Stock Core i7 920 (Turbo mode off, Hyper Threading on). Results for x264.exe r1342 -------------------------- encoded 1442 frames, 63.33 fps, 3899.02 kb/s encoded 1442 frames, 65.34 fps, 3899.02 kb/s encoded 1442 frames, 64.90 fps, 3899.02 kb/s encoded 1442 frames, 63.75 fps, 3898.50 kb/s encoded 1442 frames, 24.82 fps, 3967.70 kb/s encoded 1442 frames, 24.90 fps, 3962.88 kb/s encoded 1442 frames, 24.69 fps, 3962.19 kb/s encoded 1442 frames, 25.06 fps, 3968.94 kb/s System Details -------------- Name Intel Core i7 920 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Core Stepping D0 Technology 45 nm Stock frequency 2666 MHz Core Speed 2672.7 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 801.8 MHz (2:12) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 35°C (94°F) [0x23] (SYSTIN) Temperature 1 39°C (102°F) [0x4E] (CPUTIN) Temperature 2 29°C (83°F) [0x39] (AUXTIN) Temperature 0 44°C (111°F) [0x38] (Core #0) Temperature 1 39°C (102°F) [0x3D] (Core #1) Temperature 2 41°C (105°F) [0x3B] (Core #2) Temperature 3 39°C (102°F) [0x3D] (Core #3)
x264 HD Benchmark 3.13 The new x264 HD Benchmark 3.0 is here! This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors. Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. There are now 72 CPUs in this article, but we need MORE results! So please contribute your new benchmark results to this project! Check out the latest results! Link : x264 HD Benchmark 3.13
Hmmm... that's the TurboBoost itself. i7-860 goes at 2'8 Ghz (133Mhz x21) and Turbo uses x22. Shall we consider it OCed? ^^
Hmm.. That was Phrystorm's results. I'm not sure if it's due to Turbo Boost... or if he just overclocked it. But for consistency sake, let's list the processors as overclocked if they end up using Turbo Boost as that's the actual clock speed that CPU-Z detects while the benchmark is running.
Intel Mobile Core 2 Duo T5800 2.0 Ghz 800Mhz 2 MB L2 3GB RAM DDR-2 PC2-5300 Nvidia GeForce 9600M GT 512Mb IO SONO UN AUTARCHICO x264 HD BENCHMARK 3.0 RESULTS ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 25.77 fps, 3899.26 kb/s encoded 1442 frames, 25.75 fps, 3899.26 kb/s encoded 1442 frames, 25.94 fps, 3899.26 kb/s encoded 1442 frames, 25.72 fps, 3899.26 kb/s encoded 1442 frames, 6.35 fps, 3971.88 kb/s encoded 1442 frames, 6.37 fps, 3971.41 kb/s encoded 1442 frames, 6.33 fps, 3971.59 kb/s encoded 1442 frames, 6.36 fps, 3970.88 kb/s System Details -------------- Name Intel Mobile Core 2 Duo T5800 Codename Merom Specification Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz Core Stepping M0 Technology 65 nm Stock frequency 2000 MHz Core Speed 1995.4 MHz FID range 6.0x - 10.0x Northbridge Intel PM45 rev. 07 Southbridge Intel 82801IM (ICH9-M) rev. 03 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Memory Frequency 332.6 MHz (3:5) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket P (478) (0x7) Temperature 0 63°C (145°F) [0x16] (Core #0) Temperature 1 65°C (148°F) [0x14] (Core #1)
Sony VAIO CW-series Laptop Results for x264.exe r1342 -------------------------- encoded 1442 frames, 36.05 fps, 3900.68 kb/s encoded 1442 frames, 35.83 fps, 3901.21 kb/s encoded 1442 frames, 35.84 fps, 3900.68 kb/s encoded 1442 frames, 36.05 fps, 3901.21 kb/s encoded 1442 frames, 9.87 fps, 3971.70 kb/s encoded 1442 frames, 9.86 fps, 3971.68 kb/s encoded 1442 frames, 9.88 fps, 3970.54 kb/s encoded 1442 frames, 9.90 fps, 3971.35 kb/s System Details -------------- Name Intel Core i5 Codename Specification Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz Core Stepping Technology 32 nm Stock frequency 2133 MHz Core Speed 2128.4 MHz Northbridge Intel ID0044 rev. 02 Southbridge Intel PM55 rev. 05 Memory Type Memory Size 4096 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x4) Temperature 0 54°C (129°F) [0x24] (Core #0) Temperature 2 45°C (112°F) [0x2D] (Core #2)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 34.26 fps, 3899.26 kb/s encoded 1442 frames, 34.03 fps, 3899.26 kb/s encoded 1442 frames, 33.95 fps, 3899.26 kb/s encoded 1442 frames, 33.88 fps, 3899.26 kb/s encoded 1442 frames, 8.58 fps, 3971.88 kb/s encoded 1442 frames, 8.55 fps, 3971.72 kb/s encoded 1442 frames, 8.55 fps, 3971.87 kb/s encoded 1442 frames, 8.55 fps, 3971.65 kb/s System Details -------------- Name Intel Mobile Core 2 Duo Codename Penryn Specification Intel(R) Core(TM)2 Duo CPU T9300 @ 2.50GHz Core Stepping C0 Technology 45 nm Stock frequency 2500 MHz Core Speed 2493.8 MHz FID range 6.0x - 12.5x Northbridge Intel PM965 rev. C0 Southbridge Intel 82801HBM (ICH8-ME) rev. B1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Memory Frequency 332.5 MHz (3:5) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket P (478) (0x7) Temperature 0 56°C (132°F) [0x2C] (Core #0) Temperature 1 56°C (132°F) [0x2C] (Core #1)
