Are these nice coolers still sold in M'sia? I seldom find it anymore compared to last time - I just want to stick it into my old Athlon XP 2400+. Well, is it worth it? My motherboard is just a budget KM4M series and some other cheap stuff slapped into the computer. Or I could actually bring the temps down to 30 degrees?
try at lowyat.. c-zone maybe.. last time i bought SP-97 they manage to have it.. maybe they have the SI-97 too..
I'm gonna make one outta a stock A64 cooler for my toasty 6800Ultra... Choices for fans are either my 7krpm YsTech 60mm fan or the stock AMD fan...
I thought SI-97 is more common??? Anyway, I think SI-97 is a better choice because it is easier to install, lighter and has the same performance as the SP-97.
It can go as low as 30, only in an air-conditioned room though. Last i checked (it was many months ago) both of them had the same price tag.
hi Max_87, saw ur sign... u use Si-97 for ur Opteron cooler. Mind to show the picture? Wanna knw how u mount on with Si-97 non-a newbies here... hehe
Thx for the info. Actually i dont knw which section need to find the guide. I even try use the "Search" with "Si-97" also cant find the guide. But thx for showing me the link
That's because the guide is part of the main site @ http://www.rojakpot.com/. It's not hosted in these forums. Just click on the Article Database link on the menu (right on top, on the left).
