i5 3450 @ 3,85Ghz 37x104bclk maybe the peak of this processor without overvoltage. r2200 changed to the latest r2345 Results for x264.exe r2345 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 74.14 fps, 7772.27 kb/s encoded 5906 frames, 75.23 fps, 7772.27 kb/s encoded 5906 frames, 75.55 fps, 7772.27 kb/s encoded 5906 frames, 75.25 fps, 7772.27 kb/s Pass 2 ------ encoded 5906 frames, 12.85 fps, 8005.11 kb/s encoded 5906 frames, 12.86 fps, 8005.11 kb/s encoded 5906 frames, 12.87 fps, 8005.11 kb/s encoded 5906 frames, 12.89 fps, 8005.11 kb/s System Details -------------- Name Intel Core i5 3450 product System Product Name Codename Ivy Bridge Specification Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz Core Stepping E1 Technology 22 nm Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000) Stock frequency 3100 MHz Core Speed 1664.0 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 693.4 MHz (1:5) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 36°C (96°F) [0x24] (SYSTIN) Temperature 1 51°C (122°F) [0x65] (CPUTIN) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
x264 Benchmark No Results Apologies if I am missing something obvious, but I can't get x264 Benchmark 5 to run properly. I am running Win8 and have tried it on various computers with exactly the same result, or lack thereof. I have Avisynth installed, I have UAC off. But it tells me that access is denied to Avisynth. I presume I am missing something obvious. I ran through the having trouble getting it to run instruction, as well as the running from command line ones. It gives the error: The system was unable to find the specified register key or value. And can find avisynth.dll, as well as devil.dll and says access denied to a variety of files. Any help would be appreciated!
AMD Phenom II X4 945 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 22.17 fps, 7776.34 kb/s encoded 5906 frames, 22.16 fps, 7776.34 kb/s encoded 5906 frames, 22.08 fps, 7776.34 kb/s encoded 5906 frames, 22.02 fps, 7776.34 kb/s Pass 2 ------ encoded 5906 frames, 7.17 fps, 8004.31 kb/s encoded 5906 frames, 7.17 fps, 8004.31 kb/s encoded 5906 frames, 7.14 fps, 8004.31 kb/s encoded 5906 frames, 7.17 fps, 8004.31 kb/s System Details -------------- Name AMD Phenom II X4 945 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping RB-C3 Technology 45 nm Stock frequency 3000 MHz Core Speed 800.0 MHz FID range 4.0x - 15.0x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 57°C (134°F) [0x39] (TMPIN0) Temperature 1 45°C (112°F) [0x2D] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
AMD Phenom II X4 945 @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 26.02 fps, 7753.00 kb/s encoded 11812 frames, 26.36 fps, 7753.00 kb/s encoded 11812 frames, 26.02 fps, 7752.75 kb/s encoded 11812 frames, 26.44 fps, 7753.00 kb/s Pass 2 ------ encoded 11812 frames, 6.90 fps, 8002.56 kb/s encoded 11812 frames, 6.91 fps, 8002.55 kb/s encoded 11812 frames, 6.91 fps, 8002.67 kb/s encoded 11812 frames, 6.90 fps, 8002.59 kb/s System Details -------------- Name AMD Phenom II X4 945 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping RB-C3 Technology 45 nm Stock frequency 3000 MHz Core Speed 800.0 MHz FID range 4.0x - 15.0x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 44°C (111°F) [0x2C] (TMPIN0) Temperature 1 40°C (103°F) [0x28] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
