x264 HD Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Mar 15, 2008.
  1. rocketmen2k5
    rocketmen2k5 Newbie
    Why the deception?
    It would be nice to state in your instruction that you have to download two(2)files for this to work not just one(1).
    Not only do you have to download AviSynth 2.5.7 BUT you also need to download x264 Benchmark HD.
    Why isn't this stated in the instruction?:confused:
  2. Narcosis
    Narcosis Newbie
    Results for x264.exe v0.58.747
    encoded 1442 frames, 62.70 fps, 3905.42 kb/s
    encoded 1442 frames, 62.57 fps, 3905.42 kb/s
    encoded 1442 frames, 62.65 fps, 3905.42 kb/s
    encoded 1442 frames, 62.74 fps, 3905.42 kb/s
    encoded 1442 frames, 17.21 fps, 3952.85 kb/s
    encoded 1442 frames, 17.25 fps, 3952.85 kb/s
    encoded 1442 frames, 17.27 fps, 3952.85 kb/s
    Results for x264.exe v0.59.819M
    encoded 1442 frames, 67.27 fps, 3887.12 kb/s
    encoded 1442 frames, 67.56 fps, 3889.29 kb/s
    encoded 1442 frames, 67.31 fps, 3888.63 kb/s
    encoded 1442 frames, 67.41 fps, 3889.26 kb/s
    encoded 1442 frames, 19.23 fps, 3963.14 kb/s
    encoded 1442 frames, 19.27 fps, 3962.91 kb/s
    encoded 1442 frames, 19.25 fps, 3962.67 kb/s
    encoded 1442 frames, 19.23 fps, 3962.50 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
    Core Stepping G0
    Technology 65 nm
    Stock frequency 2400 MHz
    Core Speed 3086.4 MHz (9.0 x 342.9 MHz)
    FID range 6.0x - 9.0x
    Northbridge Intel P35/G33/G31 rev. A2
    Southbridge Intel 82801IR (ICH9R) rev. 02
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 18
    Command Rate 2T
    Memory Frequency 411.5 MHz (5:6)
    Memory Type DDR2
    Memory Size 3328 MBytes
    Channels Dual (Symmetric)
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    max VID 1.213 V
    Voltage sensor 0 1.18 Volts [0x94] (CPU VCORE)
    Number of processors 1
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
    Package Socket 775 LGA (platform ID = 4h)
    Temperature sensor 0 38°C (100°F) [0x26] (SYSTIN)
    Temperature sensor 1 48°C (118°F) [0x60] (CPUTIN)
    Temperature sensor 2 119°C (246°F) [0xEE] (AUXTIN)
    Temperature sensor 0 65°C (148°F) [0x23] (core #0)
    Temperature sensor 1 63°C (145°F) [0x25] (core #1)
    Temperature sensor 2 61°C (141°F) [0x27] (core #2)
    Temperature sensor 3 61°C (141°F) [0x27] (core #3)
    Temperature sensor 0 38°C (100°F) [0x26] (GPU Core)
  3. Adrian Wong
    LOL!!! How will you run the benchmark if you only download AVISynth? :mrgreen:
    It's not like you are running XYZ Benchmark which needs the x264 HD Benchmark as well as AVISynth to function.
