ANyone know have any idea why cant the dynamic ftp work ? im using bulletproof server 2.4 and no-ip . Previously works on my linksys router.... after change my router to netgear it refused to work. a help will be great thanks.
it works on direct ip .... but not dynamic I use no-ip on linksys router before and it works. Just not netgear.... too bad my linksys router fried...
yup i did download the no ip software ... i guess is the dynamic dns server have issue with my router?
Huh? What has the dynamic dns server got to do with your router? If you DNS server is getting your IP, then it's completely your router problem not port forwarding to your IP properly.
I think he's referring to his former Linksys router which has a mutual partnership programme with DYNDNS.ORG that allows users of their routers to update their IP via the embedded firmware.
LOL! I knew about the feature, but he wasn't really clear...And he did mention about using no-ip. But even then, using no-ip software should solve all his problems. The most likely issue is the no-ip software is not configured properly, or the port forwarding setting is wrong. If you are in Canada, then the no-ip software works, which leaves the port forwarding settings.
lol finally got it to work. The problem was my dns cache setting in firewall .....which will not update the IP address it uses for my server to reflect the current address given by no-ip. lol sorry for the trouble guys and thanks for helping me out.
