0x1A] (core #1)
    Temperature sensor 2 73°C (163°F) [0x1B] (core #2)
    Temperature sensor 3 73°C (163°F) [0x1B] (core #3)
    Temperature sensor 0 63°C (145°F) [0x3F] (GPU Core)
    I don't think the temperatures are right though..
  16. g0tanks
    g0tanks Newbie
    Now on XP with slightly better results.
    encoded 1442 frames, 58.86 fps, 3905.42 kb/s
    encoded 1442 frames, 59.93 fps, 3905.42 kb/s
    encoded 1442 frames, 59.97 fps, 3905.42 kb/s
    encoded 1442 frames, 60.08 fps, 3905.42 kb/s
    encoded 1442 frames, 16.87 fps, 3952.85 kb/s
    encoded 1442 frames, 16.88 fps, 3952.85 kb/s
    encoded 1442 frames, 16.80 fps, 3952.85 kb/s
    encoded 1442 frames, 63.78 fps, 3889.52 kb/s
    encoded 1442 frames, 63.64 fps, 3886.93 kb/s
    encoded 1442 frames, 63.78 fps, 3890.88 kb/s
    encoded 1442 frames, 63.00 fps, 3886.74 kb/s
    encoded 1442 frames, 18.84 fps, 3962.51 kb/s
    encoded 1442 frames, 18.83 fps, 3963.67 kb/s
    encoded 1442 frames, 18.86 fps, 3962.40 kb/s
    encoded 1442 frames, 18.77 fps, 3963.83 kb/s
    System Details
    Codename Kentsfield
    Core Stepping B3
    Technology 65 nm
    Core Speed 3000.0 MHz (9.0 x 333.3 MHz)
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Type DDR2
    Memory Size 2816 MBytes
    Channels Dual
    Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
    max VID 1.250 V
    Voltage sensor 0 1.23 Volts [0x9A] (CPU VCORE)
    Number of threads 4
    Temperature sensor 1 61°C (141°F) [0x7A] (CPU)
    Temperature sensor 2 19°C (66°F) [0x26] (AUX)
    Temperature sensor 3 71°C (159°F) [0x1D] (core #3)
    Temperature sensor 2 75°C (166°F) [0x19] (core #2)
    Temperature sensor 0 62°C (143°F) [0x3E] (GPU Core)
  17. graysky
    thanks for the data sets, guys. I'll update shortly.
  18. kpfong
    kpfong Newbie
    encoded 1442 frames, 54.25 fps, 3904.67 kb/s
    encoded 1442 frames, 54.12 fps, 3904.67 kb/s
    encoded 1442 frames, 54.09 fps, 3904.67 kb/s
    encoded 1442 frames, 53.90 fps, 3904.67 kb/s
    encoded 1442 frames, 14.96 fps, 3952.97 kb/s
    encoded 1442 frames, 14.97 fps, 3952.97 kb/s
    encoded 1442 frames, 14.94 fps, 3952.97 kb/s
    encoded 1442 frames, 58.62 fps, 3887.23 kb/s
    encoded 1442 frames, 58.40 fps, 3889.38 kb/s
    encoded 1442 frames, 58.29 fps, 3889.41 kb/s
    encoded 1442 frames, 58.47 fps, 3886.98 kb/s
    encoded 1442 frames, 16.73 fps, 3963.59 kb/s
    encoded 1442 frames, 16.74 fps, 3962.87 kb/s
    encoded 1442 frames, 16.62 fps, 3962.60 kb/s
    encoded 1442 frames, 16.72 fps, 3963.33 kb/s
    System Details
    Name Intel Core 2 Quad Q6700
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz
    Core Stepping G0
    Technology 65 nm
    Core Speed 2660.5 MHz (10.0 x 266.0 MHz)
    FID range 6.0x - 10.0x
    Northbridge Intel Q35 rev. A2
    Southbridge Intel ID2914 rev. 02
    CAS# 6.0
    RAS# to CAS# 6
    RAS# Precharge 6
    Command Rate 2T
    Memory Frequency 399.1 MHz (2:3)
    Memory Type DDR2
    Memory Size 3062 MBytes
    max VID 1.250 V
    Number of threads 4
    Temperature sensor 0 67°C (152°F) [0x21] (core #0)
    Temperature sensor 1 65°C (148°F) [0x23] (core #1)
    Temperature sensor 2 63°C (145°F) [0x25] (core #2)
    Temperature sensor 3 62°C (143°F) [0x26] (core #3)
  19. kpfong
    kpfong Newbie
    encoded 1442 frames, 18.76 fps, 3905.08 kb/s
    encoded 1442 frames, 18.95 fps, 3905.08 kb/s
    encoded 1442 frames, 18.07 fps, 3905.08 kb/s
    encoded 1442 frames, 19.09 fps, 3905.08 kb/s
    encoded 1442 frames, 4.39 fps, 3942.92 kb/s
    encoded 1442 frames, 4.41 fps, 3942.92 kb/s
    encoded 1442 frames, 4.44 fps, 3942.92 kb/s
    encoded 1442 frames, 4.37 fps, 3942.92 kb/s
    encoded 1442 frames, 20.06 fps, 3889.96 kb/s
    encoded 1442 frames, 20.02 fps, 3889.96 kb/s
    encoded 1442 frames, 20.44 fps, 3889.96 kb/s
    encoded 1442 frames, 20.08 fps, 3889.96 kb/s
    encoded 1442 frames, 4.70 fps, 3953.35 kb/s
    encoded 1442 frames, 4.64 fps, 3953.35 kb/s
    encoded 1442 frames, 4.68 fps, 3953.35 kb/s
    encoded 1442 frames, 4.69 fps, 3953.35 kb/s
    System Details
    Name AMD Athlon 64 X2 BE-2300
    Codename Brisbane
    Specification AMD Athlon(tm) X2 Dual Core Processor BE-2300
    Core Stepping BH-G2
    Technology 65 nm
    Stock frequency 1900 MHz
    Core Speed 1900.0 MHz (9.5 x 200.0 MHz)
    Northbridge ATI RS690/RS690M rev. 00
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 380.0 MHz (CPU/5)
    Memory Type DDR2
    Memory Size 1918 MBytes
    Channels Dual
    Windows Version Microsoft Windows Vista (6.0) Home Premium Edition (Build 6000)
    max VID 1.300 V
    Voltage sensor 0 1.26 Volts [0x4F] (CPU VCORE)
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
    Package Socket AM2 (940)
    Temperature sensor 0 74°C (165°F) [0x4A] (TMPIN0)
    Temperature sensor 1 47°C (116°F) [0x2F] (TMPIN1)
    Temperature sensor 0 48°C (117°F) [0x182] (core #0)
    Temperature sensor 1 52°C (125°F) [0x193] (core #1)
  20. graysky
    got 'em, thanks. Will update soon.