  4. mariushm
    mariushm Newbie
    SD benchmark:
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 37.46 fps, 1850.89 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 37.84 fps, 1850.89 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 37.22 fps, 1850.89 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 37.55 fps, 1850.89 kb/s
    ---------- RUN5PASS1.LOG
    encoded 1749 frames, 37.60 fps, 1850.89 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 9.58 fps, 1826.37 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 9.54 fps, 1826.38 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 9.57 fps, 1826.38 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 9.61 fps, 1826.37 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 9.59 fps, 1826.27 kb/s
    HD benchmark:
    x264 HD BENCHMARK RESULTS
    Please copy/paste everything below the line into the forum post to report your data
    encoded 1442 frames, 14.56 fps, 3905.08 kb/s
    encoded 1442 frames, 14.45 fps, 3905.08 kb/s
    encoded 1442 frames, 14.46 fps, 3905.08 kb/s
    encoded 1442 frames, 3.59 fps, 3942.92 kb/s
    encoded 1442 frames, 3.58 fps, 3942.92 kb/s
    System Details
    Name Intel Pentium D 805
    Codename SmithField
    Specification Intel(R) Pentium(R) D CPU 2.66GHz
    Core Stepping B0
    Technology 90 nm
    Stock frequency 2666 MHz
    Core Speed 2666.7 MHz (20.0 x 133.3 MHz)
    Northbridge NVIDIA nForce4 SLI Intel Edition rev. A1
    Southbridge NVIDIA nForce4 MCP rev. A3
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 15
    Memory Frequency 333.3 MHz (4:10)
    Memory Type DDR2
    Memory Size 2048 MBytes
    Channels Dual
    Windows Version Microsoft Windows Server 2003 Enterprise Edition Service Pack 2 (Build 3790)
    Voltage sensor 0 1.25 Volts [0x4E] (CPU VCORE)
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 2 x 1024 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, EM64T
    Temperature sensor 0 55°C (130°F) [0x37] (TMPIN0)
    Temperature sensor 1 40°C (103°F) [0x28] (TMPIN1)
    Temperature sensor 2 121°C (249°F) [0x79] (TMPIN2)
    Temperature sensor 0 71°C (159°F) [0x47] (GPU Core)
    ^^ only ran with the first encoder version because I don't have another 20 minutes to spare at the moment .
    Standard D805, 2.66GHz , 2GB DDR2 667 Kingston Value, Windows 2003 R2.
  5. JetJock_fl
    JetJock_fl Newbie
    Waiting on the Bababoom software to see if it will be compatiable with this benchmark. Hope so. Anyway this is the test platform for the Badaboom software. Here are my results without CUDA.
    encoded 1442 frames, 71.43 fps, 3905.42 kb/s
    encoded 1442 frames, 71.54 fps, 3905.42 kb/s
    encoded 1442 frames, 71.87 fps, 3905.42 kb/s
    encoded 1442 frames, 71.93 fps, 3905.42 kb/s
    encoded 1442 frames, 19.77 fps, 3952.85 kb/s
    encoded 1442 frames, 19.64 fps, 3952.85 kb/s
    encoded 1442 frames, 19.65 fps, 3952.85 kb/s
    encoded 1442 frames, 19.68 fps, 3952.85 kb/s
    encoded 1442 frames, 76.84 fps, 3889.54 kb/s
    encoded 1442 frames, 77.23 fps, 3883.91 kb/s
    encoded 1442 frames, 77.42 fps, 3886.47 kb/s
    encoded 1442 frames, 77.29 fps, 3887.80 kb/s
    encoded 1442 frames, 22.12 fps, 3962.73 kb/s
    encoded 1442 frames, 22.16 fps, 3963.61 kb/s
    encoded 1442 frames, 22.12 fps, 3963.24 kb/s
    encoded 1442 frames, 22.12 fps, 3963.27 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 3487.7 MHz (9.0 x 387.5 MHz)
    Northbridge NVIDIA nForce 790i Ultra SLI SPP rev. B1
    Southbridge NVIDIA nForce 790i Ultra SLI MCP rev. A3
    CAS# 7.0
    RAS# to CAS# 7
    RAS# Precharge 7
    Cycle Time (tRAS) 19
    Command Rate 1T
    Memory Frequency 620.0 MHz (5:8)
    Memory Type DDR3
    Channels Dual
    max VID 1.300 V
    Voltage sensor 0 1.38 Volts [0xAC] (CPU VCORE)
    Number of threads 4
    Temperature sensor 0 86°C (186°F) [0x56] (SYSTIN)
    Temperature sensor 1 1°C (32°F) [0x1FF] (CPUTIN)
    Temperature sensor 2 38°C (100°F) [0x4C] (AUXTIN)
