Wow! Our first Sandy Bridge result!! Can we have the results at stock speed please? Thanks!! PS. BTW, what clock speed were you running the memory modules at?
Hi, Tests at stock speed can i maybe do tomorrow Memory running @ DDR3-1600 8-8-8-24-2T Will also post later Results with i5-2500K @ stock & overclocked
Hi, can´t answer your PM so i write it here.. i don´t have any documents, i bought the CPUs regular in a computer store benches will come later Regards Chris
Greetings! Here's mine, using x264 Benchmark v3.19: Full machine specs below. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 90.01 fps, 3901.21 kb/s encoded 1442 frames, 89.74 fps, 3900.68 kb/s encoded 1442 frames, 89.83 fps, 3900.68 kb/s encoded 1442 frames, 90.09 fps, 3901.21 kb/s encoded 1442 frames, 28.17 fps, 3971.03 kb/s encoded 1442 frames, 28.25 fps, 3970.65 kb/s encoded 1442 frames, 28.05 fps, 3971.80 kb/s encoded 1442 frames, 28.13 fps, 3972.12 kb/s System Details -------------- Name Intel Core i5 760 Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 3700.0 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 23 Command Rate (CR) 1T Memory Frequency 740.0 MHz (2:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 40°C (103°F) [0x28] (TMPIN2) Temperature 0 50°C (121°F) [0x31] (Core #0) Temperature 1 47°C (116°F) [0x34] (Core #1) Temperature 2 44°C (111°F) [0x37] (Core #2) Temperature 3 48°C (118°F) [0x33] (Core #3) Full machine specs: GIGABYTE GA-P55A-UD3R w/ BIOS Rev. F13 Intel Core i5-760 @ 3.7 GHz w/ Scythe Mugen 2 Rev. B Sapphire Radeon HD 5970 @ 790/1150MHz Sound Blaster X-Fi Elite Pro Transcend aXeRam 4GB DDR3 1600MHz @ 1480MHz CL8 1 x Samsung F3 500GB + 2 x Samsung F3 1TB Sony Optiarc AD-7240S Seasonic X-750 750W Cooler Master Storm Sniper Dell UltraSharp 24" U2410 Regards, Samuel
You're most welcome, Adrian! My machine is "naturally" overclocked: Turbo Boost is OFF C1E is OFF EIST is OFF Constant 3.7GHz. As for running at stock: no promises but maybe during this weekend. Regards, Samuel
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 37.61 fps, 3909.30 kb/s encoded 1442 frames, 38.45 fps, 3909.29 kb/s encoded 1442 frames, 38.28 fps, 3909.28 kb/s encoded 1442 frames, 37.27 fps, 3909.23 kb/s encoded 1442 frames, 7.42 fps, 3963.53 kb/s encoded 1442 frames, 7.53 fps, 3963.57 kb/s encoded 1442 frames, 7.58 fps, 3963.43 kb/s encoded 1442 frames, 7.60 fps, 3963.49 kb/s System Details -------------- Name AMD Athlon 64 X2 5000+ Black Edition product System Product Name Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ Core Stepping BH-G2 Technology 65 nm Stock frequency 2600 MHz Core Speed 3200.2 MHz Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 320.0 MHz (CPU/10) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (x64) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 53°C (127°F) [0x144] (Core #0) Temperature 1 57°C (134°F) [0x154] (Core #1)
update for AMD x2 5000+Black Edition stock 2600Mhz ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 31.98 fps, 3909.28 kb/s encoded 1442 frames, 33.12 fps, 3909.28 kb/s encoded 1442 frames, 32.99 fps, 3909.28 kb/s encoded 1442 frames, 32.19 fps, 3909.28 kb/s encoded 1442 frames, 6.10 fps, 3963.56 kb/s encoded 1442 frames, 6.21 fps, 3963.61 kb/s encoded 1442 frames, 6.26 fps, 3963.57 kb/s encoded 1442 frames, 6.26 fps, 3963.62 kb/s System Details -------------- Name AMD Athlon 64 X2 5000+ Black Edition product System Product Name Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ Core Stepping BH-G2 Technology 65 nm Stock frequency 2600 MHz Core Speed 2600.2 MHz Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 325.0 MHz (CPU/8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (x64) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 52°C (124°F) [0x13E] (Core #0) Temperature 1 55°C (131°F) [0x14D] (Core #1) LE Can be made a benchmark for x64 native encoding?
