x264 HD Benchmark 3.0
Discussion in 'Reviews & Articles' started by Adrian Wong, Nov 24, 2009.
  1. Adrian Wong
    No problem. Take your time! :)
  2. Bamboo
    Bamboo Newbie
    Results for x264.exe r1342
    encoded 1442 frames, 29.11 fps, 3899.26 kb/s
    encoded 1442 frames, 29.13 fps, 3899.26 kb/s
    encoded 1442 frames, 29.17 fps, 3899.26 kb/s
    encoded 1442 frames, 29.04 fps, 3899.26 kb/s
    encoded 1442 frames, 7.08 fps, 3970.72 kb/s
    encoded 1442 frames, 7.04 fps, 3971.30 kb/s
    encoded 1442 frames, 7.05 fps, 3970.50 kb/s
    encoded 1442 frames, 7.06 fps, 3971.42 kb/s
    System Details
    Name Intel Mobile Core 2 Duo T6500
    Codename Penryn
    Specification Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz
    Core Stepping R0
    Technology 45 nm
    Stock frequency 2100 MHz
    Core Speed 2094.8 MHz
    FID range 6.0x - 10.5x
    Northbridge Intel GL40 rev. 09
    Southbridge Intel 82801IM (ICH9-M) rev. 03
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 15
    Memory Frequency 332.5 MHz (3:5)
    Memory Type DDR2
    Memory Size 3038 MBytes
    Channels Dual, (Symmetric)
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    Number of processors 1
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
    Package (platform ID) Socket P (478) (0x7)
    Temperature 0 65°C (148°F) [0x23] (Core #0)
    Temperature 1 66°C (150°F) [0x22] (Core #1)
    Will test on win7x64 aswell and on q6600 when I get hoime.
    :wave:
  3. Adrian Wong
    Thanks! Look forward to the Win7 results. I think it will be significantly faster. :thumb:
  4. E8400 9x409
    x264 HD BENCHMARK 3.0 RESULTS
    Please do not compare it with older versions of the benchmark!
    Please copy/paste everything below the line to to report your data
    encoded 1442 frames, 49.42 fps, 3899.26 kb/s
    encoded 1442 frames, 49.71 fps, 3899.26 kb/s
    encoded 1442 frames, 49.58 fps, 3899.26 kb/s
    encoded 1442 frames, 48.80 fps, 3899.26 kb/s
    encoded 1442 frames, 12.57 fps, 3971.14 kb/s
    encoded 1442 frames, 12.50 fps, 3972.04 kb/s
    encoded 1442 frames, 12.50 fps, 3971.08 kb/s
    encoded 1442 frames, 12.60 fps, 3970.69 kb/s
    System Details
    Name Intel Core 2 Duo E8400
    Codename Wolfdale
    Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
    Core Stepping C0
    Technology 45 nm
    Stock frequency 3000 MHz
    Core Speed 3680.8 MHz
    FID range 6.0x - 9.0x
    Northbridge Intel P35/G33/G31 rev. A2
    Southbridge Intel 82801IR (ICH9R) rev. 02
    CAS# latency (CL) 4.0
    Cycle Time (tRAS) 12
    Command Rate (CR) 2T
    Memory Frequency 409.0 MHz (1:1)
    Memory Type DDR2
    Memory Size 4096 MBytes
    Windows Version Microsoft Windows 7 (6.1) (Build 7600)
    Number of threads 2
    L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
    Package (platform ID) Socket 775 LGA (0x0)
    Temperature 0 62°C (143°F) [0x3E] (TMPIN0)
    Temperature 1 38°C (100°F) [0x26] (TMPIN1)
    Temperature 1 61°C (141°F) [0x27] (Core #1)
    My temperatures are due to my case being enclosed in my computer desk with limited air flow
  5. Adrian Wong
    x264 HD Benchmark 3.15
    The new x264 HD Benchmark 3.0 is here!
    This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts.
    The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors.
    Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark.
    In addition to the release of the benchmark, we will be compiling benchmark results for this new version. There are now 80 CPUs in this article, but we need MORE results! So please contribute your new benchmark results to this project! :beer:
    Check out the latest results!
