I just bought a new Aztech USB ADSL Modem to connect to streamyx and there is some problems when I try to connect: It will display "Error 680: There was no dial tone". I connected the telephone lines properly, install it properly but when I run the DSL TEST, the INTERFACE shows green(running fine) and MODEM shows red(error) . I got the VCI and VPI parameters right as well... Which part I do wrong here?? Please help me here...
Download latest drivers. Install. If you have two RJ11 (telephone) ports, check that you didn't plug the line into the one meant for the telephone set.
ok, one question, what is the line type for standard Malaysian telephone lines? 56k voice, 56k digital or 64k digital? I hope this is the problem with my modem...
"Standard" lines are copper, but some areas are fiber-optic cable. Shouldn't matter though, unless you live in an area where there's FTTH. I hear there's FTTH in some condos. Have you tested the modem with a working line ?
Nope... maybe I should... thx for the advice! The lines at my area is copper lines... but that doesn't matter actually. What matters is the line type on the c/o side.
hey... i use that modem before, try to reinstall the driver and go into your browser url http://10.0.0.2 or http://10.0.0.1 and fill in the blanks.
O! I reinstalled it before and seems like it doesn't work. Anyway it works now! This is what I did to make it work properly yesterday: 1. Unplug and uninstall the hardware 2. Use System Restore to restore my computer to before I install the driver 3.Install driver 4. Restart computer 5. Plug the USB ADSL MODEM and let it auto-install Then it works! Thanks for all the advice that you guys give! =D
ya.. i dont like USB modem .. i had one before.. if my modem is not detected by the pc i have to restart the whole pc