Six Core AMD,my new CPU Results for x264.exe r1342 -------------------------- encoded 1442 frames, 70.95 fps, 3898.70 kb/s encoded 1442 frames, 70.93 fps, 3898.70 kb/s encoded 1442 frames, 71.03 fps, 3898.70 kb/s encoded 1442 frames, 70.70 fps, 3898.70 kb/s encoded 1442 frames, 31.84 fps, 3964.14 kb/s encoded 1442 frames, 31.87 fps, 3970.57 kb/s encoded 1442 frames, 31.92 fps, 3970.44 kb/s encoded 1442 frames, 31.57 fps, 3970.33 kb/s System Details -------------- Name AMD Phenom II X6 1055T Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping PH-E0 Technology 45 nm Stock frequency 2800 MHz Core Speed 3500.1 MHz FID range 4.0x - 16.5x Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 666.7 MHz (3:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Ganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 34°C (93°F) [0x110] (Core #0) Temperature 1 34°C (93°F) [0x113] (Core #1) Temperature 2 34°C (93°F) [0x113] (Core #2) Temperature 3 35°C (94°F) [0x115] (Core #3) Temperature 4 35°C (94°F) [0x118] (Core #4) Temperature 5 35°C (95°F) [0x119] (Core #5)
Some results for a Dual X5670 setup. The difference between r1342 and r1867 is tremendous. r1867: 1st: 129.69 2nd: 63.03 Average: 96.49 r1342: 1st: 72.65 2nd: 58.34 Average: 65.5 Faster by 78%, 8% and 47%. Full Results: Results for x264.exe r1867 -------------------------- encoded 1442 frames, 128.92 fps, 3911.81 kb/s encoded 1442 frames, 129.46 fps, 3911.81 kb/s encoded 1442 frames, 130.00 fps, 3911.81 kb/s encoded 1442 frames, 130.38 fps, 3911.81 kb/s encoded 1442 frames, 63.49 fps, 3951.81 kb/s encoded 1442 frames, 63.09 fps, 3950.12 kb/s encoded 1442 frames, 63.62 fps, 3949.76 kb/s encoded 1442 frames, 63.01 fps, 3950.65 kb/s System Details -------------- Name Intel Xeon X5670 Name Intel Xeon X5670 Codename Westmere-EP Codename Westmere-EP Specification Intel(R) Xeon(R) CPU X5670 @ 2.93GHz Specification Intel(R) Xeon(R) CPU X5670 @ 2.93GHz Core Stepping B1 Core Stepping B1 Technology 32 nm Technology 32 nm Stock frequency 2933 MHz Stock frequency 2933 MHz Core Speed 2926.2 MHz Core Speed 1596.1 MHz Northbridge Intel 5500 rev. 22 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 532.0 MHz (2:8) Memory Type DDR3 Memory Size 49086 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 2 Number of threads 24 Number of threads 12 (max 32) Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x0) Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 49°C (120°F) [0x2F] (Core #0) Temperature 1 44°C (111°F) [0x34] (Core #1) Temperature 2 46°C (114°F) [0x32] (Core #2) Temperature 8 44°C (111°F) [0x34] (Core #8) Temperature 9 46°C (114°F) [0x32] (Core #9) Temperature 10 45°C (112°F) [0x33] (Core #10) Temperature 0 41°C (105°F) [0x37] (Core #0) Temperature 1 43°C (109°F) [0x35] (Core #1) Temperature 2 36°C (96°F) [0x3C] (Core #2) Temperature 8 43°C (109°F) [0x35] (Core #8) Temperature 9 40°C (103°F) [0x38] (Core #9) Temperature 10 34°C (93°F) [0x3E] (Core #10) x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 72.67 fps, 3903.51 kb/s encoded 1442 frames, 72.50 fps, 3904.26 kb/s encoded 1442 frames, 72.96 fps, 3902.79 kb/s encoded 1442 frames, 72.50 fps, 3902.42 kb/s encoded 1442 frames, 58.06 fps, 3908.10 kb/s encoded 1442 frames, 58.32 fps, 3944.61 kb/s encoded 1442 frames, 58.73 fps, 3903.27 kb/s encoded 1442 frames, 58.28 fps, 3923.46 kb/s System