x264 HD Benchmark 5.0
Discussion in 'Reviews & Articles' started by Adrian Wong, May 25, 2012.
  1. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5639 @ Turbo 2.4GHz
    Results for x264.exe r2200
    x264 Benchmark: 32-bit
    Pass 1
    encoded 5906 frames, 45.05 fps, 7787.14 kb/s
    encoded 5906 frames, 42.19 fps, 7787.14 kb/s
    encoded 5906 frames, 44.98 fps, 7787.14 kb/s
    encoded 5906 frames, 42.25 fps, 7787.14 kb/s
    Pass 2
    encoded 5906 frames, 11.94 fps, 8001.61 kb/s
    encoded 5906 frames, 12.21 fps, 8001.61 kb/s
    encoded 5906 frames, 12.16 fps, 8001.61 kb/s
    encoded 5906 frames, 11.86 fps, 8001.61 kb/s
    System Details
    Name Intel Xeon
    product System Product Name
    Codename Westmere-EP
    Specification Intel(R) Xeon(R) CPU L5639 @ 2.13GHz
    Specification PC3-17100
    Core Stepping B1
    Technology 32 nm
    Stock frequency 2133 MHz
    Core Speed 2402.9 MHz
    Northbridge Intel X58 rev. 13
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Command Rate (CR) 1T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 667.5 MHz (2:10)
    Memory Type DDR3
    Memory Size 12288 MBytes
    Channels Triple
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
    Number of processors 1
    Number of threads 12
    Number of threads 12 (max 32)
    L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES
    Package (platform ID) Socket 1366 LGA (0x0)
    Temperature 0 37°C (98°F) [0x25] (SYSTIN)
    Temperature 1 49°C (119°F) [0x61] (CPUTIN)
    Temperature 2 40°C (103°F) [0x50] (AUXTIN)
    Temperature 0 53°C (127°F) [0x35] (SB)
    Temperature 1 59°C (138°F) [0x3B] (NB)
    Temperature 0 39°C (102°F) [0xC270] (core)
    Temperature 0 38°C (100°F) [0xC260] (core)
    Temperature 0 37°C (97°F) [0xC248] (core)
  2. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5639 @ Turbo 2.4GHz @ x64
    x264 Benchmark: 64-bit
    Pass 1
    encoded 11812 frames, 54.70 fps, 7756.64 kb/s
    encoded 11812 frames, 54.67 fps, 7756.72 kb/s
    encoded 11812 frames, 49.79 fps, 7756.61 kb/s
    encoded 11812 frames, 50.08 fps, 7756.79 kb/s
    Pass 2
    encoded 11812 frames, 12.13 fps, 8000.28 kb/s
    encoded 11812 frames, 11.83 fps, 8000.26 kb/s
    encoded 11812 frames, 11.66 fps, 8000.33 kb/s
    encoded 11812 frames, 11.65 fps, 8000.17 kb/s
    System Details
    Name Intel Xeon
    Core Stepping B1
    Technology 32 nm
    Core Speed 2403.0 MHz
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Type DDR3
    Channels Triple
    Temperature 0 37°C (97°F) [0xC249] (core)
  3. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5639 @ 3.6GHz
    Pass 1
    encoded 5906 frames, 67.13 fps, 7787.14 kb/s
    encoded 5906 frames, 67.61 fps, 7787.14 kb/s
    encoded 5906 frames, 67.51 fps, 7787.14 kb/s
    Pass 2
    encoded 5906 frames, 18.33 fps, 8001.61 kb/s
    encoded 5906 frames, 18.29 fps, 8001.61 kb/s
    encoded 5906 frames, 18.34 fps, 8001.61 kb/s
    System Details
    Name Intel Xeon
    Core Stepping B1
    Technology 32 nm
    Core Speed 3608.1 MHz
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 801.8 MHz (2:8)
    Memory Type DDR3
    Channels Triple
    Temperature 0 38°C (100°F) [0x26] (SYSTIN)
    Temperature 1 54°C (129°F) [0x6C] (CPUTIN)
    Temperature 2 41°C (104°F) [0x51] (AUXTIN)
    Temperature 0 55°C (130°F) [0x37] (SB)
    Temperature 1 63°C (145°F) [0x3F] (NB)
    Temperature 0 42°C (106°F) [0xC298] (core)
    Temperature 0 40°C (103°F) [0xC278] (core)
    Temperature 0 38°C (99°F) [0xC25B] (core)
  4. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5639 @ 3.6GHz @ x64
    Pass 1
    encoded 11812 frames, 80.97 fps, 7756.62 kb/s
    encoded 11812 frames, 81.03 fps, 7756.78 kb/s
    encoded 11812 frames, 80.97 fps, 7756.81 kb/s
    encoded 11812 frames, 73.76 fps, 7756.68 kb/s
    Pass 2
    encoded 11812 frames, 18.18 fps, 8000.30 kb/s
    encoded 11812 frames, 18.21 fps, 8000.20 kb/s
    encoded 11812 frames, 17.64 fps, 8000.21 kb/s
    encoded 11812 frames, 17.54 fps, 8000.29 kb/s
    System Details
    Name Intel Xeon
    Core Stepping B1
    Technology 32 nm
    Core Speed 3608.3 MHz
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Type DDR3
    Channels Triple
    Temperature 1 57°C (133°F) [0x71] (CPUTIN)
    Temperature 2 41°C (105°F) [0x52] (AUXTIN)
    Temperature 0 38°C (99°F) [0xC258] (core)
  5. Question about Results
    Greetings All:
    I haven't seen anything or don't know where to look, on the 4770K results; These are my preliminary results after running the benchmark. However, keep in mind I was running programs in the background and services were running that I normally would have turned off. I usually keep stuff like this running on the first run of any software, unless it's absolutely required.
