I would recommend you stay far far away from the Thermaltake one...every part of it has the makings of a lousy cooling system. I have also heard several cases of the acrylic on the waterblocks cracking. X-bit labs did a comparison of some watercooling kits recently, including the Tt and Gigabyte ones: http://www.xbitlabs.com/articles/coolers/display/16watercooling.html So out of these 2, the Gigabyte would definitely be a better choice. Although I have my own opinions about watercooling (vs air cooling) and I'm sure Chai will drop in to say something as well
it cost like err 300++ for tat money better u stay air cooling..get a scythe ninja, xp-120, xp-90 or soon coming ultra 90 n 120 from TR..it will pawned entry level watercooling but if tok about coolness having a watercooling den can go for it
humm ... well im just asking ... cause never play with watercooling before ...so just wish to try it out.
Like PowerSlide said...you buy that sort of watercooling is to look good only (and only to certain people ). If you want watercooling that's really better than air cooling, be prepared to pay.
And if you want to get that kind of system, be prepared for paying the price for not paying the price!
One good all-in-one watercooling kit is Corsair Nautilus500 External Water Cooling kit. It performs quite good.
i say dat coz im tempted to get the bigwater coz its cool to have watercooling but lucky my sanity does not happen stick to highend air or pay like 600 up for a good WC set
if you wanna have custom water cooling better to go for>Danger Den waterblocks or Vgablock,Black Ice Pro Radiator,Eheim Pump but costly$$$
Yep. It'll set you off double of what you wanted. Ehiem? Really good pump, but it's a big heat load on the loop.
gigabyte doesn't try it but thermaltake, is an entry level water cooling dun expect much... and be aware of installation. plz reminded, becareful when u want to open the water block make sure it is screw tight, when u resemble it or not, u may got a chance to smell of burning hardware
im thinking of external water cooling too....but is gonna be troublesome if i wanna move my pc around ..
