Here's the TL60 running at stock: Results for x264.exe r1342 -------------------------- encoded 1442 frames, 22.39 fps, 3899.26 kb/s encoded 1442 frames, 22.38 fps, 3899.26 kb/s encoded 1442 frames, 22.39 fps, 3899.26 kb/s encoded 1442 frames, 22.47 fps, 3899.26 kb/s encoded 1442 frames, 5.06 fps, 3970.59 kb/s encoded 1442 frames, 5.06 fps, 3970.94 kb/s encoded 1442 frames, 5.05 fps, 3971.67 kb/s encoded 1442 frames, 5.06 fps, 3972.11 kb/s System Details -------------- Name AMD Turion 64 X2 Mobile TL-60 Codename Tyler Specification AMD Turion(tm) 64 X2 Mobile Technology TL-60 Core Stepping Specification AMD Turion(tm) 64 X2 Mobile Technology TL-60 Technology 65 nm Stock frequency 2000 MHz Core Speed 2000.3 MHz Northbridge NVIDIA nForce 560 rev. A2 Southbridge NVIDIA nForce 560 rev. A2 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 1T Memory Frequency 333.4 MHz (CPU/6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket S1 (638) Temperature 0 77°C (169°F) [0x1F6] (Core #0) Temperature 1 72°C (162°F) [0x1E5] (Core #1)
Prehistoric AMD Sempron 3100+ @ 2.2Ghz Here's the bench on an oldie Sempron 3100 @ 2200 Mhz I'll run it at stock soon. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 12.12 fps, 3896.61 kb/s encoded 1442 frames, 12.16 fps, 3896.61 kb/s encoded 1442 frames, 12.23 fps, 3896.61 kb/s encoded 1442 frames, 12.15 fps, 3896.61 kb/s encoded 1442 frames, 2.87 fps, 3971.28 kb/s encoded 1442 frames, 2.87 fps, 3971.28 kb/s encoded 1442 frames, 2.87 fps, 3971.28 kb/s encoded 1442 frames, 2.87 fps, 3971.28 kb/s System Details -------------- Name AMD Sempron 3100+ Codename Paris Specification AMD Sempron(tm) Processor 3100+ Core Stepping DH7-CG Technology 0.13 um Stock frequency 1800 MHz Core Speed 2205.0 MHz Northbridge NVIDIA nForce3 250 rev. A1 Southbridge NVIDIA nForce3 MCP rev. A2 CAS# latency (CL) 2.5 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 7 Command Rate (CR) 1T Memory Frequency 200.5 MHz (CPU/11) Memory Type DDR Memory Size 1536 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 1 Number of threads 1 (max 1) L2 cache 256 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2 Package Socket 754 Temperature 0 61°C (141°F) [0x3D] (TMPIN0) Temperature 1 39°C (102°F) [0x27] (TMPIN1) Temperature 0 71°C (159°F) [0x78] (Core #0)
Xeon E5504 2Ghz - Proliant WS Xeon E5504 2Ghz - Proliant WS The DDR3 is only running single channel, but it looks like the fastest 2Ghz computer on the bench Results for x264.exe r1342 -------------------------- encoded 1442 frames, 46.19 fps, 3900.68 kb/s encoded 1442 frames, 47.18 fps, 3900.68 kb/s encoded 1442 frames, 46.40 fps, 3900.68 kb/s encoded 1442 frames, 46.03 fps, 3900.68 kb/s encoded 1442 frames, 15.22 fps, 3971.48 kb/s encoded 1442 frames, 15.23 fps, 3971.57 kb/s encoded 1442 frames, 15.24 fps, 3971.85 kb/s encoded 1442 frames, 15.26 fps, 3971.84 kb/s System Details -------------- Name Intel Xeon Codename Gainestown Specification Intel(R) Xeon(R) CPU E5504 @ 2.00GHz Core Stepping D0 Technology 45 nm Stock frequency 2000 MHz Core Speed 1995.0 MHz Northbridge Intel 5500 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 15 Command Rate (CR) 1T Memory Frequency 399.0 MHz (2:6) Memory Type DDR3 Memory Size 2048 MBytes Channels Single Windows Version Microsoft Windows Server 2003 Standard Edition Service Pack 2 (Build 3790) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 50°C (121°F) [0x2F] (Core #0) Temperature 2 51°C (123°F) [0x2E] (Core #2) Temperature 1 50°C (121°F) [0x2F] (Core #1) Temperature 3 45°C (112°F) [0x34] (Core #3)