    Temperature sensor 0 51°C (123°F) [0x31] (core #0)
    Temperature sensor 1 50°C (121°F) [0x32] (core #1)
    Temperature sensor 3 48°C (118°F) [0x34] (core #3)
    Temperature sensor 2 48°C (118°F) [0x34] (core #2)
    Temperature sensor 0 51°C (123°F) [0x33] (GPU Core)
  6. stinster
    stinster Newbie
    Intel Core 2 Duo E6550
    2GB RAM
    NVidia Geforce 8800 GT
    Windows Vista Home Premium SP1
    encoded 1442 frames, 26.00 fps, 3905.08 kb/s
    encoded 1442 frames, 26.38 fps, 3905.08 kb/s
    encoded 1442 frames, 26.37 fps, 3905.08 kb/s
    encoded 1442 frames, 26.40 fps, 3905.08 kb/s
    encoded 1442 frames, 6.55 fps, 3942.92 kb/s
    encoded 1442 frames, 6.61 fps, 3942.92 kb/s
    encoded 1442 frames, 6.54 fps, 3942.92 kb/s
    encoded 1442 frames, 6.53 fps, 3942.92 kb/s
  7. fpink3
    fpink3 Newbie
    AMD4800eGigabytemobo780g
    encoded 1442 frames, 25.18 fps, 3905.08 kb/s
    encoded 1442 frames, 25.11 fps, 3905.08 kb/s
    encoded 1442 frames, 25.24 fps, 3905.08 kb/s
    encoded 1442 frames, 24.98 fps, 3905.08 kb/s
    encoded 1442 frames, 5.86 fps, 3942.92 kb/s
    encoded 1442 frames, 5.85 fps, 3942.92 kb/s
    encoded 1442 frames, 5.79 fps, 3942.92 kb/s
    encoded 1442 frames, 26.59 fps, 3889.96 kb/s
    encoded 1442 frames, 26.45 fps, 3889.96 kb/s
    encoded 1442 frames, 26.46 fps, 3889.96 kb/s
    encoded 1442 frames, 26.52 fps, 3889.96 kb/s
    encoded 1442 frames, 6.18 fps, 3953.35 kb/s
    encoded 1442 frames, 6.17 fps, 3953.35 kb/s
    System Details
    Name AMD Athlon 64 X2 4800e
    Codename
    Specification AMD Athlon(tm) Dual Core Processor 4850e
    Core Stepping
    Technology 65 nm
    Stock frequency 2500 MHz
    Core Speed 2505.5 MHz (12.5 x 200.4 MHz)
    Northbridge AMD 780G rev. 00
    Southbridge ATI SB700 rev. 00
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 357.9 MHz (CPU/7)
    Memory Type DDR2
    Memory Size 1790 MBytes
    Channels Dual
    Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001)
    max VID 1.300 V
    Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE)
    Number of threads 2
    L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
    Package Socket AM2 (940)
  8. cyberpunk2019
    cyberpunk2019 Newbie
    5400X2
    encoded 1442 frames, 30.97 fps, 3905.08 kb/s
    encoded 1442 frames, 31.12 fps, 3905.08 kb/s
    encoded 1442 frames, 31.13 fps, 3905.08 kb/s
    encoded 1442 frames, 31.04 fps, 3905.08 kb/s
    encoded 1442 frames, 7.23 fps, 3942.92 kb/s
    encoded 1442 frames, 7.22 fps, 3942.92 kb/s
    encoded 1442 frames, 32.61 fps, 3889.11 kb/s
    encoded 1442 frames, 32.73 fps, 3888.16 kb/s
    encoded 1442 frames, 32.71 fps, 3889.23 kb/s
    encoded 1442 frames, 32.68 fps, 3887.60 kb/s
    encoded 1442 frames, 7.65 fps, 3953.35 kb/s
    encoded 1442 frames, 7.65 fps, 3953.32 kb/s
    encoded 1442 frames, 7.65 fps, 3953.39 kb/s
    encoded 1442 frames, 7.65 fps, 3953.46 kb/s
    System Details
    Name AMD Athlon 64 X2 5400+
    Codename Brisbane
    Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5400+
    Core Stepping BH-G2
    Technology 65 nm
    Stock frequency 2800 MHz
    Core Speed 3087.9 MHz (14.0 x 220.6 MHz)
    Northbridge NVIDIA nForce4 rev. A3
    Southbridge NVIDIA nForce4 MCP rev. F3
    CAS# 6.0
    RAS# to CAS# 6
    RAS# Precharge 6
    Command Rate 2T
    Memory Frequency 441.1 MHz (CPU/7)
    Memory Type DDR2
    Channels Dual
    Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
    max VID 1.375 V
    Voltage sensor 0 1.46 Volts [0x5B] (CPU VCORE)
    Number of threads 2
    Temperature sensor 0 54°C (129°F) [0x36] (TMPIN0)
    Temperature sensor 1 59°C (138°F) [0x3B] (TMPIN1)
    Temperature sensor 2 34°C (93°F) [0x22] (TMPIN2)
    Temperature sensor 0 42°C (108°F) [0x16D] (core #0)
    Temperature sensor 1 41°C (104°F) [0x166] (core #1)
    Temperature sensor 0 54°C (129°F) [0x36] (GPU Core)
  9. goldfries
    goldfries www.goldfries.com
    VERY ODD how the specs were detected.
