x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 33.29 fps, 3899.26 kb/s encoded 1442 frames, 33.55 fps, 3899.26 kb/s encoded 1442 frames, 33.17 fps, 3899.29 kb/s encoded 1442 frames, 33.52 fps, 3899.13 kb/s encoded 1442 frames, 7.84 fps, 3970.96 kb/s encoded 1442 frames, 7.86 fps, 3971.61 kb/s encoded 1442 frames, 7.87 fps, 3970.73 kb/s encoded 1442 frames, 7.85 fps, 3971.11 kb/s System Details -------------- Name AMD Athlon 64 X2 6000+ Codename Windsor Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ Core Stepping JH-F3 Technology 90 nm Stock frequency 3000 MHz Core Speed 3115.4 MHz Northbridge NVIDIA nForce 720a rev. A2 Southbridge NVIDIA ID075C rev. A2 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 389.4 MHz (CPU/8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940) Temperature 0 37°C (98°F) [0x25] (SYSTIN) Temperature 1 64°C (146°F) [0x7F] (CPUTIN) Temperature 2 63°C (144°F) [0x7D] (AUXTIN) Temperature 0 58°C (136°F) [0x6B] (Core #0) Temperature 1 65°C (148°F) [0x72] (Core #1) ======================= memory timings 4-4-4-12 ======================= x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 34.26 fps, 3899.26 kb/s encoded 1442 frames, 34.26 fps, 3899.25 kb/s encoded 1442 frames, 34.24 fps, 3899.38 kb/s encoded 1442 frames, 34.36 fps, 3899.45 kb/s encoded 1442 frames, 7.95 fps, 3971.22 kb/s encoded 1442 frames, 7.88 fps, 3970.94 kb/s encoded 1442 frames, 7.93 fps, 3970.77 kb/s encoded 1442 frames, 7.93 fps, 3971.55 kb/s System Details -------------- Name AMD Athlon 64 X2 6000+ Codename Windsor Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ Core Stepping JH-F3 Technology 90 nm Stock frequency 3000 MHz Core Speed 3115.6 MHz Northbridge NVIDIA nForce 720a rev. A2 Southbridge NVIDIA ID075C rev. A2 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 389.4 MHz (CPU/8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940) Temperature 0 39°C (102°F) [0x27] (SYSTIN) Temperature 1 67°C (152°F) [0x86] (CPUTIN) Temperature 2 66°C (149°F) [0x83] (AUXTIN) Temperature 0 61°C (141°F) [0x6E] (Core #0) Temperature 1 70°C (157°F) [0x77] (Core #1)
Intel Core2Quad Q9300 on an Intel DP45SG mobo. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 70.94 fps, 3902.28 kb/s encoded 1442 frames, 71.82 fps, 3902.28 kb/s encoded 1442 frames, 71.93 fps, 3902.21 kb/s encoded 1442 frames, 70.83 fps, 3902.21 kb/s encoded 1442 frames, 16.88 fps, 3982.42 kb/s encoded 1442 frames, 16.96 fps, 3981.07 kb/s encoded 1442 frames, 16.73 fps, 3981.72 kb/s encoded 1442 frames, 16.71 fps, 3981.10 kb/s System Details -------------- Name Intel Core 2 Quad Q9300 Name ATI Radeon HD 2600 PRO Codename Yorkfield Codename RV630 Specification Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz Specification PC3-10700 Specification PC3-10700 Core Stepping M1 Technology 45 nm Technology 65 nm Stock frequency 2500 MHz Core Speed 2500.1 MHz FID range 6.0x - 7.5x Northbridge Intel P45/P43/G45/G43 rev. A2 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 666.7 MHz (1:2) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 1 32°C (89°F) [0x20] (Zone 2) Temperature 2 30°C (85°F) [0x1E] (System) Temperature 3 28°C (82°F) [0x1C] (CPU) Temperature 0 60°C (139°F) [0x28] (Core #0) Temperature 1 57°C (134°F) [0x2B] (Core #1) Temperature 2 54°C (129°F) [0x2E] (Core #2) Temperature 3 57°C (134°F) [0x2B] (Core #3) Temperature 0 35°C (94°F) (GPU Core)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 93.94 fps, 3899.02 kb/s encoded 1442 frames, 92.62 fps, 3899.02 kb/s encoded 1442 frames, 92.80 fps, 3899.02 kb/s encoded 1442 frames, 93.94 fps, 3899.02 kb/s encoded 1442 frames, 37.27 fps, 3967.55 kb/s encoded 1442 frames, 37.15 fps, 3963.59 kb/s encoded 1442 frames, 36.84 fps, 3960.64 kb/s encoded 1442 frames, 37.21 fps, 3959.23 kb/s System Details -------------- Name Intel Core i7 920 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Specification PC3-14900 Specification PC3-14900 Specification PC3-14900 Core Stepping D0 Technology 45 nm Stock frequency 2666 MHz Core Speed 3989.8 MHz Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 760.0 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7100) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 45°C (112°F) [0x5A] (CPUTIN) Temperature 2 32°C (88°F) [0x3F] (AUXTIN) Temperature 0 48°C (118°F) [0x34] (Core #0) Temperature 1 52°C (125°F) [0x30] (Core #1) Temperature 2 48°C (118°F) [0x34] (Core #2) Temperature 3 42°C (107°F) [0x3A] (Core #3)
No. Instead of averaging the results, I am taking the BEST result possible for the CPU at that clock speed. For example, if there are three submissions of an Intel Core i7-920 CPU running at STOCK speed, but each with different combinations of motherboards, memory speeds and memory sizes, I will post the results of the fastest Core i7-920 system. But if someone submits a Core i7-920 that is overclocked, I will add that separately.
