@ditche - thanks for the results. I just updated the db today, but I'll add your results on the next update. About the latest build, yeah, I know they keep getting faster and faster. Continually updating can get confusing (hell, having two versions of x264 is confusing enough)! The nice thing about it is that as far as I can tell, the rank-order of results hasn't changed. In other words, the magnitude if the encode time may improve as x264 becomes more refined, but the systems should run it more or less in the order presented with the included exe's.
x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 56.99 fps, 3905.42 kb/s encoded 1442 frames, 57.88 fps, 3905.42 kb/s encoded 1442 frames, 58.17 fps, 3905.42 kb/s encoded 1442 frames, 57.70 fps, 3905.42 kb/s encoded 1442 frames, 14.64 fps, 3952.85 kb/s encoded 1442 frames, 14.69 fps, 3952.85 kb/s encoded 1442 frames, 14.66 fps, 3952.85 kb/s encoded 1442 frames, 14.65 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 58.25 fps, 3891.55 kb/s encoded 1442 frames, 58.65 fps, 3891.55 kb/s encoded 1442 frames, 58.84 fps, 3891.55 kb/s encoded 1442 frames, 59.52 fps, 3891.55 kb/s encoded 1442 frames, 15.51 fps, 3963.43 kb/s encoded 1442 frames, 15.60 fps, 3963.43 kb/s encoded 1442 frames, 15.77 fps, 3963.43 kb/s encoded 1442 frames, 15.77 fps, 3963.43 kb/s System Details -------------- Name AMD Phenom X4 9850 Codename Agena Specification AMD Phenom(tm) 9850 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Core Speed 2812.8 MHz (14.0 x 200.9 MHz) Northbridge ATI RD790 rev. 00 Southbridge ATI SB600 rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 334.9 MHz (3:5) Memory Type DDR2 Memory Size 8190 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) Voltage sensor 0 1.42 Volts [0x59] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 53°C (127°F) [0x35] (System) Temperature sensor 1 56°C (132°F) [0x38] (CPU) Temperature sensor 0 59°C (138°F) [0x1D8] (core #0) Temperature sensor 1 59°C (138°F) [0x1D8] (core #1) Temperature sensor 3 59°C (138°F) [0x1D8] (core #3) Temperature sensor 2 58°C (136°F) [0x1D0] (core #2) Temperature sensor 0 71°C (159°F) [0x47] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 31.73 fps, 3905.08 kb/s encoded 1442 frames, 32.04 fps, 3905.08 kb/s encoded 1442 frames, 31.99 fps, 3905.08 kb/s encoded 1442 frames, 32.02 fps, 3905.08 kb/s encoded 1442 frames, 8.04 fps, 3942.92 kb/s encoded 1442 frames, 8.04 fps, 3942.92 kb/s encoded 1442 frames, 8.04 fps, 3942.92 kb/s encoded 1442 frames, 8.04 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 35.83 fps, 3887.99 kb/s encoded 1442 frames, 35.36 fps, 3888.30 kb/s encoded 1442 frames, 35.60 fps, 3887.58 kb/s encoded 1442 frames, 35.81 fps, 3887.97 kb/s encoded 1442 frames, 8.97 fps, 3953.45 kb/s encoded 1442 frames, 8.98 fps, 3954.97 kb/s encoded 1442 frames, 8.97 fps, 3953.28 kb/s encoded 1442 frames, 8.98 fps, 3953.01 kb/s System Details -------------- Name Intel Core 2 Duo E4300 Codename Conroe Specification Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz Core Stepping L2 Technology 65 nm Stock frequency 1800 MHz Core Speed 2880.2 MHz (9.0 x 320.0 MHz) FID range 6.0x - 9.0x Northbridge Intel P965/G965 