    On my overclocked test, the specs aren't found at all. The report just ends at the results.
    encoded 1442 frames, 27.72 fps, 3905.08 kb/s
    encoded 1442 frames, 28.00 fps, 3905.08 kb/s
    encoded 1442 frames, 28.06 fps, 3905.08 kb/s
    encoded 1442 frames, 28.01 fps, 3905.08 kb/s
    encoded 1442 frames, 7.41 fps, 3942.92 kb/s
    encoded 1442 frames, 7.39 fps, 3942.92 kb/s
    encoded 1442 frames, 7.40 fps, 3942.92 kb/s
    encoded 1442 frames, 31.36 fps, 3889.96 kb/s
    encoded 1442 frames, 31.18 fps, 3889.96 kb/s
    encoded 1442 frames, 8.26 fps, 3953.35 kb/s
    encoded 1442 frames, 8.28 fps, 3953.35 kb/s
    encoded 1442 frames, 8.25 fps, 3953.35 kb/s
    System Details
    Name Intel Core 2 Duo E7200
    Codename Wolfdale
    Specification Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz
    Core Stepping M0
    Technology 45 nm
    Stock frequency 2533 MHz
    Core Speed 84354.3 MHz (9.5 x 8879.4 MHz)
    FID range 6.0x - 9.5x
    Southbridge Intel 82801GB (ICH7/R) rev. A1
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 13
    Command Rate 2T
    Memory Frequency 8879.4 MHz (1:1)
    Memory Type DDR2
    Memory Size 3326 MBytes
    Windows Version Microsoft Windows Vista (6.0) Home Basic Edition Service Pack 1 (Build 6001)
    max VID 1.225 V
    Number of threads 2
    L2 cache 3072 KBytes, 12-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
    Package Socket 775 LGA (platform ID = 0h)
    Temperature sensor 0 53°C (127°F) [0x34] (core #0)
    Temperature sensor 1 52°C (125°F) [0x35] (core #1)
    Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core)
  10. Rimmer100
    Rimmer100 Newbie
    New Dell I'm Setting up
    It's the first Quad Core PC I've got my hands on so thought I would give it a little work out!