i5 3570K@4,5GHz Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 49.96 fps, 7777.89 kb/s encoded 5906 frames, 48.48 fps, 7777.89 kb/s encoded 5906 frames, 48.92 fps, 7777.89 kb/s encoded 5906 frames, 50.06 fps, 7777.89 kb/s Pass 2 ------ encoded 5906 frames, 14.57 fps, 8003.72 kb/s encoded 5906 frames, 14.57 fps, 8003.72 kb/s encoded 5906 frames, 14.44 fps, 8003.72 kb/s encoded 5906 frames, 14.46 fps, 8003.72 kb/s System Details -------------- Name Intel Core i5 3570K product System Product Name Codename Ivy Bridge Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Core Stepping E1 Technology 22 nm Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000) Stock frequency 3400 MHz Core Speed 1600.1 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (SYSTIN) Temperature 1 55°C (130°F) [0x6D] (CPUTIN) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
3570K@4,5 Ghz 64bit Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 64.14 fps, 7752.94 kb/s encoded 11812 frames, 64.57 fps, 7752.93 kb/s encoded 11812 frames, 64.34 fps, 7752.99 kb/s encoded 11812 frames, 64.29 fps, 7752.85 kb/s Pass 2 ------ encoded 11812 frames, 15.15 fps, 8002.25 kb/s encoded 11812 frames, 15.17 fps, 8002.20 kb/s encoded 11812 frames, 15.21 fps, 8002.18 kb/s encoded 11812 frames, 15.18 fps, 8002.23 kb/s
Intel Pentium E6500 @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 20.32 fps, 7752.08 kb/s encoded 11812 frames, 20.57 fps, 7752.07 kb/s encoded 11812 frames, 20.62 fps, 7752.14 kb/s encoded 11812 frames, 20.54 fps, 7751.98 kb/s Pass 2 ------ encoded 11812 frames, 3.69 fps, 8003.31 kb/s encoded 11812 frames, 3.69 fps, 8003.30 kb/s encoded 11812 frames, 3.69 fps, 8003.33 kb/s encoded 11812 frames, 3.68 fps, 8003.33 kb/s System Details -------------- Name Intel Pentium E6500 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E6500 @ 2.93GHz Core Stepping R0 Technology 45 nm Stock frequency 2933 MHz Core Speed 1596.0 MHz FID range 6.0x - 11.0x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 399.0 MHz (2:3) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0) Temperature 0 30°C (85°F) [0xBD8] (THRM)
Intel Pentium E6500 @ Win7 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 18.71 fps, 7772.23 kb/s encoded 5906 frames, 18.82 fps, 7772.23 kb/s encoded 5906 frames, 18.75 fps, 7772.23 kb/s encoded 5906 frames, 18.74 fps, 7772.23 kb/s Pass 2 ------ encoded 5906 frames, 3.65 fps, 8005.80 kb/s encoded 5906 frames, 3.66 fps, 8005.80 kb/s encoded 5906 frames, 3.66 fps, 8005.80 kb/s encoded 5906 frames, 3.66 fps, 8005.80 kb/s System Details -------------- Name Intel Pentium E6500 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E6500 @ 2.93GHz Core Stepping R0 Technology 45 nm Stock frequency 2933 MHz Core Speed 1596.0 MHz FID range 6.0x - 11.0x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 399.0 MHz (2:3) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0) Temperature 0 30°C (85°F) [0xBD8] (THRM)
My Current System ( settings ) is very slow and I need to replace it with a better performance system but I do not know exactly which way I should take ( AMD OR INTEL ) AMD with the 8 cores or INTEL with the hyper-threading. Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 20.88 fps, 7751.99 kb/s encoded 11812 frames, 20.88 fps, 7752.26 kb/s encoded 11812 frames, 20.89 fps, 7752.13 kb/s encoded 11812 frames, 20.94 fps, 7752.14 kb/s Pass 2 ------ encoded 11812 frames, 3.72 fps, 8003.25 kb/s encoded 11812 frames, 3.72 fps, 8003.26 kb/s encoded 11812 frames, 3.72 fps, 8003.27 kb/s encoded 11812 frames, 3.72 fps, 8003.26 kb/s System Details -------------- Name Intel Core 2 Duo E7500 Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz Core Stepping R0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2933 MHz Core Speed 1600.0 MHz FID range 6.0x - 11.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (2:3) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0)