    Here is a tid-bit before posting results:
    i7-4770K @ 4.6Ghz
    ASUS MAXIMUS VI FORMULA
    G.Skill RipJaw DDR3 @ 2400 (11-11-11-31)
    Corsair 760i PSU
    Custom liquid loop w/t XSPC RayStorm Water Block & 360mm Rad
    Here are my results:
    Pass 1
    encoded 11812 frames, 97.13 fps, 7754.01 kb/s
    encoded 11812 frames, 96.78 fps, 7754.04 kb/s
    encoded 11812 frames, 98.28 fps, 7754.05 kb/s
    encoded 11812 frames, 95.99 fps, 7754.09 kb/s
    Pass 2
    encoded 11812 frames, 19.81 fps, 8002.25 kb/s
    encoded 11812 frames, 19.77 fps, 8002.26 kb/s
    encoded 11812 frames, 19.87 fps, 8002.21 kb/s
    encoded 11812 frames, 19.86 fps, 8002.20 kb/s
    How or where can I compare these against similar CPU's??
    Is this an average, below or higher benchmark? I am totally new to this software and I am really liking the "real-world" testing, less Prime95 which is strictly synthetic and on my cpu, can't run correctly; it doesn't even recognize my cpu..Not running anything that also hasn't been approved yet as you're chancing your CPU to danger.
    Thanks for the help;
    Matthew
    *edit*
    I wasn't yet aware to disable turbo... so my turbo was engaged during this testing phase. will try it without @ same settings and compare results
  6. tonyhsie
    tonyhsie Newbie
    Intel Core i7-2600 @ Turbo 3.5GHz
    Pass 1
    encoded 5906 frames, 47.72 fps, 7779.52 kb/s
    encoded 5906 frames, 48.35 fps, 7779.52 kb/s
    encoded 5906 frames, 48.03 fps, 7779.52 kb/s
    encoded 5906 frames, 47.78 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 12.88 fps, 8002.16 kb/s
    encoded 5906 frames, 12.92 fps, 8002.16 kb/s
    encoded 5906 frames, 12.93 fps, 8002.16 kb/s
    System Details
    (empty)
    copy from CPU-Z's report
    Number of cores 4 (max 8)
    Number of threads 8 (max 16)
    Name Intel Core i7 2600
    Codename Sandy Bridge
    Specification Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
    Package (platform ID) Socket 1155 LGA (0x1)
    CPUID 6.A.7
    Extended CPUID 6.2A
    Core Stepping D2
    Technology 32 nm
    TDP Limit 95 Watts
    Core Speed 3494.9 MHz
    Multiplier x Bus Speed 35.0 x 99.9 MHz
    Stock frequency 3400 MHz
  7. tonyhsie
    tonyhsie Newbie
    Intel Core i7-2600 @ Turbo 3.5GHz @ x64
    Pass 1
    encoded 11812 frames, 56.50 fps, 7753.88 kb/s
    encoded 11812 frames, 56.66 fps, 7754.14 kb/s
    encoded 11812 frames, 56.81 fps, 7754.02 kb/s
    encoded 11812 frames, 56.68 fps, 7754.01 kb/s
    Pass 2
    encoded 11812 frames, 12.81 fps, 8002.20 kb/s
    encoded 11812 frames, 12.82 fps, 8002.13 kb/s
    encoded 11812 frames, 12.81 fps, 8002.18 kb/s
    encoded 11812 frames, 12.83 fps, 8002.19 kb/s
    System Details
    (empty)
    CPUID 6.A.7
    Extended CPUID 6.2A
    Core Stepping D2
    Technology 32 nm
    TDP Limit 95 Watts
  8. (sic)Klown12
    (sic)Klown12 Newbie
    i7 4930K @ 4400Mhz
    Pass 1
    encoded 11812 frames, 121.18 fps, 7757.16 kb/s
    encoded 11812 frames, 121.00 fps, 7757.05 kb/s
    encoded 11812 frames, 120.93 fps, 7757.13 kb/s
    encoded 11812 frames, 121.35 fps, 7757.15 kb/s
    Pass 2
    encoded 11812 frames, 25.18 fps, 8000.52 kb/s
    encoded 11812 frames, 25.15 fps, 8000.53 kb/s
    encoded 11812 frames, 25.18 fps, 8000.54 kb/s
    encoded 11812 frames, 25.19 fps, 8000.42 kb/s
    System Details
    Name Intel Core i7