    encoded 1442 frames, 47.47 fps, 3905.42 kb/s
    encoded 1442 frames, 44.59 fps, 3905.42 kb/s
    encoded 1442 frames, 49.09 fps, 3905.42 kb/s
    encoded 1442 frames, 49.06 fps, 3905.42 kb/s
    encoded 1442 frames, 13.42 fps, 3952.85 kb/s
    encoded 1442 frames, 12.98 fps, 3952.85 kb/s
    encoded 1442 frames, 13.46 fps, 3952.85 kb/s
    encoded 1442 frames, 13.41 fps, 3952.85 kb/s
    encoded 1442 frames, 52.28 fps, 3891.55 kb/s
    encoded 1442 frames, 53.16 fps, 3891.55 kb/s
    encoded 1442 frames, 52.67 fps, 3891.55 kb/s
    encoded 1442 frames, 52.34 fps, 3891.55 kb/s
    encoded 1442 frames, 15.04 fps, 3963.43 kb/s
    encoded 1442 frames, 15.04 fps, 3963.44 kb/s
    encoded 1442 frames, 15.03 fps, 3963.43 kb/s
    encoded 1442 frames, 15.07 fps, 3963.43 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 2394.4 MHz (9.0 x 266.0 MHz)
    CAS# 6.0
    RAS# to CAS# 6
    RAS# Precharge 6
    Command Rate 2T
    Memory Frequency 399.1 MHz (2:3)
    Memory Type DDR2
    Memory Size 2046 MBytes
    max VID 1.325 V
    Voltage sensor 0 1.26 Volts [0x4F] (CPU VCORE)
    Number of threads 4
    Temperature sensor 0 87°C (188°F) [0x57] (TMPIN0)
    Temperature sensor 1 39°C (102°F) [0x27] (TMPIN1)
    Temperature sensor 2 -33°C (-29°F) [0xDE] (TMPIN2)
    Temperature sensor 0 62°C (143°F) [0x26] (core #0)
    Temperature sensor 1 62°C (143°F) [0x26] (core #1)
    Temperature sensor 3 58°C (136°F) [0x2A] (core #3)
    Temperature sensor 2 58°C (136°F) [0x2A] (core #2)
  11. Rimmer100
    Rimmer100 Newbie
    This is my normal PC. Poor thing wasn't all that happy with me making it do all this work!
    encoded 1442 frames, 9.46 fps, 3902.58 kb/s
    encoded 1442 frames, 9.48 fps, 3902.58 kb/s
    encoded 1442 frames, 2.27 fps, 3936.11 kb/s
    encoded 1442 frames, 2.28 fps, 3936.11 kb/s
    encoded 1442 frames, 9.98 fps, 3882.40 kb/s
    encoded 1442 frames, 9.99 fps, 3882.40 kb/s
    encoded 1442 frames, 2.38 fps, 3947.86 kb/s
    System Details
    Name AMD Athlon XP
    Codename Barton
    Specification AMD Athlon(tm) XP 3200+
    Core Stepping
    Technology 0.13 um
    Core Speed 2205.1 MHz (11.0 x 200.5 MHz)
    Northbridge NVIDIA nForce2 Ultra 400 rev. C1
    Southbridge NVIDIA nForce2 MCP-T rev. A4
    CAS# 2.0
    RAS# to CAS# 3
    RAS# Precharge 2
    Cycle Time (tRAS) 6
    Memory Frequency 200.5 MHz (1:1)
    Memory Type DDR
    Memory Size 1024 MBytes
    Channels Dual
    Windows Version Microsoft Windows 2000 Professional Service Pack 4 (Build 2195)
    Voltage sensor 0 1.66 Volts [0x79] (CPU Core)
    Number of threads 1
    Number of threads 1 (max 1)
    L2 cache 512 KBytes, 16-way set associative, 64-byte line size
    Package Socket A (462)
    Temperature sensor 0 55°C (130°F) [0x37] (CPU)
    Temperature sensor 1 37°C (98°F) [0x25] (SYS)
    Temperature sensor 2 53°C (127°F) [0x35] (PWM)
    Temperature sensor 0 67°C (152°F) [0x43] (GPU Core)
  12. jrspe
    jrspe Newbie
    encoded 1442 frames, 67.83 fps, 3905.42 kb/s
    encoded 1442 frames, 68.44 fps, 3905.42 kb/s
    encoded 1442 frames, 66.55 fps, 3905.42 kb/s
    encoded 1442 frames, 67.56 fps, 3905.42 kb/s
    encoded 1442 frames, 18.78 fps, 3952.85 kb/s
    encoded 1442 frames, 18.75 fps, 3952.85 kb/s