2.93GHz is indeed the Turbo Boost speed of the 860. Here is mine with Turbo on. I'll post results without it tomorrow. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 66.88 fps, 3899.02 kb/s encoded 1442 frames, 67.01 fps, 3898.30 kb/s encoded 1442 frames, 67.32 fps, 3898.50 kb/s encoded 1442 frames, 68.05 fps, 3899.02 kb/s encoded 1442 frames, 27.04 fps, 3961.78 kb/s encoded 1442 frames, 27.17 fps, 3964.59 kb/s encoded 1442 frames, 27.09 fps, 3960.36 kb/s encoded 1442 frames, 27.20 fps, 3971.50 kb/s System Details -------------- Name Intel Core i7 860 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Stock frequency 2800 MHz Core Speed 2942.3 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 668.7 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1)
...Q6600 Hi all here you are my little result for my old Q6600 Results for x264.exe r1342 -------------------------- encoded 1442 frames, 69.24 fps, 3900.68 kb/s encoded 1442 frames, 69.51 fps, 3901.21 kb/s encoded 1442 frames, 69.12 fps, 3900.68 kb/s encoded 1442 frames, 69.41 fps, 3901.21 kb/s encoded 1442 frames, 20.73 fps, 3970.67 kb/s encoded 1442 frames, 20.70 fps, 3971.91 kb/s encoded 1442 frames, 20.78 fps, 3971.13 kb/s encoded 1442 frames, 20.72 fps, 3971.34 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3329.5 MHz FID range 6.0x - 9.0x Northbridge Intel X38 rev. 01 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 554.9 MHz (2:3) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 28°C (82°F) [0x1C] (SYSTIN) Temperature 1 41°C (105°F) [0x52] (CPUTIN) Temperature 2 24°C (75°F) [0x30] (AUXTIN) Temperature 0 39°C (102°F) [0x27] (TMPIN0) Temperature 1 42°C (107°F) [0x54] (TMPIN1) Temperature 2 37°C (98°F) [0x4A] (TMPIN2) Temperature 0 55°C (130°F) [0x2D] (Core #0) Temperature 1 56°C (132°F) [0x2C] (Core #1) Temperature 2 48°C (118°F) [0x34] (Core #2) Temperature 3 46°C (114°F) [0x36] (Core #3)
i7 860 with Turbo Mode off. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 62.33 fps, 3899.02 kb/s encoded 1442 frames, 64.42 fps, 3899.02 kb/s encoded 1442 frames, 62.75 fps, 3899.02 kb/s encoded 1442 frames, 62.41 fps, 3899.02 kb/s encoded 1442 frames, 25.86 fps, 3961.64 kb/s encoded 1442 frames, 25.92 fps, 3961.91 kb/s encoded 1442 frames, 25.86 fps, 3961.14 kb/s encoded 1442 frames, 25.92 fps, 3960.08 kb/s System Details -------------- Name Intel Core i7 860 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Stock frequency 2800 MHz Core Speed 2808.7 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 668.7 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) and same CPU @3.3GHz Results for x264.exe r1342 -------------------------- encoded 1442 frames, 74.66 fps, 3899.02 kb/s encoded 1442 frames, 72.84 fps, 3899.02 kb/s encoded 1442 frames, 68.42 fps, 3899.02 kb/s encoded 1442 frames, 74.19 fps, 3899.02 kb/s encoded 1442 frames, 26.83 fps, 3972.41 kb/s encoded 1442 frames, 25.83 fps, 3969.89 kb/s encoded 1442 frames, 24.29 fps, 3971.85 kb/s encoded 1442 frames, 26.47 fps, 3956.75 kb/s System Details -------------- Name Intel Core i7 860 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Stock frequency 2800 MHz Core Speed 3374.3 MHz
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 40.56 fps, 3899.26 kb/s encoded 1442 frames, 40.14 fps, 3899.26 kb/s encoded 1442 frames, 40.28 fps, 3899.26 kb/s encoded 1442 frames, 40.14 fps, 3899.26 kb/s encoded 1442 frames, 10.23 fps, 3970.57 kb/s encoded 1442 frames, 10.29 fps, 3971.05 kb/s encoded 1442 frames, 10.28 fps, 3971.57 kb/s encoded 1442 frames, 10.32 fps, 3970.81 kb/s System Details -------------- Name Intel Core 2 Duo E8400 Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Core Stepping C0 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3000 MHz Core Speed 3000.0 MHz FID range 6.0x - 9.