Well there is no .exe to run (or see) in the Avisynth 2.5 folder. I believe core files are also stored somewhere in the Windows (sub)folders. I don't know why avisynth is not running for you. Sorry, can't help there. Perhaps ask the guys on Doom9, plenty of avisynth nuts to be found there h**p:// forum.doom9.org/forumdisplay.php?s=&forumid=33]Avisynth Usage - Doom9's Forum
I had the same problem and found it was because I had installed it to a Programs folder on a non-"C:" partition.When I ran the install with default options to C: it ran fine. Hope this helps and GL.
x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 62.81 fps, 3905.42 kb/s encoded 1442 frames, 63.55 fps, 3905.42 kb/s encoded 1442 frames, 64.08 fps, 3905.42 kb/s encoded 1442 frames, 63.44 fps, 3905.42 kb/s encoded 1442 frames, 16.23 fps, 3952.85 kb/s encoded 1442 frames, 16.24 fps, 3952.85 kb/s encoded 1442 frames, 16.29 fps, 3952.85 kb/s encoded 1442 frames, 16.21 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 65.09 fps, 3891.55 kb/s encoded 1442 frames, 65.40 fps, 3891.55 kb/s encoded 1442 frames, 65.40 fps, 3891.55 kb/s encoded 1442 frames, 65.27 fps, 3891.55 kb/s encoded 1442 frames, 17.35 fps, 3963.44 kb/s encoded 1442 frames, 17.39 fps, 3963.43 kb/s encoded 1442 frames, 17.42 fps, 3963.43 kb/s encoded 1442 frames, 17.41 fps, 3963.42 kb/s System Details -------------- Name AMD Phenom X4 9950 Black Edition Codename Agena Specification AMD Phenom(tm) 9950 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Core Speed 3194.9 MHz (15.0 x 213.0 MHz) Northbridge NVIDIA SPP190 (C51XE) rev. A2 Southbridge NVIDIA nForce 570 SLI rev. A2 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 426.0 MHz (1:2) Memory Type DDR2 Memory Size 7678 MBytes Channels Dual (Ganged) Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001) Voltage sensor 0 1.47 Volts [0x5C] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 83°C (181°F) [0x53] (TMPIN0) Temperature sensor 1 60°C (139°F) [0x3C] (TMPIN1) Temperature sensor 0 60°C (139°F) [0x1DC] (core #0) Temperature sensor 1 60°C (139°F) [0x1DC] (core #1) Temperature sensor 2 60°C (139°F) [0x1E0] (core #2) Temperature sensor 3 60°C (139°F) [0x1E0] (core #3) Temperature sensor 0 68°C (154°F) [0x44] (GPU Core) Temperature sensor 0 68°C (154°F) [0x44] (GPU Core)
My results on my q9650 at 4ghz Results for x264.exe v0.58.747 encoded 1442 frames, 79.89 fps, 3904.67 kb/s encoded 1442 frames, 81.08 fps, 3904.67 kb/s encoded 1442 frames, 79.48 fps, 3904.67 kb/s encoded 1442 frames, 80.38 fps, 3904.67 kb/s encoded 1442 frames, 23.56 fps, 3952.97 kb/s encoded 1442 frames, 23.61 fps, 3952.97 kb/s encoded 1442 frames, 23.63 fps, 3952.97 kb/s encoded 1442 frames, 23.56 fps, 3952.97 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 86.23 fps, 3889.34 kb/s encoded 1442 frames, 86.47 fps, 3889.34 kb/s encoded 1442 frames, 86.39 fps, 3889.34 kb/s encoded 1442 frames, 86.47 fps, 3889.34 kb/s encoded 1442 frames, 26.49 fps, 3962.75 kb/s encoded 1442 frames, 26.45 fps, 3962.75 kb/s encoded 1442 frames, 26.38 fps, 3962.75 kb/s encoded 1442 frames, 26.49 fps, 3962.76 kb/s System Details -------------- Name Intel Core 2 Quad Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz Core Stepping E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 4050.2 MHz (9.0 x 450.0 MHz) FID range 6.0x - 9.0x Northbridge Intel X48 rev. 01 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 