I got marginally better results for a AMD Athlon 64 X2 5200+ than the one already listed. 0.1 fps faster Results for x264.exe r1342 -------------------------- encoded 1442 frames, 29.08 fps, 3899.26 kb/s encoded 1442 frames, 29.13 fps, 3899.26 kb/s encoded 1442 frames, 29.20 fps, 3899.26 kb/s encoded 1442 frames, 29.00 fps, 3899.26 kb/s encoded 1442 frames, 6.72 fps, 3971.72 kb/s encoded 1442 frames, 6.71 fps, 3971.02 kb/s encoded 1442 frames, 6.73 fps, 3971.63 kb/s encoded 1442 frames, 6.70 fps, 3970.81 kb/s System Details -------------- Name AMD Athlon 64 X2 5200+ product System Product Name Name ATI Radeon Xpress 1250 Codename Brisbane Codename RS690 Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ Core Stepping BH-G2 Technology 65 nm Technology 80 nm Stock frequency 2700 MHz Core Speed 2699.9 MHz Northbridge ATI Radeon X1250 rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 385.7 MHz (CPU/7) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 64°C (147°F) [0x40] (TMPIN0) Temperature 1 44°C (111°F) [0x2C] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM) Temperature 0 80°C (175°F) [0x1AE] (Core #0) Temperature 1 81°C (178°F) [0x1B5] (Core #1)
I had to check if it wasn't underclocking . But that's actually the stock speed Intel® Xeon® Processor E5504 (4M Cache, 2.00 GHz, 4.80 GT/s Intel® QPI) with SPEC Code(s) SLBF9
Didn't see any results for my AMD X2-545, so here you go! Results for x264.exe r1342 -------------------------- encoded 1442 frames, 41.12 fps, 3899.26 kb/s encoded 1442 frames, 40.76 fps, 3899.26 kb/s encoded 1442 frames, 41.01 fps, 3899.26 kb/s encoded 1442 frames, 40.86 fps, 3899.26 kb/s encoded 1442 frames, 10.13 fps, 3971.11 kb/s encoded 1442 frames, 10.16 fps, 3971.57 kb/s encoded 1442 frames, 10.13 fps, 3971.71 kb/s encoded 1442 frames, 10.18 fps, 3971.54 kb/s System Details -------------- Name AMD Phenom II X2 545 product System Product Name Codename Callisto Specification AMD Phenom(tm) II X2 545 Processor Core Stepping RB-C2 Technology 45 nm Stock frequency 3000 MHz Core Speed 3013.2 MHz FID range 5.0x - 15.0x Northbridge AMD 785GX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 401.8 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 53°C (127°F) [0x35] (TMPIN0) Temperature 1 47°C (116°F) [0x2F] (TMPIN1) Temperature 0 45°C (112°F) [0x164] (Core #0) Temperature 1 45°C (112°F) [0x164] (Core #1)
Intel Pentium E2160 1.8 GHz [Conroe] Results for x264.exe r1342 -------------------------- encoded 1442 frames, 24.74 fps, 3899.26 kb/s encoded 1442 frames, 24.93 fps, 3899.26 kb/s encoded 1442 frames, 24.90 fps, 3899.26 kb/s encoded 1442 frames, 24.87 fps, 3899.26 kb/s encoded 1442 frames, 5.76 fps, 3971.07 kb/s encoded 1442 frames, 5.79 fps, 3970.90 kb/s encoded 1442 frames, 5.78 fps, 3970.95 kb/s encoded 1442 frames, 5.81 fps, 3971.58 kb/s System Details -------------- Name Intel Pentium E2160 Codename Conroe Specification Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz Core Stepping M0 Technology 65 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 1800 MHz Core Speed 1809.2 MHz FID range 6.0x - 9.0x Northbridge Intel P965/G965 rev. C2 Southbridge Intel 82801HB/HR (ICH8/R) rev. B0 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 402.0 MHz (1:2) Memory Type DDR2 Memory Size 1024 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 1024 KBytes, 4-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 51°C (123°F) [0x33] (TMPIN0) Temperature 1 66°C (150°F) [0x42] (TMPIN1) Temperature 0 58°C (136°F) [0x1B] (Core #0) Temperature 1 59°C (138°F) [0x1A] (Core #1)