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 333.3 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 46°C (114°F) [0x2E] (System) Temperature 1 41°C (105°F) [0x29] (CPU) Temperature 0 59°C (138°F) [0x29] (Core #0) Temperature 1 57°C (134°F) [0x2B] (Core #1)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 43.79 fps, 3899.26 kb/s encoded 1442 frames, 43.93 fps, 3899.26 kb/s encoded 1442 frames, 44.08 fps, 3899.26 kb/s encoded 1442 frames, 43.32 fps, 3899.26 kb/s encoded 1442 frames, 10.93 fps, 3971.63 kb/s encoded 1442 frames, 10.95 fps, 3971.57 kb/s encoded 1442 frames, 10.96 fps, 3970.75 kb/s encoded 1442 frames, 11.01 fps, 3971.00 kb/s System Details -------------- Name Intel Core 2 Duo E8500 Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz Core Stepping E0 Technology 45 nm Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3166 MHz Core Speed 3166.4 MHz FID range 6.0x - 9.5x Northbridge Intel P45/P43/G45/G43 rev. A2 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 400.0 MHz (5:6) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 2 (Build 6002) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 35°C (94°F) [0x23] (System) Temperature 1 33°C (91°F) [0x21] (CPU) Temperature 0 32°C (89°F) [0x44] (Core #0) Temperature 1 34°C (93°F) [0x42] (Core #1)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 67.72 fps, 3901.21 kb/s encoded 1442 frames, 68.87 fps, 3900.68 kb/s encoded 1442 frames, 69.32 fps, 3900.10 kb/s encoded 1442 frames, 69.64 fps, 3900.68 kb/s encoded 1442 frames, 20.92 fps, 3971.67 kb/s encoded 1442 frames, 20.85 fps, 3971.80 kb/s encoded 1442 frames, 20.90 fps, 3971.01 kb/s encoded 1442 frames, 20.83 fps, 3971.00 kb/s System Details -------------- Name Intel Core 2 Quad Q9550 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Core Stepping E0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2833 MHz Core Speed 3255.5 MHz FID range 6.0x - 8.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 478.8 MHz (4:5) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 38°C (100°F) [0x26] (System) Temperature 1 37°C (98°F) [0x25] (CPU) Temperature 0 51°C (123°F) [0x31] (Core #0) Temperature 1 45°C (112°F) [0x37] (Core #1) Temperature 2 42°C (107°F) [0x3A] (Core #2) Temperature 3 43°C (109°F) [0x39] (Core #3)
x264 HD Benchmark 3.14 The new x264 HD Benchmark 3.0 is here! This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors. Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. There are now 77 CPUs in this article, but we need MORE results! So please contribute your new benchmark results to this project! Check out the latest results! Link : x264 HD Benchmark 3.14
Maybe later Other results : Results for x264.exe r1342 -------------------------- encoded 1442 frames, 27.45 fps, 3899.26 kb/s encoded 1442 frames, 26.74 fps, 3899.26 kb/s encoded 1442 frames, 27.33 fps, 3899.26 kb/s encoded 1442 frames, 26.82 fps, 3899.26 kb/s encoded 1442 frames, 6.54 fps, 3971.04 kb/s encoded 1442 frames, 6.58 fps, 3971.55 kb/s encoded 1442 frames, 6.61 fps, 3971.80 kb/s encoded 1442 frames, 6.58 fps, 3971.15 kb/s System Details -------------- Name Intel Pentium T4300 Codename Penryn Specification Pentium(R) Dual-Core CPU T4300 @ 2.10GHz Core Stepping R0 Technology 45 nm Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Stock frequency 2100 MHz Core Speed 2094.2 MHz FID range 6.0x - 10.5x Northbridge Intel GM45/GM47 rev. 07 Southbridge Intel 82801IM (ICH9-M) rev. 03 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Memory Frequency 398.9 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 1024 KBytes, 4-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket P (478) (0x7) Temperature 0 53°C (127°F) [0x2F] (Core #0) Temperature 1 51°C (123°F) [0x31] (Core #1)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 72.84 fps, 3901.21 kb/s encoded 1442 frames, 72.10 fps, 3901.21 kb/s encoded 1442 frames, 73.13 fps, 3900.68 kb/s encoded 1442 frames, 72.73 fps, 3900.68 kb/s encoded 1442 frames, 22.68 fps, 3970.75 kb/s encoded 1442 frames, 22.68 fps, 3971.62 kb/s encoded 1442 frames, 22.67 fps, 3972.02 kb/s encoded 1442 frames, 22.65 fps, 3971.46 kb/s System Details -------------- Name AMD Phenom II X4 965 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 965 Processor Core Stepping RB-C3 Technology 45 nm Core Speed 3600.4 MHz Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 38°C (100°F) [0x26] (TMPIN0) Temperature 1 35°C (94°F) [0x23] (TMPIN1) Temperature 2 22°C (71°F) [0x16] (TMPIN2) Temperature 0 42°C (106°F) [0x14D] (Core #0) Temperature 1 42°C (107°F) [0x14F] (Core #1) Temperature 2 42°C (107°F) [0x150] (Core #2) Temperature 3 42°C (107°F) [0x150] (Core #3)