450.0 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.238 V Voltage sensor 0 1.32 Volts [0xA5] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 33°C (91°F) [0x21] (SYSTIN) Temperature sensor 1 43°C (109°F) [0x56] (CPUTIN) Temperature sensor 2 36°C (95°F) [0x47] (AUXTIN) Temperature sensor 0 60°C (139°F) [0x2D] (core #0) Temperature sensor 1 58°C (136°F) [0x2F] (core #1) Temperature sensor 2 58°C (136°F) [0x2F] (core #2) Temperature sensor 3 61°C (141°F) [0x2C] (core #3) Temperature sensor 0 65°C (148°F) [0x40] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 26.94 fps, 3905.08 kb/s encoded 1442 frames, 26.99 fps, 3905.08 kb/s encoded 1442 frames, 26.92 fps, 3905.08 kb/s encoded 1442 frames, 26.91 fps, 3905.08 kb/s encoded 1442 frames, 6.17 fps, 3942.92 kb/s encoded 1442 frames, 6.17 fps, 3942.92 kb/s encoded 1442 frames, 6.18 fps, 3942.92 kb/s encoded 1442 frames, 6.17 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 28.12 fps, 3888.08 kb/s encoded 1442 frames, 28.21 fps, 3888.46 kb/s encoded 1442 frames, 28.11 fps, 3889.32 kb/s encoded 1442 frames, 28.11 fps, 3889.96 kb/s encoded 1442 frames, 6.50 fps, 3954.65 kb/s encoded 1442 frames, 6.49 fps, 3953.47 kb/s encoded 1442 frames, 6.50 fps, 3953.30 kb/s encoded 1442 frames, 6.49 fps, 3953.35 kb/s System Details -------------- Name AMD Athlon 64 X2 5000+ Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ Core Stepping BH-G2 Technology 65 nm Stock frequency 5000 MHz Core Speed 2600.1 MHz (13.0 x 200.0 MHz) Northbridge NVIDIA ID0754 rev. A2 Southbridge NVIDIA ID075C rev. A2 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 371.4 MHz (CPU/7) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) max VID 1.375 V Voltage sensor 0 1.38 Volts [0xAC] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940) Temperature sensor 0 42°C (107°F) [0x2A] (SYSTIN) Temperature sensor 1 69°C (155°F) [0x89] (CPUTIN) Temperature sensor 2 52°C (124°F) [0x67] (AUXTIN) Temperature sensor 0 47°C (116°F) [0x17F] (core #0) Temperature sensor 1 47°C (116°F) [0x180] (core #1) Temperature sensor 0 70°C (157°F) [0x46] (GPU Core)
x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 88.28 fps, 3905.23 kb/s encoded 1442 frames, 89.57 fps, 3905.23 kb/s encoded 1442 frames, 89.65 fps, 3905.23 kb/s encoded 1442 frames, 89.39 fps, 3905.23 kb/s encoded 1442 frames, 25.37 fps, 3952.94 kb/s encoded 1442 frames, 25.42 fps, 3952.94 kb/s encoded 1442 frames, 25.41 fps, 3952.94 kb/s encoded 1442 frames, 25.31 fps, 3952.94 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 96.58 fps, 3891.41 kb/s encoded 1442 frames, 97.09 fps, 3889.36 kb/s encoded 1442 frames, 96.99 fps, 3891.41 kb/s encoded 1442 frames, 96.79 fps, 3891.41 kb/s encoded 1442 frames, 28.47 fps, 3962.86 kb/s encoded 1442 frames, 28.45 fps, 3962.68 kb/s encoded 1442 frames, 28.39 fps, 3962.86 kb/s encoded 1442 frames, 28.38 fps, 3962.86 kb/s System Details -------------- Name Intel Core 2 Quad Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz Core Stepping E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 4275.2 MHz (9.0 x 475.0 MHz) FID range 6.0x - 9.0x Northbridge Intel P45 rev. A2 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 570.0 MHz (5:6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric)
