Need graphics card for OptiPlex 7010
Discussion in 'Graphics Cards & Displays' started by Tran33, Jul 5, 2020.
  1. Tran33
    Tran33 Newbie
    I need it to have an actual VGA port, as I do not want to mess with a DVI/DisplayPort adapter, and it must work with the power supply (265 W active PFC / 100 - 240 V AC). It has to be better than the integrated graphics, fit the case, and support Win 7. These cards are the closest I have found to the above requirements:
    Radeon HD 5670
    Geforce GT 703
    Are either of these compatible with the Dell Optiplex 7010 Mini-Tower Quad Core i7-3770 3.4GHz 16GB Ram 1TB Hard Drive (Windows 7 Pro 64 Bit)? If not, can you suggest ones that will meet the requirements? Thanks.
  2. Chai
    Either cards should work fine. However, you need to make sure your Dell can accept full sized graphics card. If not, you will need to get the half height cards and bracket in order to fit into your Dell.
