sherren..i think its about time for you to get going with your unfinished business.. benn waiting for quite a while for your update..
hahahhahah .. sherren deserves to be shot for starting the project .. posting it ... but .. slack off.. wtf ? .. hahahahhahahah sherren! if you dont finish ASAP i think you end up finishing it in december .. or worse.. next year ... you having your PMR right this year
Well today ,not that much though, Just file to make it even straightly, u can try to look at the older updates to compare. Halfway Done Almost Finally Done
Any Ideas what can i do wtih this? I was Thinking removing this[see da red coloured lines]then place an arcylic piece on top , what do u think? and remove that legs
Heres The Update I was Taking Off The Top part of the case,It was Kinda Super hard to drill out those big rivets,and it dented my case abit ,sigh i will use some paty to cover up 6 holes,and im not going to use Rivets any more,give me a hard time,i will use Screws ,which is easier for next time and future. see the dents Next, i got this from an I-Cute Case Cutting it Shorter Done Cutting Test Fit on CM 80mm UV fan[Blue]
Its Time to Cut a blowhole on the Top Panel of The C5 Case Done Cutting By the way the hole is not properly filed,tomorow i will file it properly