rev. C2 Southbridge Intel 82801HB/HR (ICH8/R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 400.0 MHz (4:5) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 1 (Build 2600) max VID 1.325 V Voltage sensor 0 1.41 Volts [0x58] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 33°C (91°F) [0x21] (TMPIN0) Temperature sensor 1 46°C (114°F) [0x2E] (TMPIN1) Temperature sensor 0 60°C (139°F) [0x28] (core #0) Temperature sensor 1 60°C (139°F) [0x28] (core #1) Temperature sensor 0 42°C (107°F) [0x2A] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 32.87 fps, 3905.08 kb/s encoded 1442 frames, 33.03 fps, 3905.08 kb/s encoded 1442 frames, 33.17 fps, 3905.08 kb/s encoded 1442 frames, 33.19 fps, 3905.08 kb/s encoded 1442 frames, 8.36 fps, 3942.92 kb/s encoded 1442 frames, 8.36 fps, 3942.92 kb/s encoded 1442 frames, 8.36 fps, 3942.92 kb/s encoded 1442 frames, 8.36 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 36.90 fps, 3888.26 kb/s encoded 1442 frames, 36.86 fps, 3887.38 kb/s encoded 1442 frames, 37.12 fps, 3887.99 kb/s encoded 1442 frames, 36.89 fps, 3887.74 kb/s encoded 1442 frames, 9.34 fps, 3954.63 kb/s encoded 1442 frames, 9.33 fps, 3953.24 kb/s encoded 1442 frames, 9.33 fps, 3953.45 kb/s encoded 1442 frames, 9.32 fps, 3953.36 kb/s System Details -------------- Name Intel Core 2 Duo E4300 Codename Conroe Specification Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz Core Stepping L2 Technology 65 nm Stock frequency 1800 MHz Core Speed 8297.0 MHz (9.0 x 921.9 MHz) * should be 2997.0 (9.0 x 333) * FID range 6.0x - 9.0x Northbridge Intel P965/G965 rev. C2 Southbridge Intel 82801HB/HR (ICH8/R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 1152.4 MHz (4:5) * should be 416.3 * Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 1 (Build 2600) max VID 1.325 V Voltage sensor 0 1.41 Volts [0x58] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 33°C (91°F) [0x21] (TMPIN0) Temperature sensor 1 46°C (114°F) [0x2E] (TMPIN1) Temperature sensor 0 61°C (141°F) [0x27] (core #0) Temperature sensor 1 59°C (138°F) [0x29] (core #1) Temperature sensor 0 41°C (105°F) [0x29] (GPU Core)
Two older Dell servers, the first one is my fileserver and the second I don't turn on, as it's too loud . Results for x264.exe v0.58.747 encoded 1442 frames, 12.00 fps, 3904.67 kb/s encoded 1442 frames, 12.06 fps, 3904.67 kb/s encoded 1442 frames, 12.06 fps, 3904.67 kb/s encoded 1442 frames, 12.06 fps, 3904.67 kb/s encoded 1442 frames, 3.01 fps, 3952.97 kb/s encoded 1442 frames, 3.04 fps, 3952.97 kb/s encoded 1442 frames, 3.06 fps, 3952.97 kb/s encoded 1442 frames, 3.03 fps, 3952.97 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 13.09 fps, 3889.34 kb/s encoded 1442 frames, 13.14 fps, 3889.34 kb/s encoded 1442 frames, 13.11 fps, 3889.34 kb/s encoded 1442 frames, 13.06 fps, 3888.38 kb/s encoded 1442 frames, 3.35 fps, 3962.76 kb/s encoded 1442 frames, 3.31 fps, 3962.75 kb/s encoded 1442 frames, 3.34 fps, 3962.75 kb/s encoded 1442 frames, 3.34 fps, 3963.58 kb/s System Details -------------- Name Intel Xeon Name Intel Xeon Codename Prestonia Codename Prestonia Specification Intel(R) XEON(TM) CPU 2.00GHz Specification Intel(R) XEON(TM) CPU 2.00GHz Core Stepping