The new x264 HD Benchmark 5.0 is here! This is the improved version of the x264 HD Benchmark 4.0 benchmark which had become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. We have completely revamped the benchmark by using a new 1080p video sample, as well as added both 64-bit and 32-bit tests using the latest r2200 x264 encoder. There have been other major changes under the hood as well, to make it a better stress test for newer multi-core processors. All these changes make the x264 HD Benchmark 5.0 the new best tool for testing the full capabilities of modern multi-core, multi-threaded processors. Do note that due to the changes, the results from x264 HD Benchmark 5.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. So please contribute your new benchmark results to this project! Link : x264 HD Benchmark 5.0
Here is my first one.. x264 HD BENCHMARK 5.0 RESULTS Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 89.31 fps, 7756.85 kb/s encoded 11812 frames, 87.61 fps, 7756.98 kb/s encoded 11812 frames, 87.34 fps, 7756.76 kb/s encoded 11812 frames, 91.68 fps, 7756.66 kb/s Pass 2 ------ encoded 11812 frames, 20.46 fps, 8000.18 kb/s encoded 11812 frames, 20.44 fps, 8000.09 kb/s encoded 11812 frames, 20.64 fps, 8000.26 kb/s encoded 11812 frames, 20.72 fps, 8000.29 kb/s System Details -------------- Name Intel Core i7 970 product System Product Name Codename Gulftown Specification Intel(R) Core(TM) i7 CPU 970 @ 3.20GHz Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Core Stepping B1 Technology 32 nm Stock frequency 3200 MHz Core Speed 4209.5 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 1T Command Rate 1T Command Rate 1T Memory Frequency 877.0 MHz (2:10) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 28°C (82°F) [0x1C] (SYSTIN) Temperature 1 29°C (83°F) [0x39] (CPUTIN) Temperature 2 36°C (95°F) [0x47] (AUXTIN) Temperature 0 54°C (129°F) [0x36] (SB) Temperature 1 58°C (136°F) [0x3A] (NB) And Thanx for god job
Why? Why not just: --quiet --preset slower --level 4.1 --crf 16 test-1080p.mpg -o nul Tech ARP - x264 HD Benchmark Ver. 5.0 These are not true.
Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 26.37 fps, 7775.81 kb/s encoded 5906 frames, 27.76 fps, 7775.81 kb/s encoded 5906 frames, 28.29 fps, 7775.81 kb/s encoded 5906 frames, 26.50 fps, 7775.81 kb/s Average: 27.23 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 6.08 fps, 8004.45 kb/s encoded 5906 frames, 6.08 fps, 8004.45 kb/s encoded 5906 frames, 5.96 fps, 8004.45 kb/s encoded 5906 frames, 6.05 fps, 8004.45 kb/s Average: 6.04 fps, 8004.45 kb/s System Details -------------- Name Intel Core i7 Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2640M CPU @ 2.80GHz Core Stepping D2 Technology 32 nm Stock frequency 2800 MHz Core Speed 798.1 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel QM67 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 665.2 MHz (1:5) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 988B rPGA (0x4) Temperature 0 25°C (76°F) [0xBA6] (THM_)
Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 29.84 fps, 7752.61 kb/s encoded 11812 frames, 31.71 fps, 7752.53 kb/s encoded 11812 frames, 31.53 fps, 7752.47 kb/s encoded 11812 frames, 32.25 fps, 7752.57 kb/s Average: 31.33 fps, 7752.54 kb/s Pass 2 ------ encoded 11812 frames, 6.00 fps, 8002.61 kb/s encoded 11812 frames, 6.00 fps, 8002.65 kb/s encoded 11812 frames, 5.99 fps, 8002.62 kb/s encoded 11812 frames, 5.98 fps, 8002.68 kb/s Average: 5.99 fps, 8002.64 kb/s System Details -------------- Name Intel Core i7 Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2640M CPU @ 2.80GHz Core Stepping D2 Technology 32 nm Stock frequency 2800 MHz Core Speed 798.1 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel QM67 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 665.2 MHz (1:5) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 988B rPGA (0x4) Temperature 0 25°C (76°F) [0xBA6] (THM_)
One of the reasons why we took so long to come up with this version is because we took a while to test both a single test based on the Constant RateFactor (CRF) as well as a 2-pass test, which cannot support CRF but must use a constant bitrate. What we found is that the CRF test would not adequately test the CPU's performance because it would be greatly restricted by the system's memory bandwidth. In fact, it was not able to even tax a Core i5-2430M mobile processor by more than 60% (peak). After numerous tests and adjustments, we felt that the best way forward was to return to the 2-pass, fixed-bitrate test because : 1. The first pass practically mimics the results of the single-pass CRF test, and is similarly limited by the system's memory bandwidth. Therefore, it would serve as an excellent test of a system's memory bandwidth. 2. The second pass was able to force an quad-core Core i7 processor to hit 98-100% usage on all cores. Therefore, it would be a much better CPU test than a single CRF test. As for your other comments, I can understand that the CRF method is able to deliver the same results (if not better) at less time. So yes, I think we should change that to something like... You can encode video in a single pass, but two passes will typically give a higher quality result. "You can encode video in a single pass, but two passes may give a higher quality result, at the expense of much greater encoding time." Or... You can encode video in a single pass, but the benchmark uses two passes to better examine the CPU's performance." As for the memory-intensive comment on the first pass, that was our observation after testing out both the first pass as well as the CRF test, as well as other quality settings.