Results for x264.exe v0.58.747 encoded 1442 frames, 20.46 fps, 3905.08 kb/s encoded 1442 frames, 19.05 fps, 3905.08 kb/s encoded 1442 frames, 17.80 fps, 3905.08 kb/s encoded 1442 frames, 19.22 fps, 3905.08 kb/s encoded 1442 frames, 4.60 fps, 3942.92 kb/s encoded 1442 frames, 4.46 fps, 3942.92 kb/s encoded 1442 frames, 4.33 fps, 3942.92 kb/s encoded 1442 frames, 4.39 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 20.49 fps, 3889.96 kb/s encoded 1442 frames, 18.38 fps, 3889.96 kb/s encoded 1442 frames, 20.43 fps, 3889.96 kb/s encoded 1442 frames, 19.48 fps, 3889.96 kb/s encoded 1442 frames, 4.78 fps, 3953.35 kb/s encoded 1442 frames, 4.71 fps, 3953.35 kb/s encoded 1442 frames, 4.67 fps, 3953.35 kb/s encoded 1442 frames, 4.69 fps, 3953.35 kb/s System Details -------------- Name AMD Turion X2 Ultra ZM-80 Codename Griffin Specification AMD Turion(tm) X2 Ultra Dual-Core Mobile ZM-80 Core Stepping Technology 65 nm Stock frequency 2100 MHz Core Speed 524.8 MHz (2.63 x 199.9 MHz) FID range 5.0x - 6.5x Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 333.2 MHz (3:5) Memory Type DDR2 Memory Size 2814 MBytes Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket S1 (638) Package Type 0x2 Temperature sensor 0 95°C (202°F) [0x2F6] (core #0) Temperature sensor 1 95°C (202°F) [0x2F5] (core #1)
Dell XPS M1330 (C2D 1.66 Ghz) Results for x264.exe v0.58.747 encoded 1442 frames, 18.12 fps, 3905.08 kb/s encoded 1442 frames, 18.18 fps, 3905.08 kb/s encoded 1442 frames, 18.35 fps, 3905.08 kb/s encoded 1442 frames, 18.39 fps, 3905.08 kb/s encoded 1442 frames, 4.58 fps, 3942.92 kb/s encoded 1442 frames, 4.60 fps, 3942.92 kb/s encoded 1442 frames, 4.60 fps, 3942.92 kb/s encoded 1442 frames, 4.57 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 20.30 fps, 3889.96 kb/s encoded 1442 frames, 19.90 fps, 3889.96 kb/s encoded 1442 frames, 19.87 fps, 3889.96 kb/s encoded 1442 frames, 20.07 fps, 3889.96 kb/s encoded 1442 frames, 5.09 fps, 3953.35 kb/s encoded 1442 frames, 5.08 fps, 3953.35 kb/s encoded 1442 frames, 5.08 fps, 3953.35 kb/s encoded 1442 frames, 5.09 fps, 3953.35 kb/s System Details -------------- Name Intel Mobile Core 2 Duo T5500 Codename Merom Specification Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz Core Stepping M0 Technology 65 nm Stock frequency 1666 MHz Core Speed 1662.5 MHz (10.0 x 166.2 MHz) FID range 6.0x - 10.0x Northbridge Intel GM965 rev. C0 Southbridge Intel 82801HBM (ICH8-ME) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Memory Frequency 332.5 MHz (1:2) Memory Type DDR2 Memory Size 4086 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.363 V Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket P (478) (platform ID = 7h) Temperature sensor 0 70°C (157°F) [0xF] (core #0) Temperature sensor 1 77°C (170°F) [0x8] (core #1)
OC Pentium D 805 (20x177) 3.4 Ghz Results for x264.exe v0.58.747 encoded 1442 frames, 18.99 fps, 3905.08 kb/s encoded 1442 frames, 19.12 fps, 3905.08 kb/s encoded 1442 frames, 19.16 fps, 3905.08 kb/s encoded 1442 frames, 19.15 fps, 3905.08 kb/s encoded 1442 frames, 4.74 fps, 3942.92 kb/s encoded 1442 frames, 4.77 fps, 3942.92 kb/s encoded 1442 frames, 4.77 fps, 3942.92 kb/s encoded 1442 frames, 4.76 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 21.55 fps, 3887.74 kb/s encoded 1442 frames, 21.52 fps, 3889.96 kb/s encoded 1442 frames, 21.55 fps, 3889.23 kb/s encoded 1442 frames, 21.58 fps, 3888.26 kb/s encoded 1442 frames, 5.33 fps, 3955.32 kb/s encoded 1442 frames, 5.33 fps, 3953.35 kb/s encoded 1442 frames, 5.33 fps, 3953.39 kb/s encoded 1442 frames, 5.33 fps, 3954.63 kb/s System Details -------------- Name Intel Pentium D 805 Codename SmithField Specification Intel(R) Pentium(R) D CPU 2.66GHz Core Stepping B0 Technology 90 nm Stock frequency 2666 MHz Core Speed 3400.0 MHz (20.0 x 170.0 MHz) Northbridge NVIDIA nForce4 SLI Intel Edition rev. A1 Southbridge NVIDIA nForce4 MCP rev. A3 CAS# 5.