B0 Core Stepping B0 Technology 0.13 um Technology 0.13 um Stock frequency 2000 MHz Stock frequency 2000 MHz Core Speed 1993.9 MHz (20.0 x 99.7 MHz) Core Speed 1993.9 MHz (20.0 x 99.7 MHz) Northbridge Intel i860 rev. A3 Southbridge Intel 82801BA (ICH2) rev. 04 Total CAS# (tRDRAM) 12 Memory Frequency 398.8 MHz (1:1) Memory Type RDRAM Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows Vista (6.0) Service Pack 1 (Build 6001) <- Actually Server 2008 Standard Number of processors 2 Number of threads 4 Number of threads 2 (max 2) Number of threads 2 (max 2) L2 cache 512 KBytes, 8-way set associative, 64-byte line size L2 cache 512 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2 Instructions sets MMX, SSE, SSE2 Package Socket 604 mPGA (platform ID = 1h) Package Socket 604 mPGA (platform ID = 1h) --------------------------------------------------------- Results for x264.exe v0.58.747 encoded 1442 frames, 15.79 fps, 3905.23 kb/s encoded 1442 frames, 16.05 fps, 3905.23 kb/s encoded 1442 frames, 15.98 fps, 3905.23 kb/s encoded 1442 frames, 16.04 fps, 3905.23 kb/s encoded 1442 frames, 4.43 fps, 3952.94 kb/s encoded 1442 frames, 4.45 fps, 3952.94 kb/s encoded 1442 frames, 4.44 fps, 3952.94 kb/s encoded 1442 frames, 4.30 fps, 3952.94 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 17.26 fps, 3891.41 kb/s encoded 1442 frames, 17.32 fps, 3891.41 kb/s encoded 1442 frames, 17.28 fps, 3888.99 kb/s encoded 1442 frames, 17.31 fps, 3889.45 kb/s encoded 1442 frames, 4.81 fps, 3962.86 kb/s encoded 1442 frames, 4.80 fps, 3962.86 kb/s encoded 1442 frames, 4.82 fps, 3962.76 kb/s encoded 1442 frames, 4.82 fps, 3962.79 kb/s System Details -------------- Name Intel Xeon Name Intel Xeon Codename Prestonia Codename Prestonia Specification Intel(R) Xeon(TM) MP CPU 2.80GHz Specification Intel(R) Xeon(TM) MP CPU 2.80GHz Core Stepping M0 Core Stepping M0 Technology 0.13 um Technology 0.13 um Stock frequency 2800 MHz Stock frequency 2800 MHz Core Speed 2791.0 MHz (28.0 x 99.7 MHz) Core Speed 2791.0 MHz (28.0 x 99.7 MHz) Northbridge ServerWorks CMIC-HE rev. 22 Southbridge ServerWorks ID0225 rev. 00 Memory Type Memory Size 3840 MBytes Windows Version Microsoft Windows Server 2003 Standard Edition Service Pack 2 (Build 3790) Number of processors 2 Number of threads 4 Number of threads 2 (max 2) Number of threads 2 (max 2) L2 cache 512 KBytes, 8-way set associative, 64-byte line size L2 cache 512 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2 Instructions sets MMX, SSE, SSE2 Package Socket 604 mPGA (platform ID = 1h) Package Socket 604 mPGA (platform ID = 1h)
x264 .bat file: 'tee' is not recognized Sent a PM, but will post here for others who might get same error. Trying to bench my Asus P5k D w/ Q6600[G0] in XP (SP2). Upon running the x264 .bat file, I get: 'tee' is not recognized as an internal or external command, operable program or batch file. Apparently, "tee run1pass2.log" isn't working, for some reason. Any ideas? beachbouy