Details -------------- Name Intel Xeon X5670 Name Intel Xeon X5670 Codename Westmere-EP Codename Westmere-EP Specification Intel(R) Xeon(R) CPU X5670 @ 2.93GHz Specification Intel(R) Xeon(R) CPU X5670 @ 2.93GHz Core Stepping B1 Core Stepping B1 Technology 32 nm Technology 32 nm Stock frequency 2933 MHz Stock frequency 2933 MHz Core Speed 2927.3 MHz Core Speed 2927.3 MHz Northbridge Intel 5500 rev. 22 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 532.2 MHz (2:8) Memory Type DDR3 Memory Size 49086 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 2 Number of threads 24 Number of threads 12 (max 32) Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x0) Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 42°C (107°F) [0x36] (Core #0) Temperature 1 37°C (98°F) [0x3B] (Core #1) Temperature 2 40°C (103°F) [0x38] (Core #2) Temperature 8 39°C (102°F) [0x39] (Core #8) Temperature 9 37°C (98°F) [0x3B] (Core #9) Temperature 10 34°C (93°F) [0x3E] (Core #10) Temperature 0 47°C (116°F) [0x31] (Core #0) Temperature 1 46°C (114°F) [0x32] (Core #1) Temperature 2 39°C (102°F) [0x39] (Core #2) Temperature 8 43°C (109°F) [0x35] (Core #8) Temperature 9 44°C (111°F) [0x34] (Core #9) Temperature 10 36°C (96°F) [0x3C] (Core #10)
Phenom II X6 1055T Results for x264.exe r1342 -------------------------- encoded 1442 frames, 73.07 fps, 3898.70 kb/s encoded 1442 frames, 73.01 fps, 3898.70 kb/s encoded 1442 frames, 72.90 fps, 3898.70 kb/s encoded 1442 frames, 72.95 fps, 3898.70 kb/s encoded 1442 frames, 30.17 fps, 3955.65 kb/s encoded 1442 frames, 30.34 fps, 3969.41 kb/s encoded 1442 frames, 30.28 fps, 3969.86 kb/s encoded 1442 frames, 30.29 fps, 3971.77 kb/s System Details -------------- Name AMD Phenom II X6 1055T product System Product Name Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping PH-E0 Technology 45 nm Stock frequency 2800 MHz Core Speed 3220.2 MHz FID range 4.0x - 16.5x Northbridge ATI 770 rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 460.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 46°C (114°F) [0x2E] (TMPIN0) Temperature 1 33°C (91°F) [0x21] (TMPIN1) Temperature 0 32°C (89°F) [0xFF] (Core #0) Temperature 1 32°C (89°F) [0xFE] (Core #1) Temperature 2 32°C (88°F) [0xFC] (Core #2) Temperature 3 32°C (89°F) [0xFE] (Core #3) Temperature 4 32°C (89°F) [0xFE] (Core #4) Temperature 5 32°C (89°F) [0xFF] (Core #5)
Phenom_II_X2_550_unlocked_X4_B50 Results for x264.exe r1342 -------------------------- encoded 1442 frames, 63.38 fps, 3900.68 kb/s encoded 1442 frames, 64.85 fps, 3900.68 kb/s encoded 1442 frames, 63.68 fps, 3900.68 kb/s encoded 1442 frames, 64.84 fps, 3900.68 kb/s encoded 1442 frames, 17.08 fps, 3971.69 kb/s encoded 1442 frames, 16.34 fps, 3961.77 kb/s encoded 1442 frames, 17.48 fps, 3972.25 kb/s encoded 1442 frames, 17.41 fps, 3971.95 kb/s System Details -------------- Name AMD Phenom II X4 Codename Deneb Specification AMD Phenom(tm) II X4 B50 Processor Core Stepping RB-C2 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Core Speed 3100.0 MHz Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 666.7 MHz (3:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 60°C (139°F) [0x3C] (CPU) Temperature 1 58°C (136°F) [0x3A] (Mainboard) Temperature 2 41°C (105°F) [0x29] (TMPIN2) Temperature 0 60°C (139°F) [0xD04] (THRM) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