Intel Core 2 Duo E6300 1.86 MHz [Conroe] and another one. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 24.95 fps, 3899.26 kb/s encoded 1442 frames, 25.22 fps, 3899.26 kb/s encoded 1442 frames, 25.41 fps, 3899.26 kb/s encoded 1442 frames, 24.43 fps, 3899.26 kb/s encoded 1442 frames, 6.09 fps, 3971.91 kb/s encoded 1442 frames, 6.02 fps, 3971.66 kb/s encoded 1442 frames, 6.14 fps, 3971.40 kb/s encoded 1442 frames, 6.09 fps, 3971.86 kb/s System Details -------------- Name Intel Core 2 Duo E6300 product System Product Name Codename Conroe Specification Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz Core Stepping B2 Technology 65 nm Stock frequency 1866 MHz Core Speed 1866.8 MHz FID range 6.0x - 7.0x Northbridge Intel i945P/PL/G/GZ rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Memory Frequency 266.7 MHz (1:1) Memory Type DDR2 Memory Size 2560 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 45°C (112°F) [0x2D] (SYSTIN) Temperature 1 49°C (120°F) [0x62] (CPUTIN) Temperature 0 57°C (134°F) [0x1C] (Core #0) Temperature 1 57°C (134°F) [0x1C] (Core #1)
Intel Core 2 Duo E6420 (OC'd 3.25 GHz) If you want me to post results at stock speed let me know. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 45.31 fps, 3899.26 kb/s encoded 1442 frames, 45.31 fps, 3899.27 kb/s encoded 1442 frames, 45.42 fps, 3899.29 kb/s encoded 1442 frames, 45.17 fps, 3899.12 kb/s encoded 1442 frames, 11.00 fps, 3970.94 kb/s encoded 1442 frames, 10.98 fps, 3970.90 kb/s encoded 1442 frames, 10.97 fps, 3971.64 kb/s encoded 1442 frames, 10.97 fps, 3971.20 kb/s System Details -------------- Name Intel Core 2 Duo E6420 Codename Conroe Specification Intel(R) Core(TM)2 CPU 6420 @ 2.13GHz Core Stepping B2 Technology 65 nm Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Stock frequency 2133 MHz Core Speed 3328.6 MHz FID range 6.0x - 8.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 1T Memory Frequency 416.1 MHz (1:1) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 34°C (93°F) [0x22] (SYSTIN) Temperature 1 44°C (111°F) [0x58] (CPUTIN) Temperature 2 119°C (246°F) [0xEE] (AUXTIN) Temperature 0 53°C (127°F) [0x20] (Core #0) Temperature 1 50°C (121°F) [0x23] (Core #1)
Intel Pentium 4 630 3 GHz [Prescott] Results for x264.exe r1342 -------------------------- encoded 1442 frames, 12.68 fps, 3899.26 kb/s encoded 1442 frames, 12.81 fps, 3899.26 kb/s encoded 1442 frames, 12.72 fps, 3899.26 kb/s encoded 1442 frames, 12.77 fps, 3899.26 kb/s encoded 1442 frames, 2.97 fps, 3970.89 kb/s encoded 1442 frames, 2.91 fps, 3971.73 kb/s encoded 1442 frames, 2.96 fps, 3970.87 kb/s encoded 1442 frames, 2.96 fps, 3971.12 kb/s System Details -------------- Name Intel Pentium 4 630 Codename Prescott Specification Intel(R) Pentium(R) 4 CPU 3.00GHz Core Stepping N0 Technology 90 nm Stock frequency 3000 MHz Core Speed 2992.5 MHz FID range 14.0x - 15.0x Northbridge Intel i915P/i915G rev. B1 Southbridge Intel 82801FB (ICH6) rev. 03 CAS# latency (CL) 3.0 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 8 Memory Frequency 199.5 MHz (1:1) Memory Type DDR Memory Size 512 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 45°C (112°F) [0x2D] (SYSTIN) Temperature 1 72°C (161°F) [0x90] (CPUTIN) Temperature 2 67°C (151°F) [0x85] (AUXTIN)