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 16 Memory Frequency 340.0 MHz (1:2) Memory Type DDR2 Memory Size 1024 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Voltage sensor 0 1.34 Volts [0x86] (CPU Core) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 66°C (150°F) [0x42] (CPU) Temperature sensor 1 35°C (94°F) [0x23] (SYS) Temperature sensor 2 71°C (159°F) [0x47] (PWM) Temperature sensor 0 55°C (130°F) [0x37] (GPU Core)
Toshiba Qosmio F40 ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 24.82 fps, 3905.08 kb/s encoded 1442 frames, 24.29 fps, 3905.08 kb/s encoded 1442 frames, 24.60 fps, 3905.08 kb/s encoded 1442 frames, 24.71 fps, 3905.08 kb/s encoded 1442 frames, 6.19 fps, 3942.92 kb/s encoded 1442 frames, 6.19 fps, 3942.92 kb/s encoded 1442 frames, 6.20 fps, 3942.92 kb/s encoded 1442 frames, 6.18 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 27.67 fps, 3889.96 kb/s encoded 1442 frames, 27.65 fps, 3889.96 kb/s encoded 1442 frames, 27.26 fps, 3889.96 kb/s encoded 1442 frames, 27.28 fps, 3889.96 kb/s encoded 1442 frames, 6.95 fps, 3953.35 kb/s encoded 1442 frames, 6.90 fps, 3953.35 kb/s encoded 1442 frames, 6.95 fps, 3953.35 kb/s encoded 1442 frames, 6.92 fps, 3953.35 kb/s System Details -------------- Name Intel Mobile Core 2 Duo T7500 Codename Merom Specification Intel(R) Core(TM)2 Duo CPU T7500 @ 2.20GHz Core Stepping E1 Technology 65 nm Stock frequency 2200 MHz Core Speed 2194.5 MHz (11.0 x 199.5 MHz) FID range 6.0x - 11.0x Northbridge Intel PM965 rev. C0 Southbridge Intel 82801HBM (ICH8-ME) rev. 03 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Memory Frequency 332.5 MHz (3:5) Memory Type DDR2 Memory Size 2046 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001) max VID 1.325 V Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket P (478) (platform ID = 7h)
Intel D945GCLF2 with atom A330 Hyperthreading enable: ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 11.34 fps, 3905.42 kb/s encoded 1442 frames, 11.36 fps, 3905.42 kb/s encoded 1442 frames, 11.39 fps, 3905.42 kb/s encoded 1442 frames, 11.36 fps, 3905.42 kb/s encoded 1442 frames, 2.82 fps, 3952.85 kb/s encoded 1442 frames, 2.82 fps, 3952.85 kb/s encoded 1442 frames, 2.86 fps, 3952.85 kb/s encoded 1442 frames, 2.83 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 12.17 fps, 3891.55 kb/s encoded 1442 frames, 12.11 fps, 3891.55 kb/s encoded 1442 frames, 12.28 fps, 3889.52 kb/s encoded 1442 frames, 12.39 fps, 3891.55 kb/s encoded 1442 frames, 3.10 fps, 3963.44 kb/s encoded 1442 frames, 3.10 fps, 3963.43 kb/s encoded 1442 frames, 3.12 fps, 3962.64 kb/s encoded 1442 frames, 3.13 fps, 3963.43 kb/s System Details -------------- Name Intel Atom 330 Codename Diamondville Specification Intel(R) Atom(TM) CPU 330 @ 1.60GHz (Engineering Sample) Core Stepping C0 Technology 45 nm Stock frequency 1600 MHz Core Speed 1600.4 MHz (12.0 x 133.4 MHz) Northbridge Intel i945G/GZ rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# 4.0 RAS# to CAS# 4 