x264 HD Benchmark 3.06 The new x264 HD Benchmark 3.0 is here! This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors. Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. So please contribute your new benchmark results to this project! Check out the latest results! Link : x264 HD Benchmark 3.06
This has been overclocked to 2.91 GHz, right? The results look abnormally high. It is as if Turbo Boost had been enabled.
No that is with all settings in the BIOS set to defaults except for Turbo Mode disabled and SATA ports set to AHCI. For whatever reason the P7P55D board runs the processor at a slightly higher default speed. I used to have an MSI board that did the same thing back in the P4 days. I'm not an overclocker, never have been, just don't see the benefits in a day and age when an off the shelf processor can handle HD encoding of a 720p source in real time.
Just for comparison, here are my results with Turbo Mode enabled on my board. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 97.29 fps, 3882.95 kb/s encoded 1442 frames, 98.28 fps, 3882.95 kb/s encoded 1442 frames, 97.98 fps, 3882.95 kb/s encoded 1442 frames, 97.55 fps, 3882.95 kb/s encoded 1442 frames, 28.17 fps, 3995.84 kb/s encoded 1442 frames, 28.00 fps, 3997.15 kb/s encoded 1442 frames, 27.89 fps, 3994.49 kb/s encoded 1442 frames, 27.90 fps, 3992.55 kb/s System Details -------------- Name Intel Core i7 860 product System Product Name Name NVIDIA GeForce GTS 250 Codename Lynnfield Codename G92 Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Technology 65 nm Stock frequency 2800 MHz Core Speed 3050.7 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 693.3 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 49°C (120°F) [0x31] (SYSTIN) Temperature 1 49°C (120°F) [0x62] (CPUTIN) Temperature 2 37°C (98°F) [0x4A] (AUXTIN) Temperature 0 47°C (116°F) [0x34] (Core #0) Temperature 1 43°C (109°F) [0x38] (Core #1) Temperature 2 42°C (107°F) [0x39] (Core #2) Temperature 3 43°C (109°F) [0x38] (Core #3) Temperature 0 37°C (98°F) (GPU Core) Also, a screen shot of CPU-Z while running the benchmark. Seems like the board runs the processor at a slightly higher FSB, which when multiplied by 21 (the default multiplier) gives you the difference in default speed. As you can see with Turbo Mode on my board is running at 3.05 GHz not the specified 2.93 GHz. Again, this is the 5.4 Mhz difference in FSB multiplied by the Turbo Mode multiplier of 22.
I've got a Core i7 860 as well. With Turbo Mode I got 2-3 fps more. He has x22 and I have x21. My results without turbo mode: Code: x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 65.37 fps, 3899.02 kb/s encoded 1442 frames, 65.42 fps, 3899.02 kb/s encoded 1442 frames, 64.55 fps, 3899.02 kb/s encoded 1442 frames, 66.07 fps, 3899.02 kb/s encoded 1442 frames, 26.05 fps, 3958.13 kb/s encoded 1442 frames, 25.97 fps, 3972.28 kb/s encoded 1442 frames, 25.89 fps, 3971.90 kb/s encoded 1442 frames, 25.94 fps, 3958.11 kb/s System Details -------------- Name Intel Core i7 860 Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Stock frequency 2800 MHz Core Speed 2798.0 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 666.2 MHz (2:10) Memory Type DDR3 Memory Size 3072 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 37°C (98°F) [0x25] (TMPIN2) Temperature 0 39°C (102°F) [0x3C] (Core #0) Temperature 1 43°C (109°F) [0x38] (Core #1) Temperature 2 43°C (109°F) [0x38] (Core #2) Temperature 3 44°C (111°F) [0x37] (Core #3) I was going to post my CPU-Z screenshot but forum says I need to write 5 posts to be able to do that. ^^ Pic: yfrog.com/44cpuzg
That's because that screenshot of CPU-Z was taken with Turbo Mode on. With Turbo Mode off my max multiplier is 21x just like yours. The point of that screenshot was to show that under load my FSB is 5 MHz higher than default. My FSB ranges from ~128-138 Mhz depending on load. I'm sure its a BIOS setting but I don't know which one as this ASUS board has about 100 custom settings. My previous 3 boards have been Intel and they are crap for custom BIOS settings and hence easy to setup but with the ASUS there are so many settings I'm not sure which one allows the FSB to move around like that. That said, my posted results are at my boards default speeds with Turbo Mode off and all BIOS settings at default (other than those previously mentioned). No overclocking.