AMD Phenom X3 8450 Pass 1 ------ encoded 5906 frames, 12.85 fps, 7774.08 kb/s encoded 5906 frames, 13.20 fps, 7774.08 kb/s encoded 5906 frames, 12.92 fps, 7774.08 kb/s encoded 5906 frames, 12.88 fps, 7774.08 kb/s Pass 2 ------ encoded 5906 frames, 3.54 fps, 8005.34 kb/s encoded 5906 frames, 3.53 fps, 8005.34 kb/s encoded 5906 frames, 3.54 fps, 8005.34 kb/s encoded 5906 frames, 3.51 fps, 8005.34 kb/s System Details -------------- Name AMD Phenom X3 8450 Codename Toliman Specification AMD Phenom(tm) 8450 Triple-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2100 MHz Core Speed 1047.6 MHz FID range 5.3x - 10.5x Northbridge AMD 780G rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 399.1 MHz (1:2) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows Vista (6.0) Home Premium Edition 32-bit Service Pack 2 (Build 6002) Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 81°C (177°F) [0x51] (TMPIN0)
Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 85.77 fps, 7754.21 kb/s encoded 11812 frames, 85.69 fps, 7754.31 kb/s encoded 11812 frames, 86.50 fps, 7754.13 kb/s encoded 11812 frames, 86.46 fps, 7754.34 kb/s Pass 2 ------ encoded 11812 frames, 18.81 fps, 8002.18 kb/s encoded 11812 frames, 18.97 fps, 8002.11 kb/s encoded 11812 frames, 18.92 fps, 8002.10 kb/s encoded 11812 frames, 18.92 fps, 8002.09 kb/s System Details -------------- Name Intel Processor Codename Haswell Specification Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz Specification PC3-16000 Specification PC3-14200 Specification PC3-16000 Specification PC3-14200 Core Stepping Technology 22 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3500 MHz Core Speed 800.0 MHz Northbridge Intel ID0C00 rev. 06 Southbridge Intel ID8C44 rev. 04 Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Type Memory Size 16384 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA Package (platform ID) Socket 1150 LGA (0x1) Temperature 0 39°C (102°F) [0x27] (TMPIN0) Temperature 1 37°C (98°F) [0x25] (TMPIN1) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
This is one of the best tools for testing stability on haswell/lynx point that I have come across. I will be highly recommending it among some others but Prime, IBT LinX OCCT are out. Besides real world gaming as a test for system stability (best) This program WinRAR bench, HCI Design Memtest, Cinebench R11.5, Hyper Pi, 3DM Firestrike, 3DM11, 3dmV, & PCM7 are in if you want system stability with this architecture. TY for the great work here. Anything I can do to help LMK Regards, Wayne
AMD Phenom X4 9450e ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 14.64 fps, 7776.34 kb/s encoded 5906 frames, 15.06 fps, 7776.34 kb/s encoded 5906 frames, 15.24 fps, 7776.34 kb/s encoded 5906 frames, 15.14 fps, 7776.34 kb/s Pass 2 ------ encoded 5906 frames, 4.84 fps, 8004.31 kb/s encoded 5906 frames, 4.84 fps, 8004.31 kb/s encoded 5906 frames, 4.85 fps, 8004.31 kb/s encoded 5906 frames, 4.86 fps, 8004.31 kb/s System Details -------------- Name AMD Phenom X4 9450e product System Product Name Codename Agena Specification AMD Phenom(tm) 9450e Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2100 MHz Core Speed 2099.8 MHz FID range 5.3x - 10.5x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 52°C (125°F) [0x34] (TMPIN0) Temperature 1 44°C (111°F) [0x2C] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