    Codename Ivy Bridge-E
    Specification Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
    Core Stepping
    Technology 22 nm
    Core Speed 4400.1 MHz
    Northbridge Intel ID0E00 rev. 04
    Southbridge Intel X79 rev. 06
    Memory Type DDR3 1866Mhz @ 9-10-9-28
    Memory Size 16326 MBytes
    Windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 2011 LGA (0x2)
  9. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5420
    Pass 1
    encoded 5906 frames, 22.49 fps, 7775.81 kb/s
    encoded 5906 frames, 22.51 fps, 7775.81 kb/s
    encoded 5906 frames, 22.54 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 6.08 fps, 8004.45 kb/s
    encoded 5906 frames, 6.31 fps, 8004.45 kb/s
    System Details
    Specification Intel(R) Xeon(R) CPU L5420 @ 2.50GHz
    Core Stepping E0
    Technology 45 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Stock frequency 2500 MHz
    Core Speed 1999.8 MHz
    FID range 6.0x - 7.5x
    Northbridge Intel P45/P43/G45/G43 rev. A3
    CAS# latency (CL) 6.0
    RAS# to CAS# delay (tRCD) 6
    RAS# Precharge (tRP) 6
    Cycle Time (tRAS) 18
    Command Rate (CR) 2T
    Memory Frequency 400.0 MHz (5:6)
    Memory Type DDR2
    Memory Size 8192 MBytes
    Channels Dual, (Symmetric)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
    Package (platform ID) Socket 771 LGA (0x6)
    Temperature 0 47°C (116°F) [0x2F] (TMPIN0)
    Temperature 1 41°C (105°F) [0x29] (TMPIN1)
  10. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5420 @ x64
    Pass 1
    encoded 11812 frames, 27.13 fps, 7752.38 kb/s
    encoded 11812 frames, 27.39 fps, 7752.31 kb/s
    encoded 11812 frames, 27.14 fps, 7752.39 kb/s
    encoded 11812 frames, 27.16 fps, 7752.40 kb/s
    Pass 2
    encoded 11812 frames, 6.26 fps, 8002.74 kb/s
    encoded 11812 frames, 6.25 fps, 8002.69 kb/s
    encoded 11812 frames, 6.27 fps, 8002.69 kb/s
    encoded 11812 frames, 6.26 fps, 8002.73 kb/s
    System Details
    Number of threads 4
  11. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5420 @ 3GHz
    Pass 1
    encoded 5906 frames, 26.30 fps, 7775.81 kb/s
    encoded 5906 frames, 26.43 fps, 7775.81 kb/s
    encoded 5906 frames, 26.38 fps, 7775.81 kb/s
    encoded 5906 frames, 26.53 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 7.57 fps, 8004.45 kb/s
    encoded 5906 frames, 7.55 fps, 8004.45 kb/s
    encoded 5906 frames, 7.56 fps, 8004.45 kb/s
    System Details
    Name Intel Xeon L5420
    Codename Harpertown
    Core Stepping E0
    Technology 45 nm
    Core Speed 2400.1 MHz
    Memory Frequency 400.0 MHz (1:1)
    Memory Type DDR2
    Number of threads 4
    Temperature 1 44°C (111°F) [0x2C] (TMPIN1)
  12. tonyhsie
    tonyhsie Newbie
    Intel Xeon L5420 @ 3GHz @ x64
    Pass 1
    encoded 11812 frames, 32.02 fps, 7752.29 kb/s
    encoded 11812 frames, 31.69 fps, 7752.36 kb/s
    encoded 11812 frames, 32.09 fps, 7752.27 kb/s
    encoded 11812 frames, 32.00 fps, 7752.37 kb/s
    Pass 2
    encoded 11812 frames, 7.50 fps, 8002.73 kb/s
    encoded 11812 frames, 7.50 fps, 8002.74 kb/s
    encoded 11812 frames, 7.49 fps, 8002.82 kb/s
    encoded 11812 frames, 7.49 fps, 8002.73 kb/s
    System Details
    Number of threads 4
    Temperature 1 43°C (109°F) [0x2B] (TMPIN1)
  13. heniken111
    heniken111 Newbie
    AMD FX 8350 turbo core off x264_64
    x264 HD BENCHMARK 5.0 RESULTS