    Link : x264 HD Benchmark 3.15
  6. Adrian Wong
    Nice scores! :thumb:
  7. Bamboo
    Bamboo Newbie
    encoded 1442 frames, 28.72 fps, 3899.26 kb/s
    encoded 1442 frames, 27.99 fps, 3899.26 kb/s
    encoded 1442 frames, 28.18 fps, 3899.26 kb/s
    encoded 1442 frames, 28.42 fps, 3899.26 kb/s
    encoded 1442 frames, 7.08 fps, 3970.54 kb/s
    encoded 1442 frames, 7.09 fps, 3972.14 kb/s
    encoded 1442 frames, 7.10 fps, 3971.42 kb/s
    encoded 1442 frames, 7.13 fps, 3971.20 kb/s
    System Details
    Codename Penryn
    Core Stepping R0
    Technology 45 nm
    Core Speed 2094.7 MHz
    Memory Type DDR2
    Memory Size 4062 MBytes
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
    Number of threads 2
  8. nkosi
    nkosi Newbie
    encoded 1442 frames, 77.81 fps, 3899.02 kb/s
    encoded 1442 frames, 79.82 fps, 3899.02 kb/s
    encoded 1442 frames, 77.42 fps, 3899.02 kb/s
    encoded 1442 frames, 76.27 fps, 3899.02 kb/s
    encoded 1442 frames, 31.06 fps, 3960.56 kb/s
    encoded 1442 frames, 31.04 fps, 3972.47 kb/s
    encoded 1442 frames, 31.13 fps, 3971.61 kb/s
    encoded 1442 frames, 30.89 fps, 3957.99 kb/s
    System Details
    Name Intel Core i7 960
    product System Product Name
    Codename Bloomfield
    Specification Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
    Core Stepping D0
    Technology 45 nm
    Stock frequency 3200 MHz
    Core Speed 3300.0 MHz
    Northbridge Intel X58 rev. 13
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Memory Frequency 900.0 MHz (2:12)
    Memory Type DDR3
    Memory Size 6144 MBytes
    Channels Triple
    Number of threads 8
    Number of threads 8 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
    Package (platform ID) Socket 1366 LGA (0x1)
    Temperature 0 38°C (100°F) [0x26] (SYSTIN)
    Temperature 1 41°C (104°F) [0x51] (CPUTIN)
    Temperature 2 34°C (93°F) [0x44] (AUXTIN)
    Temperature 0 49°C (120°F) [0x33] (Core #0)
    Temperature 1 46°C (114°F) [0x36] (Core #1)
    Temperature 2 49°C (120°F) [0x33] (Core #2)
    Temperature 3 46°C (114°F) [0x36] (Core #3)
  9. nkosi
    nkosi Newbie
    2nd run
    encoded 1442 frames, 84.34 fps, 3899.02 kb/s
    encoded 1442 frames, 82.17 fps, 3897.87 kb/s
    encoded 1442 frames, 84.49 fps, 3898.50 kb/s
    encoded 1442 frames, 84.96 fps, 3899.02 kb/s
    encoded 1442 frames, 33.65 fps, 3957.18 kb/s
    encoded 1442 frames, 33.87 fps, 3949.97 kb/s
    encoded 1442 frames, 33.83 fps, 3960.46 kb/s
    encoded 1442 frames, 34.00 fps, 3964.27 kb/s
    System Details
    Codename Bloomfield
    Core Stepping D0
    Technology 45 nm
    Core Speed 3600.0 MHz
    Memory Type DDR3
    Channels Triple
    Number of threads 8
    Temperature 0 40°C (103°F) [0x28] (SYSTIN)
    Temperature 1 50°C (121°F) [0x63] (CPUTIN)
    Temperature 2 35°C (94°F) [0x45] (AUXTIN)
    Temperature 0 58°C (136°F) [0x2A] (Core #0)
    Temperature 1 49°C (120°F) [0x33] (Core #1)
    Temperature 3 47°C (116°F) [0x35] (Core #3)
  10. Chai
    Turbo Boost enabled or overclocked?
  11. derrettlee
    derrettlee Newbie
    encoded 1442 frames, 61.90 fps, 3901.21 kb/s
    encoded 1442 frames, 61.55 fps, 3900.68 kb/s
    encoded 1442 frames, 62.28 fps, 3901.21 kb/s
    encoded 1442 frames, 61.46 fps, 3900.68 kb/s
    encoded 1442 frames, 18.07 fps, 3971.87 kb/s
    encoded 1442 frames, 18.67 fps, 3970.94 kb/s
    encoded 1442 frames, 18.71 fps, 3970.41 kb/s
    encoded 1442 frames, 18.73 fps, 3971.85 kb/s
    System Details
    Name AMD Phenom II X4 940
    Codename Deneb
    Specification AMD Phenom(tm) II X4 940 Processor
    Core Stepping RB-C2
    Technology 45 nm
    Core Speed 3016.6 MHz
    Northbridge AMD 790GX rev. 00
    Southbridge ATI SB750 rev. 00
    Memory Frequency 402.2 MHz (1:2)
    Memory Type DDR2
    Channels Dual, (Unganged)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
    Package Socket AM2+ (940)
    Package Type 0x1
    Temperature 0 41°C (105°F) [0x29] (TMPIN0)
    Temperature 1 39°C (102°F) [0x27] (TMPIN1)
    Temperature 0 46°C (115°F) [0x172] (Core #0)
    Temperature 1 46°C (115°F) [0x172] (Core #1)
    Temperature 2 46°C (115°F) [0x172] (Core #2)
    Temperature 3 46°C (115°F) [0x172] (Core #3)
  12. Jules
    Jules Newbie
    Hi all!
    This is an interesting benchmark to share with.
