Maintenance on my bike
Discussion in 'Chai' started by Chai, Jan 17, 2017.
  1. Chai
    Your wheel will be 'dished' incorrectly if your chainstay is out of alignment. but it will still be straight. You probably need wheel dishing tool. Are you riding a carbon bike or alloy?
    I really need a hanger straightening tool, hit a rock a month ago, almost killed the derailleur (L limit screw was ripped off), and hanger was bent. But I still couldn't justify getting a RM200-300 tool for basically 1 time use. I just use a spanner to bend it back. :haha:
  2. atwl77
    atwl77 Just Started
    My bike's aluminum, but that could change anytime in the future... :whistle:
    But I think eventually I'll get at least a straightening tool... even slight misalignment can be annoying if it affects shifting and noise.
  3. Chai
    Usually it's just indexing, not hanger alignment. I'm very doubtful a road bike would have a bent hanger, even if it's alloy.
    I have ridden for more than 6 years, and I have only bent the hanger twice. Once I hit a tree jamming the rear derailleur. I had to buy a new replacement as it was in L shape literally. Another time I hit a rock really hard, but it was only slightly bent. Both are caused by heavy impact.
    If you are getting shifting noise throughout the cassette range, it's usually just indexing problem which is an easy fix. You can also eyeball whether the cassette is aligned to the derailleur cage.
  4. atwl77
    atwl77 Just Started
    Well, I had a bent hanger which the shop helped me straighten last week, not sure when that happened...
  5. Chai
    Another likely reason is due to mishandling when you transport your bike on a car, or you lean your bike on the ground on the drivetrain side. Do let me know when you buy one. I will borrow from you. :Haha:
    Sent from my E5823 using Tapatalk
  6. Chai
    Did you get the derailleur hanger alignment tool yet?
  7. atwl77
    atwl77 Just Started
    Nah, not yet. Still window shopping, lol.
  8. Chai
    Where's the best place you found so far?
