Desktop Graphics Card Comparison Guide
Discussion in 'Reviews & Articles' started by peaz, Mar 30, 2004.
  1. Adrian Wong
    Desktop Graphics Card Comparison Guide Rev. 29.3
    Covering 616 desktop graphics cards, this comprehensive comparison allows you to easily compare 24 different specifications for each and every card. If you need to find out about the specification of any card, just come over and check out our Desktop Graphics Comparison Guide.
    We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Here are the latest updates in Revision 29.3 :
    Link : Desktop Graphics Card Comparison Guide Rev. 29.3
    Thanks again, Blashix! :thumb:
  2. omegatotal
    omegatotal Newbie
    need to update a few cells to correctly show specs for dual GPU on single card configurations..
    like memory bandwidth should not be a total, but rather per gpu.
    same with shaders/ROPs etc.
    also consider every other row shaded ever so slightly ligher or darker
    not just the generations (700 vs titan vs 900 for example)
  3. Adrian Wong
    Thanks for the feedback, omegatotal! :thumb:
  4. Blashix
    Blashix Newbie
    Please rename gtx 960 future for gtx 960 and update spec.
  5. Adrian Wong
    Yeah, it's time to update it. Thanks for the reminder! :thumb:
  6. Adrian Wong
    Desktop Graphics Card Comparison Guide Rev. 29.4
    Here are the latest updates in Revision 29.4 :
    Link : Desktop Graphics Card Comparison Guide Rev. 29.4
  7. Blashix
    Blashix Newbie
  8. Adrian Wong
  9. Blashix
    Blashix Newbie
  10. Adrian Wong
  11. Adrian Wong
    Desktop Graphics Card Comparison Guide Rev. 29.5
    Here are the latest updates in Revision 29.5 :
    Link : Desktop Graphics Card Comparison Guide Rev. 29.5
    Thanks, Blashix! :thumb:
  12. Blashix
    Blashix Newbie
    BIG UPDATE !
    AMD RADEON
    Rename TDP: 290 for 286. -> 4870 X2
    Radeon HD 4870 X2 | VideoCardz.com
    Add HD 5630.
    ATI Radeon HD 5630 | techPowerUp GPU Database
    Add AMD Radeon HD 6230
    AMD Radeon HD 6230 | techPowerUp GPU Database
    HD 6250
    AMD Radeon HD 6250 | techPowerUp GPU Database
    add Radeon HD 6350 AMD Radeon HD 6350 | techPowerUp GPU Database
    Radeon HD 6390
    AMD Radeon HD 6390 | techPowerUp GPU Database
    HD 6930
    Radeon HD 6930 | VideoCardz.com
    AMD Radeon HD 6850 1440SP Edition
    AMD Radeon HD 6850 1440SP Edition | techPowerUp GPU Database
    AMD Radeon HD 6870 1600SP Edition
    AMD Radeon HD 6870 1600SP Edition | techPowerUp GPU Database
    AMD Radeon HD 6770 Green Edition
    AMD Radeon HD 6770 Green Edition | techPowerUp GPU Database
    AMD Radeon HD 7970 X2
    AMD Radeon HD 7970 X2 | techPowerUp GPU Database
    AMD Radeon HD 6870 X2
    AMD Radeon HD 6870 X2 | techPowerUp GPU Database
    AMD Radeon HD 6850 X2
    AMD Radeon HD 6850 X2 | techPowerUp GPU Database
    Update Date This Card:
    AMD Radeon HD 7450 OEM | techPowerUp GPU Database
    AMD Radeon HD 7350 OEM | techPowerUp GPU Database
    AMD Radeon HD 7570 | techPowerUp GPU Database
    AMD Radeon R5 240 OEM | techPowerUp GPU Database
    AMD Radeon R5 235 OEM | techPowerUp GPU Database
    AMD Radeon R5 235X OEM | techPowerUp GPU Database
    AMD Radeon R5 230 | techPowerUp GPU Database
    AMD Radeon R5 220 OEM | techPowerUp GPU Database
    GEFORCE
    Please update spec GTX 750 Ti and add memory 4 GBGraphics Cards - STRIX-GTX750TI-DC2OC-4GD5 - ASUS
    Add:
    GT 745 NVIDIA GeForce GTX 745 OEM | techPowerUp GPU Database
    560 Ti X2 NVIDIA GeForce GTX 560 Ti X2 | techPowerUp GPU Database
    460 x2 NVIDIA GeForce GTX 460 X2 | techPowerUp GPU Database
    760 x2 NVIDIA GeForce GTX 760 X2 | techPowerUp GPU Database
    780 rev2 NVIDIA GeForce GTX 780 Rev. 2 | techPowerUp GPU Database
  13. Adrian Wong
    WOW! That is a big update indeed. Thanks for the heads-up! :D
  14. Adrian Wong
    Desktop Graphics Card Comparison Guide Rev. 29.6
    Covering 628 desktop graphics cards, this comprehensive comparison allows you to easily compare 24 different specifications for each and every card. If you need to find out about the specification of any card, just come over and check out our Desktop Graphics Comparison Guide.
    Here are the latest updates in Revision 29.6 :
    Link : Desktop Graphics Card Comparison Guide Rev. 29.6
  15. Blashix
    Blashix Newbie
  16. Adrian Wong
    Sorry, was bushed yesterday. Will be updating the NVIDIA cards in the coming update. :thumb:
  17. Adrian Wong
    Desktop Graphics Card Comparison Guide Rev. 29.7
    Covering 633 desktop graphics cards, this comprehensive comparison allows you to easily compare 24 different specifications for each and every card. If you need to find out about the specification of any card, just come over and check out our Desktop Graphics Comparison Guide.
    Here are the latest updates in Revision 29.7 :
    Link : Desktop Graphics Card Comparison Guide Rev. 29.7
  18. Blashix
    Blashix Newbie
    I do not know well or R9 285X was released,
    Always count on my help.
  19. Adrian Wong
    Okay, will check them out. Thanks for the heads-up! :thumb:
  20. Blashix
    Blashix Newbie