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 56.76 fps, 3901.42 kb/s encoded 1442 frames, 59.20 fps, 3900.68 kb/s encoded 1442 frames, 57.83 fps, 3900.93 kb/s encoded 1442 frames, 57.50 fps, 3901.21 kb/s encoded 1442 frames, 18.11 fps, 3972.11 kb/s encoded 1442 frames, 18.13 fps, 3971.74 kb/s encoded 1442 frames, 18.08 fps, 3971.11 kb/s encoded 1442 frames, 18.05 fps, 3972.20 kb/s System Details -------------- Name AMD Athlon II X4 630 Codename Propus Specification AMD Athlon(tm) II X4 630 Processor Core Stepping Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 2812.7 MHz FID range 5.0x - 14.0x Northbridge ATI RD770 rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 669.7 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 27°C (80°F) [0x1B] (TMPIN0) Temperature 1 53°C (127°F) [0x35] (TMPIN1) Temperature 2 79°C (174°F) [0x4F] (TMPIN2) Temperature 0 49°C (119°F) [0x186] (Core #0) Temperature 1 49°C (119°F) [0x186] (Core #1) Temperature 3 49°C (119°F) [0x186] (Core #3) Temperature 2 49°C (119°F) [0x185] (Core #2)
Oh, it's just that your results are much faster than the 3.33 GHz Core i7-975 even though it's just running at 2.91 GHz.
ASUS has an auto-overclocking (AI NOS, AI, etc.) feature. For accurate results, you have to disable it. I'm not sure but it could be the reason why your scores are so high.
I think I got it. It wasn't the BIOS settings, I disabled every setting I could find in the BIOS that related to FSB or the CPU and the processor still runs at 2.91 GHz under load. I can't figure it out. But what I did figure out was why my speeds were higher. I searched my system for other instances of x264.exe and found out that I had a different version of x264.exe in my SYSTEM32 folder and I think it was using that version for some reason. So once I deleted that file and re-ran the tests then my scores came in line. It didn't occur to me because my results file read just like everyone elses, "Results for x264.exe r1342". Here is the updated, and hopefully more accurate, score. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 65.17 fps, 3899.02 kb/s encoded 1442 frames, 65.32 fps, 3899.02 kb/s encoded 1442 frames, 64.68 fps, 3899.02 kb/s encoded 1442 frames, 64.14 fps, 3899.02 kb/s encoded 1442 frames, 26.14 fps, 3960.02 kb/s encoded 1442 frames, 26.10 fps, 3958.19 kb/s encoded 1442 frames, 26.11 fps, 3955.41 kb/s encoded 1442 frames, 25.93 fps, 3959.09 kb/s System Details -------------- Name Intel Core i7 860 product System Product Name Name NVIDIA GeForce GTS 250 Codename Lynnfield Codename G92 Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Technology 65 nm Stock frequency 2800 MHz Core Speed 2912.0 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 693.3 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 45°C (112°F) [0x2D] (SYSTIN) Temperature 1 46°C (113°F) [0x5B] (CPUTIN) Temperature 2 37°C (98°F) [0x4A] (AUXTIN) Temperature 0 40°C (103°F) [0x3B] (Core #0) Temperature 1 44°C (111°F) [0x37] (Core #1) Temperature 2 43°C (109°F) [0x38] (Core #2) Temperature 3 41°C (105°F) [0x3A] (Core #3) Temperature 0 37°C (98°F) (GPU Core)
Thanx for this wonderful benchmark! Here are some results from a AMD Phenom II 945 @ stock frequency (3000mhz), 3450mhz + 3600mhz ++++++++++++++++ x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 58.08 fps, 3900.68 kb/s encoded 1442 frames, 59.46 fps, 3901.21 kb/s encoded 1442 frames, 57.93 fps, 3900.68 kb/s encoded 1442 frames, 58.82 fps, 3901.21 kb/s encoded 1442 frames, 19.41 fps, 3970.45 kb/s encoded 1442 frames, 19.40 fps, 3971.25 kb/s encoded 1442 frames, 19.42 fps, 3971.69 kb/s encoded 1442 frames, 19.28 fps, 3971.73 kb/s System Details -------------- Name AMD Phenom II X4 945 Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3000 MHz Core Speed 3013.8 MHz FID range 5.0x - 15.0x Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 