    encoded 1442 frames, 18.80 fps, 3952.85 kb/s
    encoded 1442 frames, 18.84 fps, 3952.85 kb/s
    encoded 1442 frames, 74.12 fps, 3891.55 kb/s
    encoded 1442 frames, 74.38 fps, 3891.55 kb/s
    encoded 1442 frames, 74.33 fps, 3891.55 kb/s
    encoded 1442 frames, 73.67 fps, 3891.55 kb/s
    encoded 1442 frames, 21.11 fps, 3963.43 kb/s
    encoded 1442 frames, 21.13 fps, 3963.43 kb/s
    encoded 1442 frames, 21.11 fps, 3963.44 kb/s
    encoded 1442 frames, 21.16 fps, 3963.43 kb/s
    System Details
    Name Intel Core 2 Extreme QX9770
    Codename Yorkfield
    Specification Intel(R) Core(TM)2 Extreme CPU X9770 @ 3.20GHz
    Core Stepping C1
    Technology 45 nm
    Stock frequency 3200 MHz
    Core Speed 3200.2 MHz (8.0 x 400.0 MHz)
    FID range 6.0x - 8.0x
    Northbridge Intel X48 rev. 01
    CAS# 7.0
    RAS# to CAS# 7
    RAS# Precharge 7
    Cycle Time (tRAS) 20
    Command Rate 1T
    Memory Frequency 800.1 MHz (1:2)
    Memory Type DDR3
    Memory Size 3322 MBytes
    Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001)
    max VID 1.288 V
    Number of threads 4
    L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
    Temperature sensor 0 69°C (156°F) [0x24] (core #0)
    Temperature sensor 2 69°C (156°F) [0x24] (core #2)
    Temperature sensor 1 69°C (156°F) [0x24] (core #1)
    Temperature sensor 3 69°C (156°F) [0x24] (core #3)
    Temperature sensor 0 60°C (139°F) [0x3C] (GPU Core)
  13. user47
    user47 Newbie
    encoded 1442 frames, 11.06 fps, 3905.08 kb/s
    encoded 1442 frames, 11.08 fps, 3905.08 kb/s
    encoded 1442 frames, 2.76 fps, 3942.92 kb/s
    encoded 1442 frames, 2.74 fps, 3942.92 kb/s
    encoded 1442 frames, 2.77 fps, 3942.92 kb/s
    encoded 1442 frames, 12.19 fps, 3889.96 kb/s
    encoded 1442 frames, 12.19 fps, 3888.52 kb/s
    encoded 1442 frames, 12.18 fps, 3889.96 kb/s
    encoded 1442 frames, 12.20 fps, 3889.11 kb/s
    encoded 1442 frames, 3.06 fps, 3953.35 kb/s
    encoded 1442 frames, 3.06 fps, 3953.56 kb/s
    encoded 1442 frames, 3.05 fps, 3953.35 kb/s
    System Details
    Name Intel Pentium 4
    Codename Prescott
    Specification Intel(R) Pentium(R) 4 CPU 3.00GHz
    Core Stepping D0
    Technology 90 nm
    Stock frequency 3000 MHz
    Core Speed 3150.1 MHz (15.0 x 210.0 MHz)
    Northbridge Intel i865P/PE/G/i848P rev. A2
    Southbridge Intel 82801EB (ICH5) rev. 02
    CAS# 2.5
    RAS# to CAS# 4
    RAS# Precharge 4
    Cycle Time (tRAS) 8
    Memory Frequency 210.0 MHz (1:1)
    Memory Type DDR
    Memory Size 512 MBytes
    Channels Single
    Voltage sensor 0 1.36 Volts [0x55] (CPU VCore)
    Number of threads 2
    L2 cache 1024 KBytes, 8-way set associative, 64-byte line size
    Package Socket 478 mPGA (platform ID = 2h)
    Temperature sensor 0 43°C (109°F) [0x2B] (SYSTIN)
    Temperature sensor 1 73°C (162°F) [0x91] (CPUTIN)
    Temperature sensor 2 47°C (116°F) [0x1A2] (VTIN)
  14. Kurth
    Kurth Newbie
    encoded 1442 frames, 21.30 fps, 3905.08 kb/s
    encoded 1442 frames, 21.61 fps, 3905.08 kb/s
    encoded 1442 frames, 21.57 fps, 3905.08 kb/s
    encoded 1442 frames, 21.58 fps, 3905.08 kb/s
    encoded 1442 frames, 4.95 fps, 3942.92 kb/s
    encoded 1442 frames, 4.96 fps, 3942.92 kb/s