    Pass 1
    encoded 11812 frames, 56.63 fps, 7753.80 kb/s
    encoded 11812 frames, 53.19 fps, 7754.06 kb/s
    encoded 11812 frames, 56.98 fps, 7754.12 kb/s
    encoded 11812 frames, 57.16 fps, 7753.82 kb/s
    Pass 2
    encoded 11812 frames, 14.80 fps, 8002.24 kb/s
    encoded 11812 frames, 13.72 fps, 8002.24 kb/s
    encoded 11812 frames, 14.82 fps, 8002.22 kb/s
    encoded 11812 frames, 14.80 fps, 8002.20 kb/s
    System Details
    Name AMD FX
    Codename Zambezi
    Specification AMD FX(tm)-8350 Eight-Core Processor
    Specification PC3-12800
    Core Stepping OR-C0
    Technology 32 nm
    Stock frequency 4000 MHz
    Core Speed 1404.7 MHz
    Northbridge AMD RD9x0 rev. 02
    Southbridge AMD SB910/950 rev. 40
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 802.7 MHz (1:4)
    Memory Type DDR3
    Channels Dual
    Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601)
    Number of threads 8
    Number of threads 8 (max 8)
    L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA
    Package Socket AM3+ (942)
    Package Type 0x1
    Temperature 0 32°C (89°F) [0x20] (CPU)
    Temperature 1 27°C (80°F) [0x1B] (Mainboard)
  14. heniken111
    heniken111 Newbie
    Core i7 4770 off turbo, x264_64
    Pass 1
    encoded 11812 frames, 67.04 fps, 7754.13 kb/s
    encoded 11812 frames, 67.29 fps, 7753.82 kb/s
    encoded 11812 frames, 68.16 fps, 7754.19 kb/s
    encoded 11812 frames, 67.86 fps, 7753.97 kb/s
    Pass 2
    encoded 11812 frames, 14.99 fps, 8002.23 kb/s
    encoded 11812 frames, 15.01 fps, 8002.26 kb/s
    encoded 11812 frames, 14.99 fps, 8002.16 kb/s
    encoded 11812 frames, 14.97 fps, 8002.25 kb/s
    System Details
    Name Intel Processor
    Codename Haswell
    Specification Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
    Core Stepping
    Technology 22 nm
    Core Speed 800.1 MHz
    Northbridge Intel ID0C00 rev. 06
    Southbridge Intel ID8C44 rev. 05
    Command Rate 2T
    Command Rate 2T
    Memory Type
    Number of threads 8
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA
    Package (platform ID) Socket 1150 LGA (0x1)
    Temperature 0 33°C (91°F) [0x21] (SYSTIN)
    Temperature 0 28°C (82°F) [0xBC2] (TZ00)
    Temperature 1 30°C (85°F) [0xBD6] (TZ01)
  15. laychi
    laychi Newbie
    [email protected],6Ghz
    Pass 1
    encoded 11812 frames, 64.50 fps, 7752.92 kb/s
    encoded 11812 frames, 66.40 fps, 7752.88 kb/s
    encoded 11812 frames, 66.34 fps, 7752.85 kb/s
    encoded 11812 frames, 66.30 fps, 7752.91 kb/s
    Pass 2
    encoded 11812 frames, 15.59 fps, 8002.22 kb/s
    encoded 11812 frames, 15.58 fps, 8002.22 kb/s
    encoded 11812 frames, 15.57 fps, 8002.24 kb/s
    encoded 11812 frames, 15.59 fps, 8002.23 kb/s
    System Details
    Name Intel Core i5 3570K
    Codename Ivy Bridge
    Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
    Core Stepping E1
    Technology 22 nm
    Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000)
    Core Speed 1600.0 MHz
    Northbridge Intel Ivy Bridge rev. 09
    Southbridge Intel Z77 rev. 04
    Memory Frequency 800.0 MHz (1:8)
    Memory Type DDR3
    Memory Size 4096 MBytes
    Channels Dual
    Number of threads 4
    Number of threads 4 (max 16)
    Temperature 0 28°C (82°F) [0x1C] (SYSTIN)
    Temperature 1 51°C (123°F) [0x66] (CPUTIN)
  16. heniken111
    heniken111 Newbie