401.8 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 27°C (80°F) [0x1B] (TMPIN0) Temperature 1 44°C (111°F) [0x2C] (TMPIN1) Temperature 2 48°C (118°F) [0x30] (TMPIN2) Temperature 0 46°C (113°F) [0x16C] (Core #0) Temperature 1 46°C (113°F) [0x16C] (Core #1) Temperature 2 46°C (113°F) [0x16C] (Core #2) Temperature 3 46°C (113°F) [0x16C] (Core #3) ++++++++++++++++ x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 65.50 fps, 3900.68 kb/s encoded 1442 frames, 68.98 fps, 3900.68 kb/s encoded 1442 frames, 68.61 fps, 3901.21 kb/s encoded 1442 frames, 67.46 fps, 3900.68 kb/s encoded 1442 frames, 22.23 fps, 3971.73 kb/s encoded 1442 frames, 22.23 fps, 3971.74 kb/s encoded 1442 frames, 22.24 fps, 3972.15 kb/s encoded 1442 frames, 22.15 fps, 3971.73 kb/s System Details -------------- Name AMD Phenom II X4 945 Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3000 MHz Core Speed 3450.2 MHz FID range 5.0x - 15.0x Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 460.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 35°C (94°F) [0x23] (TMPIN0) Temperature 1 50°C (121°F) [0x32] (TMPIN1) Temperature 2 54°C (129°F) [0x36] (TMPIN2) Temperature 0 50°C (122°F) [0x193] (Core #0) Temperature 1 50°C (122°F) [0x192] (Core #1) Temperature 2 50°C (122°F) [0x192] (Core #2) Temperature 3 50°C (122°F) [0x192] (Core #3) ++++++++++++++++ x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 70.61 fps, 3901.21 kb/s encoded 1442 frames, 72.32 fps, 3901.21 kb/s encoded 1442 frames, 71.82 fps, 3900.93 kb/s encoded 1442 frames, 71.27 fps, 3900.68 kb/s encoded 1442 frames, 23.17 fps, 3970.57 kb/s encoded 1442 frames, 22.98 fps, 3971.55 kb/s encoded 1442 frames, 23.04 fps, 3971.90 kb/s encoded 1442 frames, 23.06 fps, 3971.87 kb/s System Details -------------- Name AMD Phenom II X4 945 Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3000 MHz Core Speed 3600.1 MHz FID range 5.0x - 15.0x Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 480.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 30°C (85°F) [0x1E] (TMPIN0) Temperature 1 49°C (120°F) [0x31] (TMPIN1) Temperature 2 51°C (123°F) [0x33] (TMPIN2) Temperature 0 49°C (119°F) [0x186] (Core #0) Temperature 1 49°C (119°F) [0x186] (Core #1) Temperature 2 49°C (119°F) [0x186] (Core #2) Temperature 3 49°C (119°F) [0x185] (Core #3)
Thanks for the results, JFC and everyone else! Do keep posting your results! I will update the table with the best results for each processor.
x264 HD Benchmark 3.07 The new x264 HD Benchmark 3.0 is here! This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors. Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. So please contribute your new benchmark results to this project! Check out the latest results! Link : x264 HD Benchmark 3.07
x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 25.83 fps, 3900.68 kb/s encoded 1442 frames, 25.53 fps, 3900.68 kb/s encoded 1442 frames, 26.41 fps, 3900.05 kb/s encoded 1442 frames, 26.07 fps, 3901.21 kb/s encoded 1442 frames, 2.72 fps, 3971.76 kb/s encoded 1442 frames, 2.71 fps, 3971.80 kb/s encoded 1442 frames, 2.70 fps, 3970.72 kb/s encoded 1442 frames, 2.69 fps, 3971.79 kb/s System Details -------------- Name Intel Core i3 530 Codename Clarkdale Specification Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz Core Stepping Technology 32 nm Stock frequency 2933 MHz Core Speed 2941.2 MHz Northbridge Intel Havendale/Clarkdale Host Bridge rev. 12 Southbridge Intel P55 rev. 05 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 16 Command Rate (CR) 2T Memory Frequency 534.8 MHz (4:16) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows Vista (6.0) Home Basic Edition Service Pack 2 (Build 6002) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (TMPIN0) Temperature 2 36°C (96°F) [0x24] (TMPIN2) Temperature 0 43°C (109°F) [0x43] (Core #0) Temperature 2 45°C (112°F) [0x41] (Core #2)