    encoded 1442 frames, 4.97 fps, 3942.92 kb/s
    encoded 1442 frames, 22.56 fps, 3886.14 kb/s
    encoded 1442 frames, 22.59 fps, 3886.94 kb/s
    encoded 1442 frames, 22.63 fps, 3887.60 kb/s
    encoded 1442 frames, 22.58 fps, 3887.35 kb/s
    encoded 1442 frames, 5.25 fps, 3955.27 kb/s
    encoded 1442 frames, 5.26 fps, 3953.47 kb/s
    encoded 1442 frames, 5.25 fps, 3953.46 kb/s
    encoded 1442 frames, 5.26 fps, 3953.17 kb/s
    System Details
    Name AMD Athlon 64 X2 4000+
    Codename Brisbane
    Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
    Core Stepping BH-G1
    Technology 65 nm
    Stock frequency 2100 MHz
    Core Speed 2110.9 MHz (10.5 x 201.0 MHz)
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 301.6 MHz (CPU/7)
    Memory Type DDR2
    Channels Dual
    max VID 1.350 V
    Number of threads 2
    Temperature sensor 0 40°C (103°F) [0x28] (TMPIN0)
    Temperature sensor 1 26°C (78°F) [0x1A] (TMPIN1)
    Temperature sensor 2 25°C (76°F) [0x19] (TMPIN2)
    Temperature sensor 0 20°C (68°F) [0x115] (core #0)
    Temperature sensor 1 18°C (63°F) [0x10A] (core #1)
    Temperature sensor 0 41°C (105°F) [0x29] (GPU Core)
  15. kpfong
    kpfong Newbie
    encoded 1442 frames, 55.45 fps, 3904.67 kb/s
    encoded 1442 frames, 54.57 fps, 3904.67 kb/s
    encoded 1442 frames, 54.44 fps, 3904.67 kb/s
    encoded 1442 frames, 55.89 fps, 3904.67 kb/s
    encoded 1442 frames, 15.62 fps, 3952.97 kb/s
    encoded 1442 frames, 15.66 fps, 3952.97 kb/s
    encoded 1442 frames, 15.68 fps, 3952.97 kb/s
    encoded 1442 frames, 59.22 fps, 3886.77 kb/s
    encoded 1442 frames, 59.57 fps, 3891.55 kb/s
    encoded 1442 frames, 59.72 fps, 3887.46 kb/s
    encoded 1442 frames, 59.30 fps, 3889.14 kb/s
    encoded 1442 frames, 17.61 fps, 3963.18 kb/s
    encoded 1442 frames, 17.63 fps, 3963.44 kb/s
    encoded 1442 frames, 17.61 fps, 3963.30 kb/s
    encoded 1442 frames, 17.68 fps, 3962.74 kb/s
    System Details
    Name Intel Core 2 Quad Q9450
    Codename Yorkfield
    Specification Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
    Core Stepping C1
    Technology 45 nm
    Core Speed 2659.7 MHz (8.0 x 332.5 MHz)
    Northbridge Intel Q35 rev. A2
    Southbridge Intel 82801IH (ICH9DH) rev. 02
    CAS# 6.0
    RAS# to CAS# 6
    RAS# Precharge 6
    Command Rate 2T
    Memory Frequency 399.0 MHz (5:6)
    Memory Type DDR2
    Memory Size 3062 MBytes
    max VID 1.250 V
    Number of threads 4
  16. MurFy
    MurFy Newbie
    System Details
    Name Intel Core 2 Quad Q9550
    Codename Yorkfield
    Specification Intel(R) Core(TM)2 Quad CPU [email protected]
    Core Stepping C1
    Technology 45 nm
    Stock frequency 2833 MHz
    Core Speed 4002.7 MHz (8.5 x 471 MHz)
    FID range 6.0x - 8.5x
    Northbridge Intel P45 rev. A2
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 471 MHz (1:1)
    Memory Type DDR2
    Memory Size 4096 MBytes
    Results:
    Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) (64bit)
    encoded 1442 frames, 80.38 fps, 3905.42 kb/s
    encoded 1442 frames, 81.16 fps, 3905.42 kb/s
    encoded 1442 frames, 80.94 fps, 3905.42 kb/s
    encoded 1442 frames, 81.23 fps, 3905.42 kb/s
    encoded 1442 frames, 23.56 fps, 3952.85 kb/s
    encoded 1442 frames, 23.59 fps, 3952.85 kb/s