    Here's a result with my new build.
    encoded 1442 frames, 77.95 fps, 3900.68 kb/s
    encoded 1442 frames, 76.65 fps, 3900.68 kb/s
    encoded 1442 frames, 78.14 fps, 3901.21 kb/s
    encoded 1442 frames, 77.23 fps, 3901.21 kb/s
    encoded 1442 frames, 23.73 fps, 3970.79 kb/s
    encoded 1442 frames, 23.83 fps, 3971.86 kb/s
    encoded 1442 frames, 23.75 fps, 3971.47 kb/s
    encoded 1442 frames, 23.70 fps, 3970.56 kb/s
    System Details
    Name AMD Phenom II X4 965
    Codename Deneb
    Specification AMD Phenom(tm) II X4 965 Processor
    Specification PC3-12800
    Core Stepping RB-C3
    Technology 45 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Core Speed 3700.1 MHz
    Northbridge AMD 790FX rev. 00
    CAS# latency (CL) 8.0
    RAS# to CAS# delay (tRCD) 8
    RAS# Precharge (tRP) 8
    Command Rate (CR) 1T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 800.0 MHz (1:4)
    Memory Type DDR3
    Number of threads 4
    Package Type 0x1
    Temperature 0 35°C (94°F) [0x23] (TMPIN0)
    Temperature 1 51°C (123°F) [0x33] (TMPIN1)
    Temperature 2 44°C (111°F) [0x2C] (TMPIN2)
    Temperature 0 48°C (117°F) [0x17C] (Core #0)
    Temperature 1 48°C (117°F) [0x17D] (Core #1)
    Temperature 3 48°C (117°F) [0x17C] (Core #3)
    Temperature 2 48°C (117°F) [0x17C] (Core #2)
  13. Jules
    Jules Newbie
    Hey Scrambler- what's your secret?
    You have a 955BE in post#47
    same AMD chipsets
    you have 20 fps faster than me in some parts of the bench
    going almost 500 mhz. slower than me on cpu
    your ram is slower and the timings are higher.
    your temps are almost 10 degrees hotter.
    inquiring minds would like to know ??:mrgreen:
  14. nkosi
    nkosi Newbie
    1st run was at stock core speed of 3200 MHz, Turboboost disabled, RAM running at 1800 something MHz; on the second run the Multiplicator was set to 24 (core speed at 3600 MHz), same RAM setting.
  15. Adrian Wong
    Hi Bamboo, what's the difference between these results and the ones you posted earlier?
  16. Adrian Wong
    Hi nkosi, can you retest the i7-960 at its stock speed? Thanks! :)
  17. Adrian Wong
    Hmm.. It looks like it was set to 3.3 GHz, not 3.2 GHz. At least that's what CPU-Z detected.
  18. Bamboo
    Bamboo Newbie
    First post was under winxp_x32 and second results win7_x64
    Almost no difference :|
  19. Bamboo
    Bamboo Newbie
    q6600 Winxp_x32
    encoded 1442 frames, 52.23 fps, 3900.68 kb/s
    encoded 1442 frames, 52.11 fps, 3900.44 kb/s
    encoded 1442 frames, 47.13 fps, 3900.10 kb/s
    encoded 1442 frames, 49.14 fps, 3900.95 kb/s
    encoded 1442 frames, 15.53 fps, 3971.73 kb/s
    encoded 1442 frames, 13.71 fps, 3970.96 kb/s
    encoded 1442 frames, 12.31 fps, 3971.74 kb/s
    encoded 1442 frames, 12.44 fps, 3971.63 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
    Core Stepping G0
    Technology 65 nm
    Stock frequency 2400 MHz
    Core Speed 2394.7 MHz
    Southbridge Intel 82801IB (ICH9) rev. 02
    Cycle Time (tRAS) 18
    Memory Frequency 399.1 MHz (2:3)
    Memory Type DDR2
    Memory Size 2048 MBytes
    Number of threads 4
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
    Package (platform ID) Socket 775 LGA (0x4)
    Temperature 0 41°C (105°F) [0x29] (System)
    Temperature 1 85°C (184°F) [0x55] (CPU)
    Temperature 0 98°C (208°F) [0x2] (Core #0)
    Temperature 3 85°C (184°F) [0xF] (Core #3)
    Temperature 1 97°C (206°F) [0x3] (Core #1)
    Temperature 2 91°C (195°F) [0x9] (Core #2)
  20. Bamboo
    Bamboo Newbie
    q6600 Win7_x32
    encoded 1442 frames, 51.38 fps, 3901.21 kb/s
    encoded 1442 frames, 51.84 fps, 3901.21 kb/s
    encoded 1442 frames, 49.91 fps, 3901.21 kb/s
    encoded 1442 frames, 44.00 fps, 3901.21 kb/s
    encoded 1442 frames, 15.37 fps, 3971.57 kb/s
    encoded 1442 frames, 14.75 fps, 3970.69 kb/s
    encoded 1442 frames, 12.77 fps, 3970.76 kb/s
    encoded 1442 frames, 11.46 fps, 3971.86 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 1596.7 MHz
    Memory Frequency 399.2 MHz (2:3)
    Memory Type DDR2
    Number of threads 4
    Temperature 0 39°C (102°F) [0x27] (System)
    Temperature 0 100°C (211°F) [0x0] (Core #0)
    Temperature 2 92°C (197°F) [0x8] (Core #2)