Hereby another posting... Results for x264.exe v0.58.747 encoded 1442 frames, 22.70 fps, 3905.08 kb/s encoded 1442 frames, 22.70 fps, 3905.08 kb/s encoded 1442 frames, 22.61 fps, 3905.08 kb/s encoded 1442 frames, 22.61 fps, 3905.08 kb/s encoded 1442 frames, 5.64 fps, 3942.92 kb/s encoded 1442 frames, 5.64 fps, 3942.92 kb/s encoded 1442 frames, 5.62 fps, 3942.92 kb/s encoded 1442 frames, 5.63 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 25.48 fps, 3888.16 kb/s encoded 1442 frames, 24.62 fps, 3887.38 kb/s encoded 1442 frames, 25.43 fps, 3889.96 kb/s encoded 1442 frames, 25.44 fps, 3889.96 kb/s encoded 1442 frames, 6.29 fps, 3954.63 kb/s encoded 1442 frames, 6.28 fps, 3953.73 kb/s encoded 1442 frames, 6.28 fps, 3953.35 kb/s encoded 1442 frames, 6.31 fps, 3953.35 kb/s System Details -------------- Name Intel Mobile Core 2 Duo T7300 Codename Merom Specification Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz Core Stepping E1 Technology 65 nm Stock frequency 2000 MHz Core Speed 1995.1 MHz (10.0 x 199.5 MHz) FID range 6.0x - 10.0x Northbridge Intel GM965 rev. C0 Southbridge Intel 82801HBM (ICH8-ME) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Memory Frequency 332.5 MHz (3:5) Memory Type DDR2 Memory Size 2038 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.363 V Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket P (478) (platform ID = 7h) Temperature sensor 0 74°C (165°F) [0x1A] (core #0) Temperature sensor 1 90°C (193°F) [0xA] (core #1)
I moved this one jvdstoel it was posted on the RE:X264HD thread on General Software. Thats for general discussion of the program
x264 HD Results... issues... For whatever reason, the .vbs file would not run, so I ran the benchmark from the .bat file in the 'test' folder. Note that x264-819 crashed twice during the process. -------- Results for x264.exe v0.58.747 encoded 1442 frames, 71.04 fps, 3905.42 kb/s encoded 1442 frames, 72.16 fps, 3905.42 kb/s encoded 1442 frames, 72.55 fps, 3905.42 kb/s encoded 1442 frames, 72.22 fps, 3905.42 kb/s encoded 1442 frames, 19.68 fps, 3952.85 kb/s encoded 1442 frames, 19.65 fps, 3952.85 kb/s encoded 1442 frames, 19.63 fps, 3952.85 kb/s encoded 1442 frames, 19.62 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 78.14 fps, 3891.55 kb/s encoded 1442 frames, 77.95 fps, 3889.39 kb/s encoded 1442 frames, 77.88 fps, 3889.28 kb/s encoded 1442 frames, 22.00 fps, 3963.43 kb/s encoded 1442 frames, 21.99 fps, 3954.38 kb/s encoded 1442 frames, 21.95 fps, 3962.59 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3474.1 MHz (9.0 x 386.0 MHz) FID range 6.0x - 9.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 4.0 RAS# to CAS# 4 RAS# Precharge 4 Cycle Time (tRAS) 12 Command Rate 2T Memory Frequency 482.5 MHz (4:5) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) max VID 1.200 V Voltage sensor 0 1.25 Volts [0x9C] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 39°C (102°F) [0x27] (SYSTIN) Temperature sensor 1 47°C (116°F) [0x5E] (CPUTIN) *Temperature sensor 2 119°C (246°F) [0xEE] (AUXTIN) Temperature sensor 0 63°C (145°F) [0x25] (core #0) Temperature sensor 1 62°C (143°F) [0x26] (core #1) Temperature sensor 2 57°C (134°F) [0x2B] (core #2) Temperature sensor 3 58°C (136°F) [0x2A] (core #3) Temperature sensor 0 50°C (121°F) [0x32] (GPU Core) ------- Look at the temperature on sensor 2* above. Now, what I want to know is, what the hell is registering 246°F in my system !!!