    encoded 1442 frames, 23.55 fps, 3952.85 kb/s
    encoded 1442 frames, 87.37 fps, 3889.41 kb/s
    encoded 1442 frames, 87.45 fps, 3887.80 kb/s
    encoded 1442 frames, 87.37 fps, 3891.55 kb/s
    encoded 1442 frames, 86.96 fps, 3891.55 kb/s
    encoded 1442 frames, 26.36 fps, 3962.60 kb/s
    encoded 1442 frames, 26.39 fps, 3963.37 kb/s
    encoded 1442 frames, 26.29 fps, 3963.44 kb/s
    encoded 1442 frames, 26.29 fps, 3963.43 kb/s
    encoded 1442 frames, 82.03 fps, 3905.42 kb/s
    encoded 1442 frames, 84.20 fps, 3905.42 kb/s
    encoded 1442 frames, 83.52 fps, 3905.42 kb/s
    encoded 1442 frames, 83.75 fps, 3905.42 kb/s
    encoded 1442 frames, 23.66 fps, 3952.85 kb/s
    encoded 1442 frames, 23.71 fps, 3952.85 kb/s
    encoded 1442 frames, 23.65 fps, 3952.85 kb/s
    encoded 1442 frames, 90.31 fps, 3889.34 kb/s
    encoded 1442 frames, 91.02 fps, 3889.21 kb/s
    encoded 1442 frames, 90.75 fps, 3889.28 kb/s
    encoded 1442 frames, 90.74 fps, 3889.29 kb/s
    encoded 1442 frames, 26.63 fps, 3962.64 kb/s
    encoded 1442 frames, 26.60 fps, 3962.65 kb/s
    encoded 1442 frames, 26.64 fps, 3962.59 kb/s
    encoded 1442 frames, 26.59 fps, 3962.74 kb/s
  17. MurFy
    MurFy Newbie
    I'd like to put in a request:
    Can you make the benchmark easy so that we can import the latest builds of x264.exe for testing?
    Earlier I tried 264.exe version 987, renamed it to 817 and substituted it into the test folder, but it didn't work.
  18. Adrian Wong
    Substituted? You cannot just replace the executable.
    It's really quite easy. Just delete the folder and extract the files out to a new folder.
  19. owcraftsman
    owcraftsman Newbie
    I use a 780i A1 mobo e8400 @ 4.00 w/4x1GB dominators 9800GX2 Vista Ultimate x64 Sp1 UAC always disabled OS resides on C:\ and ProgramFilesDir on E:\ All current updates and drivers
    I downloaded and ran Avisynth_257.exe (Standard Install)
    Extracted x264_Benchmark_HD_v2.0.rar to a folder
    3 files and one folder appear within the new folder:
    • Test (folder)
    • Instructions and details @ TechARP
    • Link to download Avisynth
    • x264_benchmark-720p.vbs
    DBl clicked x264_benchmark-720p.vbs
    A cmd prompt window appears and says:
    Attention: Avisynth 2.5.7 not found on this machine.
    In that order
    Since that I have tried to run the Avisynth_257.exe as adminstrator and gone in to properties and unblocked still no joy
    I searched the All programs list and found the AviSynth 2.5 folder no exe to start and run it is there.
    Re-Installed still no joy I assume by the instruction this runs in the background but since it's not working for me I went poking around.
    I searched the C:\Program Files (x86)\AviSynth 2.5 folder for an exe again no joy.
    Please advise what I could be doing wrong.
  20. MurFy
    MurFy Newbie
    That doesn't explain how I can use the latest x264.exe to work in this benchmark. The .vbs and .bat files call on "x264-747.exe" and "x264-819.exe" in the test. How can I make it call "x264-987.exe" instead of 819?
    Try 2.5.8 RC. It also worked for me. Also install for all users.
    h**p:// sourceforge.net/project/showfiles.php?group_id=57023]SourceForge.net: Files
