x264 Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Sep 9, 2007.
  1. Dashken
    Dashken Administrator!
    The x264 benchmark measures how fast your machine can encode a short, DVD quality MPEG-2 video clip into a high-quality x264 video clip.
    It will give you results in FPS that can be used to compare the performance of different CPUs and different CPU settings.
    Here's a quote from the article :-
    Link : x264 Benchmark
    Official x264 Results : Click to view! :thumb:
  2. chillinwitchu
    chillinwitchu Newbie
    1st results
    I think this is the first post. i dont have anything to compare my results to so, i do not know how good my results are. :boohoo:
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 34.96 fps, 1854.10 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 34.99 fps, 1854.10 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 34.73 fps, 1854.10 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 34.90 fps, 1854.10 kb/s
    ---------- RUN5PASS1.LOG
    encoded 1749 frames, 34.91 fps, 1854.10 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 8.65 fps, 1825.89 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 8.70 fps, 1825.89 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 8.68 fps, 1825.89 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 8.38 fps, 1825.89 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 8.69 fps, 1825.89 kb/s
  3. IMNOTDRPHIL
    IMNOTDRPHIL Newbie
    Here's mine:
    encoded 1749 frames, 28.47 fps, 1850.89 kb/s
    encoded 1749 frames, 28.82 fps, 1850.89 kb/s
    encoded 1749 frames, 28.73 fps, 1850.89 kb/s
    encoded 1749 frames, 29.64 fps, 1850.89 kb/s
    encoded 1749 frames, 29.67 fps, 1850.89 kb/s
    encoded 1749 frames, 7.04 fps, 1826.37 kb/s
    encoded 1749 frames, 7.05 fps, 1826.37 kb/s
    encoded 1749 frames, 7.17 fps, 1826.27 kb/s
    encoded 1749 frames, 7.26 fps, 1826.37 kb/s
    encoded 1749 frames, 7.23 fps, 1826.38 kb/s
    Machine is a Gateway S-7125C laptop.
    CPU model: U7500
    Code name: C2D/Merom 2M, L2 stepping
    Total number of cores: 2
    CPU settings: 8x133
    Core rate (MHz): 1,064
    MB chipset: 945GM + 82801GBM
    Timings/Frequency 4-4-4-12 @ 533 MHz
    OS: WinXP SP2
    MeGUI Test Data FPS 1: 29.38
    MeGUI Test Data FPS 2: 7.22
    Not bad for a little 1.06 GHz unit, beat the 3.0 GHz P4 on the front page :D
  4. PsYkHoTiK
    PsYkHoTiK Admin nerd
    Different architectures. Speed is no longer a good measure. :p
  5. Chai
    Let's see what my 3.9GHz can do... :wicked:
  6. AMV
    AMV Newbie
    Q6600 8x450 3600mhz
    RAM 1:1 4-3-3-10
    Evga 680i A1
    Vista x64
    encoded 1749 frames, 181.71 fps, 1850.95 kb/s
    encoded 1749 frames, 182.61 fps, 1850.94 kb/s
    encoded 1749 frames, 182.00 fps, 1850.94 kb/s
    encoded 1749 frames, 181.70 fps, 1850.94 kb/s
    encoded 1749 frames, 182.30 fps, 1850.94 kb/s
    encoded 1749 frames, 50.55 fps, 1829.26 kb/s
    encoded 1749 frames, 50.53 fps, 1829.14 kb/s
    encoded 1749 frames, 50.48 fps, 1829.15 kb/s
    encoded 1749 frames, 50.52 fps, 1829.12 kb/s
    encoded 1749 frames, 50.48 fps, 1829.53 kb/s
  7. graysky
    graysky ARP Reviewer
    @chillinwitchu - thanks for the results... what o/s are you running? Also, the 4000+ is a single core chip, right?
    @MNOTDRPHIL and AMV - thanks for the results!