Intel-Q8400-3.4GHz-OC Homebuilt box, 8GB DDR2, Gigabyte EP45 mb. The system was not tweaked to the ends of the earth, stock voltages all around and using an Arctic 7 cooler. Just for the thrill of it I'll post the numbers from my vintage Dell top o' the line circa 2001 C810 laptop with the blazing fast PIII-mobile cranking along at 1.13Ghz...after it completes the test in 30 minutes or so.... Results for x264.exe r1342 -------------------------- encoded 1442 frames, 66.94 fps, 3900.68 kb/s encoded 1442 frames, 66.09 fps, 3900.68 kb/s encoded 1442 frames, 66.54 fps, 3900.68 kb/s encoded 1442 frames, 64.33 fps, 3900.68 kb/s encoded 1442 frames, 21.60 fps, 3970.41 kb/s encoded 1442 frames, 21.28 fps, 3971.06 kb/s encoded 1442 frames, 21.04 fps, 3971.98 kb/s encoded 1442 frames, 21.60 fps, 3971.81 kb/s System Details -------------- Name Intel Core 2 Quad Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz Core Stepping R0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2666 MHz Core Speed 3479.9 MHz FID range 6.0x - 8.0x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 435.0 MHz (1:1) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 47°C (116°F) [0x2F] (System) Temperature 1 57°C (134°F) [0x39] (CPU) Temperature 0 58°C (136°F) [0x2A] (Core #0) Temperature 1 54°C (129°F) [0x2E] (Core #1) Temperature 2 59°C (138°F) [0x29] (Core #2) Temperature 3 57°C (134°F) [0x2B] (Core #3)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 75.81 fps, 3899.02 kb/s encoded 1442 frames, 76.89 fps, 3899.02 kb/s encoded 1442 frames, 76.79 fps, 3899.02 kb/s encoded 1442 frames, 76.37 fps, 3899.02 kb/s encoded 1442 frames, 32.66 fps, 3960.90 kb/s encoded 1442 frames, 32.62 fps, 3960.57 kb/s encoded 1442 frames, 32.61 fps, 3961.97 kb/s encoded 1442 frames, 32.52 fps, 3961.91 kb/s System Details -------------- Name Intel Core i7 870 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz Core Stepping B1 Technology 45 nm Stock frequency 2933 MHz Core Speed 3763.0 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 22 Command Rate (CR) 1T Memory Frequency 602.1 MHz (2:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 55°C (130°F) [0x37] (SYSTIN) Temperature 1 55°C (130°F) [0x6E] (CPUTIN) Temperature 2 45°C (112°F) [0x5A] (AUXTIN) Temperature 0 48°C (118°F) [0x33] (Core #0) Temperature 1 49°C (120°F) [0x32] (Core #1) Temperature 2 52°C (125°F) [0x2F] (Core #2) Temperature 3 43°C (109°F) [0x38] (Core #3)
720p_results-PIII-Mobile-1.13Ghz Here 'tis. I remember when this laptop was pretty darn fast. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 4.08 fps, 3896.61 kb/s encoded 1442 frames, 4.09 fps, 3896.61 kb/s encoded 1442 frames, 4.11 fps, 3896.61 kb/s encoded 1442 frames, 4.10 fps, 3896.61 kb/s encoded 1442 frames, 1.05 fps, 3971.28 kb/s encoded 1442 frames, 1.07 fps, 3971.28 kb/s encoded 1442 frames, 1.07 fps, 3971.28 kb/s encoded 1442 frames, 1.07 fps, 3971.28 kb/s System Details -------------- Name Intel Pentium III-M Codename Tualatin Specification Intel(R) Pentium(R) III Mobile CPU 1133MHz Core Stepping tA1 Technology 0.13 um Stock frequency 1133 MHz Core Speed 1129.6 MHz Northbridge Intel i815/E/EP rev. B Southbridge Intel 82801BA (ICH2-M) rev. 03 CAS# latency (CL) 3.0 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 7 Memory Frequency 132.9 MHz (1:1) Memory Type SDRAM Memory Size 512 MBytes Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 1 Number of threads 1 (max 1) L2 cache 512 KBytes, 8-way set associative, 32-byte line size Instructions sets MMX, SSE Package (platform ID) Socket nanoBGA2 (0x5)