    try one more time with 8350 off turbo
    I dont know why but my score is going up a little bit than the first test
    Pass 1
    encoded 11812 frames, 56.90 fps, 7754.08 kb/s
    encoded 11812 frames, 57.73 fps, 7753.94 kb/s
    encoded 11812 frames, 57.64 fps, 7754.06 kb/s
    encoded 11812 frames, 57.41 fps, 7754.06 kb/s
    Pass 2
    encoded 11812 frames, 14.90 fps, 8002.20 kb/s
    encoded 11812 frames, 14.30 fps, 8002.25 kb/s
    encoded 11812 frames, 14.98 fps, 8002.16 kb/s
    encoded 11812 frames, 15.00 fps, 8002.05 kb/s
    System Details
    Name AMD FX
    Codename Zambezi
    Core Stepping OR-C0
    Technology 32 nm
    Command Rate 2T
    Command Rate 2T
    Memory Type DDR3
    Channels Dual
    Number of threads 8
    Package Type 0x1
    Temperature 0 64°C (147°F) [0x40] (CPU)
    Temperature 1 30°C (85°F) [0x1E] (Mainboard)
  17. heniken111
    heniken111 Newbie
    Core i7 2600 turbo on
    Pass 1
    encoded 11812 frames, 59.57 fps, 7753.91 kb/s
    encoded 11812 frames, 59.47 fps, 7754.09 kb/s
    encoded 11812 frames, 59.56 fps, 7754.10 kb/s
    encoded 11812 frames, 59.31 fps, 7754.11 kb/s
    Pass 2
    encoded 11812 frames, 12.86 fps, 8002.26 kb/s
    encoded 11812 frames, 12.88 fps, 8002.21 kb/s
    encoded 11812 frames, 12.87 fps, 8002.15 kb/s
    encoded 11812 frames, 12.89 fps, 8002.11 kb/s
    System Details
    Channels Dual
    Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601)
    Number of threads 8
  18. tonyhsie
    tonyhsie Newbie
    Intel Core i5-520M @ Turbo 2.66GHz
    Pass 1
    encoded 5906 frames, 18.59 fps, 7775.81 kb/s
    encoded 5906 frames, 18.44 fps, 7775.81 kb/s
    encoded 5906 frames, 18.58 fps, 7775.81 kb/s
    encoded 5906 frames, 18.89 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 4.56 fps, 8004.45 kb/s
    System Details
    Name Intel Core i5 520M
    Codename Arrandale
    Specification Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz
    Core Stepping K0
    Technology 32 nm
    Stock frequency 2400 MHz
    Core Speed 2926.2 MHz
    Northbridge Intel Havendale/Clarkdale Host Bridge rev. 02
    Southbridge Intel HM55 rev. 06
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 7
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 20
    Memory Frequency 532.0 MHz (4:16)
    Memory Type DDR3
    Number of threads 4
    L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
    Package (platform ID) Socket 989 rPGA (0x4)
    Temperature 4 59°C (138°F) [0x3B] (PCH)
    Temperature 5 63°C (145°F) [0x3F] (GMCH)
    Temperature 0 64°C (147°F) [0xD2C] (TZ00)
  19. tonyhsie
    tonyhsie Newbie
    Intel Core i5-520M @ Turbo 2.66GHz @ x64
    Pass 1
    encoded 11812 frames, 22.26 fps, 7752.31 kb/s
    encoded 11812 frames, 22.07 fps, 7752.25 kb/s
    encoded 11812 frames, 22.26 fps, 7752.27 kb/s
    encoded 11812 frames, 22.23 fps, 7752.35 kb/s
    Pass 2
    encoded 11812 frames, 4.44 fps, 8002.78 kb/s
    encoded 11812 frames, 4.44 fps, 8002.79 kb/s
    encoded 11812 frames, 4.44 fps, 8002.77 kb/s
    encoded 11812 frames, 4.44 fps, 8002.74 kb/s
    System Details
    Codename Arrandale
    Core Stepping K0
    Technology 32 nm
    Memory Type DDR3
    Number of threads 4
  20. laychi
    laychi Newbie
    can anybody make a test with 4670K?
    @stock,@turbo boost,@OC(4,5 GHz) 32&64bit too.pls
    maybe i change my 3570K to this