  8. Chai
    encoded 1749 frames, 110.28 fps, 1850.89 kb/s
    encoded 1749 frames, 110.61 fps, 1850.89 kb/s
    encoded 1749 frames, 110.72 fps, 1850.89 kb/s
    encoded 1749 frames, 110.83 fps, 1850.89 kb/s
    encoded 1749 frames, 27.46 fps, 1826.37 kb/s
    encoded 1749 frames, 27.47 fps, 1826.37 kb/s
    encoded 1749 frames, 27.42 fps, 1826.38 kb/s
    encoded 1749 frames, 27.31 fps, 1826.38 kb/s
    9x435
  9. chillinwitchu
    REPLY @ GREYSKY
    Sorry :doh: i forgot my OS. Its Windows XP PRO W/SP2 build 2600.
    and yes, that is a single core. it is however OC'd. Stock speed is 2.4GHz.
    regards
    chillinwitchu :beer:
  10. Wwhat
    Wwhat Newbie
    Error in package
    So I got the benchmark and it failed, after checking I found that although it includes a version of DGDecode.dll and instructions to install it it seems it does not realize there might be more locations where you have DGDecode.dll installed besides avisynth, and neither does it include dgindex.exe so I had to update those too in all incarnations I have (like AutoGK and StaxRip)
    Also I think the batch file should also use the path to the x264.exe rather than just using x264.exe, and perhaps the same for tee.exe for completeness.
  11. Adrian Wong
    Hi Wwhat, what was the error message? Thanks!
  12. Wingnut
    Wingnut Newbie
    x264 Test
    OS: Windows XP Pro-SP2
    Processor: Intel Pentium D 945
    Code Name: Presler
    Overclocked: 17x230.5
    Chipset: Intel i955x
    Core Speed: 3917.6
    Frequencyz: 460.9
    FSB;Dram: 1:2
    Timings: 5,5,5,15
    MeGUI Test Data FPS 1: 59.17 Avg.
    MeGUI Test Data FPS 2: 14.77 Avg.
    encoded 1749 frames, 59.07 fps, 1850.89 kb/s
    encoded 1749 frames, 59.26 fps, 1850.89 kb/s
    encoded 1749 frames, 59.23 fps, 1850.89 kb/s
    encoded 1749 frames, 59.22 fps, 1850.89 kb/s
    encoded 1749 frames, 14.79 fps, 1826.37 kb/s
    encoded 1749 frames, 14.76 fps, 1826.37 kb/s
    encoded 1749 frames, 14.75 fps, 1826.38 kb/s
    encoded 1749 frames, 14.78 fps, 1826.37 kb/s
  13. graysky
    @Chai - Win XP SP2 32 or 64bit?
  14. graysky
    Hi Wwhat. As far as I know, the default path for all plugins for avisynth is its %instaldir%/plugins so unless one has a line in the avs that says otherwise, it should assume that. An example of a non-standard one might be:
    Code:
    LoadPlugin("F:\AviSynth\plugins\plugin-xyz.dll")
    Also, dgindex.exe isn't required for the test. As to the paths in the batch file. I opted to place the exes in the /test dir just to keep the root of the test clean, although doing as you suggested should work just fine as well.
    My curiosity is why it doesn't run on your machine. Where did you install your avisynth? If you drag-and-drop the test avs (located in c:\work2\test) into mplayerc, what does it show as an error message (can you post a screenshot of that)?
  15. Chai
    WinXP 32bit.
  16. graysky
    Cool, thanks for the data... do we have any Tech ARP members who are good with asp (I think you guys are using it) so we can bring the data out of a gif file and into a sortible table on the page? You know something akin to the Tom's hardware VGA charts... anyone?
  17. juande
    juande Newbie
    Hi :wave:
    My oced C2D 6400 @3000mhz:
    CPU model: Core 2 Duo 6400
    Code name: Allendale, B2 stepping
    CPU settings: 8x375
    Core rate (MHz): 3000
    MB chipset: Intel P965
    Timings/Frequency 4-4-4-12 @ 800 MHz (375 mhz)
    OS: Vista x64
    MeGUI Test Data FPS 1: 84.00 Avg.