AMD Phenom X4 9450e @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 18.00 fps, 7752.75 kb/s encoded 11812 frames, 18.26 fps, 7752.77 kb/s encoded 11812 frames, 18.35 fps, 7752.79 kb/s encoded 11812 frames, 18.21 fps, 7753.00 kb/s Pass 2 ------ encoded 11812 frames, 4.65 fps, 8002.55 kb/s encoded 11812 frames, 4.65 fps, 8002.73 kb/s encoded 11812 frames, 4.65 fps, 8002.55 kb/s encoded 11812 frames, 4.65 fps, 8002.70 kb/s System Details -------------- Technology 65 nm Stock frequency 2100 MHz Core Speed 2100.0 MHz FID range 5.3x - 10.5x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 50°C (121°F) [0x32] (TMPIN0) Temperature 1 40°C (103°F) [0x28] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
AMD Phenom X4 9650 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 16.66 fps, 7776.34 kb/s encoded 5906 frames, 16.45 fps, 7776.34 kb/s encoded 5906 frames, 16.50 fps, 7776.34 kb/s encoded 5906 frames, 16.47 fps, 7776.34 kb/s Pass 2 ------ encoded 5906 frames, 5.31 fps, 8004.31 kb/s encoded 5906 frames, 5.31 fps, 8004.31 kb/s encoded 5906 frames, 5.30 fps, 8004.31 kb/s encoded 5906 frames, 5.31 fps, 8004.31 kb/s System Details -------------- Name AMD Phenom X4 9650 product System Product Name Codename Agena Specification AMD Phenom(tm) 9650 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2300 MHz Core Speed 2299.9 MHz FID range 5.8x - 11.5x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 56°C (132°F) [0x38] (TMPIN0) Temperature 1 43°C (109°F) [0x2B] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
AMD Phenom X4 9650 @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 20.01 fps, 7752.66 kb/s encoded 11812 frames, 19.99 fps, 7752.67 kb/s encoded 11812 frames, 19.92 fps, 7752.66 kb/s encoded 11812 frames, 20.04 fps, 7752.97 kb/s Pass 2 ------ encoded 11812 frames, 5.07 fps, 8002.72 kb/s encoded 11812 frames, 5.08 fps, 8002.75 kb/s encoded 11812 frames, 5.09 fps, 8002.72 kb/s encoded 11812 frames, 5.08 fps, 8002.70 kb/s System Details -------------- Core Speed 2299.9 MHz FID range 5.8x - 11.5x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 55°C (130°F) [0x37] (TMPIN0) Temperature 1 41°C (105°F) [0x29] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
Alienware M18xR2 - 3920XM ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 85.12 fps, 7753.93 kb/s encoded 11812 frames, 79.27 fps, 7753.89 kb/s encoded 11812 frames, 75.73 fps, 7753.72 kb/s encoded 11812 frames, 79.74 fps, 7754.04 kb/s Pass 2 ------ encoded 11812 frames, 16.63 fps, 8002.39 kb/s encoded 11812 frames, 16.62 fps, 8002.31 kb/s encoded 11812 frames, 16.63 fps, 8002.40 kb/s encoded 11812 frames, 16.64 fps, 8002.09 kb/s System Details -------------- Name Intel Core i7 Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3920XM CPU @ 2.90GHz Core Stepping E1 Technology 22 nm Stock frequency 3100 MHz Core Speed 4322.5 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel ID1E57 rev. 04 CAS# latency (CL) 12.0 RAS# to CAS# delay (tRCD) 12 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 36 Command Rate (CR) 2T Memory Frequency 1072.3 MHz (1:8) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AVX Package (platform ID) Socket 988B rPGA (0x4)
i7 3770k @ 4.3 Ghz ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 63.24 fps, 7779.52 kb/s encoded 5906 frames, 63.95 fps, 7779.52 kb/s encoded 5906 frames, 63.05 fps, 7779.52 kb/s encoded 5906 frames, 63.12 fps, 7779.52 kb/s Pass 2 ------ encoded 5906 frames, 16.55 fps, 8002.16 kb/s encoded 5906 frames, 16.58 fps, 8002.16 kb/s encoded 5906 frames, 16.58 fps, 8002.16 kb/s encoded 5906 frames, 16.45 fps, 8002.16 kb/s Test didn't report system details...sorry.
