RunCore Introduces New RunCore Pro V 2.5" 7mm Ultra SSD
Discussion in 'News' started by Adrian Wong, Apr 15, 2012.
  1. Adrian Wong
    RunCore, a leading supplier of high-performance solid-state drives, has made their move and announced global availability of their Ultrabook SSD solutions, with their Sandforce-based 7mm Pro V Ultra SSD SATA III series Ultrabooks and other mobile applications on market.
    With only 7mm thickness this series is built to unleash the performance potential of the SATA 6Gbps interface, offering up to 525MB/s read and 525MB/s write, featuring an extreme write IOPS up to 75000, even in smallest devices of the next and upcoming generations. Key attributes include ultra-high performance, low power consumption, all combined with increased system responsiveness, high reliability, and enhanced ruggedness when compared to conventional opto-mechanical SATA hard drives.
    It easily integrates into today’s mobile and desktop platforms and features TRIM support to optimize performance over the drive’s lifespan as the ultimate Windows 7 companion. The brushed stainless steel enclosure not only adds to the aesthetical appearance but also adds to its ruggedness.
    7mm Pro V Ultra SSD SATA III series is equipped with high-speed synchronous 25nm Flash memory chips implementing DuraWrite technology, prolonging the overall product life expectancy up to 20 times over conventional solution.
    Particularly is stressful environment and under mission-critical operations these 7 mm ultra-thin solid state drives offer an ideal upgrade solution, enhancing not only system speed, longevity but also long-term shock-proof data security
    Model : RCP-V-T27XX-MCS
    Interface : SATA III
    Dimensions : 100.2mm×69.85mm×7mm
    Weight : 80g
    Capacity : 60/120/240/480GB
    Cache : None
    Flash Media : MLC
    Max. Read Speed : 560MB/s
    Max. Write Speed : 525MB/s
    4K Random Read IOPS : 50,000 IOPS
    4K Random Write IOPS : 60,000 IOPS
    Input Voltage : 5V ± 5%
    Power Consumption : 3.0W
    Idle Power Consumption : 1.65W
    MTBF : 2,000,000 Hours
    ECC : 55bits/512B sectors
    Wear-Levelling : Static and Dynamic wear-leveling algorithm based
    Operating Temperature : 0℃~﹢70℃