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 RAS# Precharge 4 RAS# Precharge 3 4 5 Cycle Time (tRAS) 12 Memory Frequency 266.7 MHz (1:2) Memory Type DDR2 Memory Size 2048 MBytes Channels Single Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) Voltage sensor 0 2.54 Volts [0xC3] (+2.5V) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 512 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 437 FCBGA8 (platform ID = 3h) Temperature sensor 0 53°C (127°F) [0x35] (Diode 1) Temperature sensor 1 35°C (94°F) [0x23] (Ambient) Temperature sensor 2 42°C (107°F) [0x2A] (Diode 2) Temperature sensor 1 24°C (75°F) [0x51] (Core #1) *********************************************** Hyper-threading disable: ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 8.22 fps, 3905.08 kb/s encoded 1442 frames, 8.16 fps, 3905.08 kb/s encoded 1442 frames, 8.12 fps, 3905.08 kb/s encoded 1442 frames, 8.16 fps, 3905.08 kb/s encoded 1442 frames, 2.07 fps, 3942.92 kb/s encoded 1442 frames, 2.09 fps, 3942.92 kb/s encoded 1442 frames, 2.08 fps, 3942.92 kb/s encoded 1442 frames, 2.05 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 8.81 fps, 3889.96 kb/s encoded 1442 frames, 8.79 fps, 3889.96 kb/s encoded 1442 frames, 8.79 fps, 3889.96 kb/s encoded 1442 frames, 8.73 fps, 3889.96 kb/s encoded 1442 frames, 2.27 fps, 3953.35 kb/s encoded 1442 frames, 2.27 fps, 3953.35 kb/s encoded 1442 frames, 2.28 fps, 3953.35 kb/s encoded 1442 frames, 2.26 fps, 3953.35 kb/s System Details -------------- Name Intel Atom 330 Codename Diamondville Specification Intel(R) Atom(TM) CPU 330 @ 1.60GHz (Engineering Sample) Core Stepping C0 Technology 45 nm Stock frequency 1600 MHz Core Speed 1596.2 MHz (12.0 x 133.0 MHz) Northbridge Intel i945G/GZ rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# 4.0 RAS# to CAS# 4 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 RAS# Precharge 4 RAS# Precharge 3 4 5 Cycle Time (tRAS) 12 Memory Frequency 266.0 MHz (1:2) Memory Type DDR2 Memory Size 2048 MBytes Channels Single Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) Voltage sensor 0 2.54 Volts [0xC3] (+2.5V) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 437 FCBGA8 (platform ID = 3h) Temperature sensor 0 51°C (123°F) [0x33] (Diode 1) Temperature sensor 1 34°C (93°F) [0x22] (Ambient) Temperature sensor 2 42°C (107°F) [0x2A] (Diode 2) Temperature sensor 1 21°C (69°F) [0x54] (Core #1)
Results for x264.exe v0.58.747 encoded 1442 frames, 95.14 fps, 3904.94 kb/s encoded 1442 frames, 99.45 fps, 3904.94 kb/s encoded 1442 frames, 100.21 fps, 3904.94 kb/s encoded 1442 frames, 100.64 fps, 3904.94 kb/s encoded 1442 frames, 33.73 fps, 3974.08 kb/s encoded 1442 frames, 33.95 fps, 3974.08 kb/s encoded 1442 frames, 33.98 fps, 3974.08 kb/s encoded 1442 frames, 33.81 fps, 3974.08 kb/s System Details -------------- Name Intel Processor Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 940 @ 2.93GHz Core Stepping Technology 45 nm Stock frequency 2933 MHz Core Speed 4004.0 MHz (22.0 x 182.0 MHz) Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1456.0 MHz () Memory Type DDR3 Memory Size 3064 MBytes Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 0.825 V Voltage sensor 0 1.40 Volts [0xAF] (CPU VCORE) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 1h) Temperature sensor 0 29°C (84°F) [0x1D] (SYSTIN) Temperature sensor 1 57°C (133°F) [0x71] (CPUTIN) Temperature sensor 2 32°C (88°F) [0x3F] (AUXTIN) Temperature sensor 0 69°C (156°F) [0x24] (core #0) Temperature sensor 1 70°C (157°F) [0x23] (core #1) Temperature sensor 2 68°C (154°F) [0x25] (core #2) Temperature sensor 3 65°C (148°F) [0x28] (core #3) Temperature sensor 0 35°C (94°F) [0x23] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 58.01 fps, 3905.42 kb/s encoded 1442 frames, 59.89 fps, 3905.42 kb/s encoded 1442 frames, 58.63 fps, 3905.42 kb/s encoded 1442 frames, 60.36 fps, 3905.42 kb/s encoded 1442 frames, 17.31 fps, 3952.85 kb/s encoded 1442 frames, 16.98 fps, 3952.85 kb/s encoded 1442 frames, 17.33 fps, 3952.85 kb/s encoded 1442 frames, 17.26 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 65.55 fps, 3889.35 kb/s encoded 1442 frames, 64.27 fps, 3891.55 kb/s encoded 1442 frames, 65.41 fps, 3891.55 kb/s encoded 1442 frames, 65.45 fps, 3889.38 kb/s encoded 1442 frames, 19.28 fps, 3963.51 kb/s encoded 1442 frames, 19.31 fps, 3963.44 kb/s encoded 1442 frames, 19.27 fps, 3963.44 kb/s encoded 1442 frames, 19.30 fps, 3962.85 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3104.5 MHz (9.0 x 344.9 MHz) FID range 6.0x - 9.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 431.2 MHz (4:5) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.325 V Voltage sensor 0 1.31 Volts [0xA4] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 39°C (102°F) [0x27] (SYSTIN) Temperature sensor 1 42°C (107°F) [0x54] (CPUTIN) Temperature sensor 2 15°C (58°F) [0x1D] (AUXTIN) Temperature sensor 0 58°C (136°F) [0x2A] (core #0) Temperature sensor 1 56°C (132°F) [0x2C] (core #1) Temperature sensor 2 50°C (121°F) [0x32] (core #2) Temperature sensor 3 49°C (120°F) [0x33] (core #3) Temperature sensor 0 51°C (123°F) [0x33] (GPU Core)
My new build...... STOCK Results for x264.exe v0.58.747 encoded 1442 frames, 60.63 fps, 3904.62 kb/s encoded 1442 frames, 61.73 fps, 3904.62 kb/s encoded 1442 frames, 61.48 fps, 3904.62 kb/s encoded 1442 frames, 61.20 fps, 3904.62 kb/s encoded 1442 frames, 16.86 fps, 3953.18 kb/s encoded 1442 frames, 16.90 fps, 3953.18 kb/s encoded 1442 frames, 16.87 fps, 3953.18 kb/s encoded 1442 frames, 16.85 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 67.02 fps, 3889.38 kb/s encoded 1442 frames, 66.78 fps, 3890.80 kb/s encoded 1442 frames, 66.68 fps, 3886.55 kb/s encoded 1442 frames, 66.92 fps, 3889.68 kb/s encoded 1442 frames, 18.95 fps, 3962.87 kb/s encoded 1442 frames, 19.00 fps, 3962.53 kb/s encoded 1442 frames, 18.97 fps, 3963.71 kb/s encoded 1442 frames, 19.01 fps, 3962.72 kb/s System Details -------------- Name Intel Xeon X3360 Codename Yorkfield Specification Intel(R) Xeon(R) CPU X3360 @ 2.83GHz Core Stepping C1 Technology 45 nm Stock frequency 2833 MHz Core Speed 2833.7 MHz (8.5 x 333.4 MHz) FID range 6.0x - 8.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IB (ICH9) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 533.4 MHz (5:8) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Media Center Edition Professional Service Pack 2 (Build 2600) max VID 1.238 V Voltage sensor 0 1.17 Volts [0x49] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 28°C (82°F) [0x1C] (CPU) Temperature sensor 1 25°C (76°F) [0x19] (System) Temperature sensor 0 45°C (112°F) [0x3C] (core #0) Temperature sensor 3 48°C (118°F) [0x39] (core #3) Temperature sensor 2 42°C (107°F) [0x3F] (core #2) Temperature sensor 1 44°C (111°F) [0x3D] (core #1) Temperature sensor 0 29°C (83°F) [0x1C] (GPU Core) @ 3.1 GHz Results for x264.exe v0.58.747 encoded 1442 frames, 67.17 fps, 3904.62 kb/s encoded 1442 frames, 67.22 fps, 3904.62 kb/s encoded 1442 frames, 67.27 fps, 3904.62 kb/s encoded 1442 frames, 67.36 fps, 3904.62 kb/s encoded 1442 frames, 18.49 fps, 3953.18 kb/s encoded 1442 frames, 18.48 fps, 3953.18 kb/s encoded 1442 frames, 18.52 fps, 3953.18 kb/s encoded 1442 frames, 18.46 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 73.19 fps, 3886.75 kb/s encoded 1442 frames, 73.07 fps, 3888.80 kb/s encoded 1442 frames, 73.19 fps, 3889.14 kb/s encoded 1442 frames, 73.36 fps, 3888.84 kb/s encoded 1442 frames, 20.78 fps, 3963.71 kb/s encoded 1442 frames, 20.83 fps, 3963.28 kb/s encoded 1442 frames, 20.82 fps, 3962.66 kb/s encoded 1442 frames, 20.81 fps, 3963.08 kb/s System Details -------------- Name Intel Xeon X3360 Codename Yorkfield Specification Intel(R) Xeon(R) CPU X3360 @ 2.83GHz Core Stepping C1 Technology 45 nm Stock frequency 2833 MHz Core Speed 3102.7 MHz (8.5 x 365.0 MHz) FID range 6.0x - 8.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IB (ICH9) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 547.5 MHz (2:3) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Media Center Edition Professional Service Pack 2 (Build 2600) max VID 1.238 V Voltage sensor 0 1.17 Volts [0x49] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 27°C (80°F) [0x1B] (CPU) Temperature sensor 1 27°C (80°F) [0x1B] (System) Temperature sensor 0 45°C (112°F) [0x3C] (core #0) Temperature sensor 3 49°C (120°F) [0x38] (core #3) Temperature sensor 1 44°C (111°F) [0x3D] (core #1) Temperature sensor 2 43°C (109°F) [0x3E] (core #2) Temperature sensor 0 29°C (84°F) [0x1D] (GPU Core) @ 3.2 GHz Results for x264.exe v0.58.747 encoded 1442 frames, 67.36 fps, 3904.62 kb/s encoded 1442 frames, 69.44 fps, 3904.62 kb/s encoded 1442 frames, 69.44 fps, 3904.62 kb/s encoded 1442 frames, 68.98 fps, 3904.62 kb/s encoded 1442 frames, 19.08 fps, 3953.18 kb/s encoded 1442 frames, 19.08 fps, 3953.18 kb/s encoded 1442 frames, 19.08 fps, 3953.18 kb/s encoded 1442 frames, 19.07 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 75.58 fps, 3887.29 kb/s encoded 1442 frames, 74.91 fps, 3887.19 kb/s encoded 1442 frames, 75.40 fps, 3888.66 kb/s encoded 1442 frames, 75.34 fps, 3889.23 kb/s encoded 1442 frames, 21.47 fps, 3963.13 kb/s encoded 1442 frames, 21.42 fps, 3963.55 kb/s encoded 1442 frames, 21.48 fps, 3963.87 kb/s encoded 1442 frames, 21.47 fps, 3962.98 kb/s System Details -------------- Name Intel Xeon X3360 Codename Yorkfield Specification Intel(R) Xeon(R) CPU X3360 @ 2.83GHz Core Stepping C1 Technology 45 nm Stock frequency 2833 MHz Core Speed 3204.5 MHz (8.5 x 377.0 MHz) FID range 6.0x - 8.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IB (ICH9) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 565.5 MHz (2:3) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Media Center Edition Professional Service Pack 2 (Build 2600) max VID 1.238 V Voltage sensor 0 1.17 Volts [0x49] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 27°C (80°F) [0x1B] (CPU) Temperature sensor 1 25°C (76°F) [0x19] (System) Temperature sensor 0 45°C (112°F) [0x3C] (core #0) Temperature sensor 3 49°C (120°F) [0x38] (core #3) Temperature sensor 2 42°C (107°F) [0x3F] (core #2) Temperature sensor 1 44°C (111°F) [0x3D] (core #1) Temperature sensor 0 28°C (82°F) [0x1C] (GPU Core)