    MeGUI Test Data FPS 2: 20.86 Avg.
    Code:
    encoded 1749 frames, 83.67 fps, 1850.89 kb/s
    encoded 1749 frames, 83.29 fps, 1850.89 kb/s
    encoded 1749 frames, 83.86 fps, 1850.89 kb/s
    encoded 1749 frames, 84.17 fps, 1850.89 kb/s
    encoded 1749 frames, 83.98 fps, 1850.89 kb/s
    encoded 1749 frames, 20.85 fps, 1826.38 kb/s
    encoded 1749 frames, 20.87 fps, 1826.38 kb/s
    encoded 1749 frames, 20.81 fps, 1826.33 kb/s
    encoded 1749 frames, 20.80 fps, 1826.37 kb/s
    Click to enlarge [​IMG]
  18. juande
    juande Newbie
    And my stock A64 X2 6000+ @3000mhz:
    CPU model: Athlon 64 X2 6000+
    Code name: Windsor, F3 stepping
    CPU settings: 15x200
    MB chipset: AMD 580X
    OS: Vista x64
    MeGUI Test Data FPS 1: 80.35 Avg.
    MeGUI Test Data FPS 2: 19.68 Avg.
    Code:
    encoded 1749 frames, 78.95 fps, 1850.89 kb/s
    encoded 1749 frames, 78.46 fps, 1850.89 kb/s
    encoded 1749 frames, 80.20 fps, 1850.89 kb/s
    encoded 1749 frames, 80.54 fps, 1850.89 kb/s
    encoded 1749 frames, 80.31 fps, 1850.89 kb/s
    encoded 1749 frames, 19.68 fps, 1826.37 kb/s
    encoded 1749 frames, 19.51 fps, 1826.37 kb/s
    encoded 1749 frames, 19.63 fps, 1826.37 kb/s
    encoded 1749 frames, 19.62 fps, 1826.37 kb/s
    encoded 1749 frames, 19.73 fps, 1826.37 kb/s
  19. todd5813
    todd5813 Newbie
    Here is another benchmark
    encoded 1749 frames, 67.20 fps, 1850.89 kb/s
    encoded 1749 frames, 65.37 fps, 1850.89 kb/s
    encoded 1749 frames, 68.20 fps, 1850.89 kb/s
    encoded 1749 frames, 66.39 fps, 1850.89 kb/s
    encoded 1749 frames, 17.48 fps, 1826.37 kb/s
    encoded 1749 frames, 17.57 fps, 1826.37 kb/s
    encoded 1749 frames, 17.54 fps, 1826.38 kb/s
    encoded 1749 frames, 17.80 fps, 1826.37 kb/s
    encoded 1749 frames, 17.68 fps, 1826.38 kb/s
    core 2d e6700
    core 3200.2MHz
    multiplier x10
    FSB 10
    nvidia 650i /570 asus p5n32-e sli plus
    4-4-4-12 mem 400MHz
    Vista Ultimate 32 bit
  20. Max_87
    Max_87 huehuehue
    Core 2 Duo E6850 @ 434x9
    Abit IP35 Pro
    WinXP SP2 32-bit
    encoded 1749 frames, 105.60 fps, 1850.89 kb/s
    encoded 1749 frames, 108.36 fps, 1850.89 kb/s
    encoded 1749 frames, 108.57 fps, 1850.89 kb/s
    encoded 1749 frames, 108.78 fps, 1850.89 kb/s
    encoded 1749 frames, 26.65 fps, 1826.38 kb/s
    encoded 1749 frames, 27.16 fps, 1826.37 kb/s
    encoded 1749 frames, 27.11 fps, 1826.38 kb/s
    encoded 1749 frames, 27.14 fps, 1826.38 kb/s
    encoded 1749 frames, 27.20 fps, 1826.37 kb/s
