i want to soft-mod my nvidia geforce 8600gt 256mb to quadro. i try the guide but somthing is not clear for me. in GPU-Z my GPU is G84 and the device ID is 10DE-0402. in the nvidia nv_disp.inf file there are these equivalents: NVIDIA_G84.DEV_040A.1 = "NVIDIA Quadro FX 370" NVIDIA_G84.DEV_040D.1 = "NVIDIA Quadro FX 1600M" NVIDIA_G84.DEV_040E.1 = "NVIDIA Quadro FX 570" NVIDIA_G84.DEV_040F.1 = "NVIDIA Quadro FX 1700 which one should i use? my OS is vista 32. someone knows? 10x
I don't think there's a Quadro-equivalent of your GeForce 8600 GT. You can still try the mod though. Check the specifications of the Quadro cards to find out whic matches your GeForce 8600 GT the CLOSEST. Something like the Quadro FX 570 maybe. Most important specifications would be the GPU type (G84), the memory bus width (128-bits) and the memory type (DDR3). These links should help you : - Tech ARP - Desktop Graphics Card Comparison Guide Rev. 15.2 - Tech ARP - Workstation Graphics Card Comparison Guide Rev. 5.3