x264 HD BENCHMARK 5.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to http://forums.techarp.com/reviews-articles/26957-x264-hd-benchmark-5-0-a.html ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 39.10 fps, 7775.81 kb/s encoded 5906 frames, 39.09 fps, 7775.81 kb/s encoded 5906 frames, 39.13 fps, 7775.81 kb/s encoded 5906 frames, 39.13 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 10.91 fps, 8004.45 kb/s encoded 5906 frames, 10.98 fps, 8004.45 kb/s encoded 5906 frames, 10.96 fps, 8004.45 kb/s encoded 5906 frames, 10.95 fps, 8004.45 kb/s System Details -------------- Name Intel Core i5 3570K Codename Ivy Bridge Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Specification PC3-12800J Specification PC3-12800J Core Stepping E1 Technology 22 nm Stock frequency 3400 MHz Core Speed 1600.2 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 10 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 27 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 41°C (105°F) [0x52] (CPUTIN) Temperature 2 49°C (120°F) [0x62] (AUXTIN) Temperature 3 46°C (114°F) [0x2E] (TMPIN3)
x264 HD BENCHMARK 5.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to http://forums.techarp.com/reviews-articles/26957-x264-hd-benchmark-5-0-a.html ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 50.45 fps, 7752.16 kb/s encoded 11812 frames, 49.92 fps, 7752.24 kb/s encoded 11812 frames, 50.53 fps, 7752.19 kb/s encoded 11812 frames, 49.98 fps, 7752.25 kb/s Pass 2 ------ encoded 11812 frames, 11.24 fps, 8002.84 kb/s encoded 11812 frames, 11.21 fps, 8002.64 kb/s encoded 11812 frames, 11.22 fps, 8002.85 kb/s encoded 11812 frames, 11.21 fps, 8002.80 kb/s System Details -------------- Name Intel Core i5 3570K Codename Ivy Bridge Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Specification PC3-12800J Specification PC3-12800J Core Stepping E1 Technology 22 nm Stock frequency 3400 MHz Core Speed 1600.2 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 10 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 27 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 41°C (104°F) [0x51] (CPUTIN) Temperature 2 50°C (121°F) [0x64] (AUXTIN) Temperature 3 45°C (112°F) [0x2D] (TMPIN3)
Intel 3570K @ 4.2Ghz x264 HD BENCHMARK 5.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to http://forums.techarp.com/reviews-articles/26957-x264-hd-benchmark-5-0-a.html ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 60.63 fps, 7752.17 kb/s encoded 11812 frames, 60.47 fps, 7752.25 kb/s encoded 11812 frames, 60.32 fps, 7752.21 kb/s encoded 11812 frames, 60.23 fps, 7752.44 kb/s Pass 2 ------ encoded 11812 frames, 13.75 fps, 8002.74 kb/s encoded 11812 frames, 13.69 fps, 8002.84 kb/s encoded 11812 frames, 13.65 fps, 8002.84 kb/s encoded 11812 frames, 13.65 fps, 8002.78 kb/s System Details -------------- Name Intel Core i5 3570K Codename Ivy Bridge Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Specification PC3-12800J Specification PC3-12800J Core Stepping E1 Technology 22 nm Stock frequency 3400 MHz Core Speed 1600.2 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel Z77 rev. 04 CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 10 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 27 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 50°C (121°F) [0x63] (CPUTIN) Temperature 2 51°C (123°F) [0x66] (AUXTIN) Temperature 3 56°C (132°F) [0x38] (TMPIN3)
Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 62.11 fps, 7753.92 kb/s encoded 11812 frames, 60.88 fps, 7753.88 kb/s encoded 11812 frames, 59.26 fps, 7753.85 kb/s encoded 11812 frames, 61.99 fps, 7753.68 kb/s Pass 2 ------ encoded 11812 frames, 12.98 fps, 8002.26 kb/s encoded 11812 frames, 12.70 fps, 8002.29 kb/s encoded 11812 frames, 12.78 fps, 8002.27 kb/s encoded 11812 frames, 12.83 fps, 8002.40 kb/s System Details -------------- HWiNFO32 Version 3.96-1640 ---------------------------------------------------------------- [Current Computer] Computer Brand Name: Hewlett-Packard HP Pavilion dv7 Notebook PC [Operating System] Operating System: Microsoft Windows 7 Home Premium (x64) Build 7601 Service Pack: Service Pack 1 Central Processor(s) ------------------------------------------------------ [CPU Unit Count] Number Of Processor Packages (Physical): 1 Number Of Processors Cores: 4 Number Of Logical Processors: 8 Intel Core i7-3720QM ------------------------------------------------------ [General Information] Processor Name: Intel Core i7-3720QM Original Processor Frequency: 2600.0 MHz Original Processor Frequency [MHz]: 2600 CPU ID: 000306A9 CPU Brand Name: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz CPU Vendor: GenuineIntel CPU Thermal Design Power (TDP): 45.0 W CPU IA Cores Thermal Design Current (TDC): 112.0 A CPU GT Cores Thermal Design Current (TDC): 50.0 A CPU Power Limits (Max): Power = Unlimited, Time = Unlimited CPU Type: Production Unit Number of CPU Cores: 4 Number of Logical CPUs: 8 [Operating Points] CPU LFM (Minimum): 1200.0 MHz = 12.00 x 100.0 MHz CPU HFM (Maximum): 2600.0 MHz = 26.00 x 100.0 MHz CPU Turbo: 3600.0 MHz = 36.00 x 100.0 MHz [Unlocked] CPU Current: 1197.4 MHz = 12.00 x 99.8 MHz @ 0.9106 V CPU Bus Type: Intel Direct Media Interface (DMI) v2.0 Maximum DMI Link Speed: 5.0 GT/s Current DMI Link Speed: 5.0 GT/s [Cache and TLB] [Standard Feature Flags] [Extended Feature Flags] [Enhanced Features] [CPU IVB Features] [Memory Ranges] [MTRRs] Motherboard --------------------------------------------------------------- [Computer] Computer Brand Name: Hewlett-Packard HP Pavilion dv7 Notebook PC [Motherboard] Motherboard Model: Hewlett-Packard 181F Motherboard Chipset: Intel HM77 (Panther Point) Motherboard Slots: 4xPCI Express x1, 6xPCI Express x2, 1xPCI Express x8 PCI Express Version Supported: v3.0 USB Version Supported: v3.0 [PCH Features] USB Port Count: 14 ports RAID Capability: RAID0/1/5/10 + Smart Response Technology SATA Ports 2 and 3: Supported SATA Port 1 6 Gb/s: Supported SATA Port 0 6 Gb/s: Supported PCI Interface: Not Supported PCI Express Ports 5 and 6: Supported USB Redirect (USBr): Not Supported Intel Anti-Theft Technology: Not Supported PCI Express Ports 7 and 8: Supported PCH Integrated Graphics Support: Supported Data Center Manageability Interface (DCMI): Supported Node Manager: Supported [BIOS] BIOS Manufacturer: Insyde Software BIOS Date: 04/19/2012 BIOS Version: F.09 EFI BIOS: Capable Super-IO/LPC Chip: Unknown Physical Memory Array ----------------------------------------------------- Array Location: System board Array Use: System memory Error Detecting Method: None Memory Capacity: 16777216 KBytes Memory Devices: 2 Memory Device ------------------------------------------------------------- Total Width: 64 bits Data Width: 64 bits Device Size: 4096 MBytes Device Form Factor: SODIMM Device Locator: Bottom-Slot 1(top) Bank Locator: BANK 0 Device Type: Unknown Device Type Detail: Synchronous Memory Speed: 1600 MHz Manufacturer: Samsung Serial Number: C11731ED Part Number: M471B5273DH0-CK0 Asset Tag: Unknown Memory Device ------------------------------------------------------------- Total Width: 64 bits Data Width: 64 bits Device Size: 4096 MBytes Device Form Factor: SODIMM Device Locator: Bottom-Slot 2(under) Bank Locator: BANK 2 Device Type: Unknown Device Type Detail: Synchronous Memory Speed: 1600 MHz Manufacturer: Samsung Serial Number: C11731E4 Part Number: M471B5273DH0-CK0 Asset Tag: Unknown Processor ----------------------------------------------------------------- Processor Manufacturer: Intel(R) Corporation Processor Version: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz External Clock: 100 MHz Maximum Clock Supported: 4000 MHz Current Clock: 2600 MHz CPU Socket: Populated CPU Status: Enabled Processor Type: Central Processor Processor Voltage: 1.0 V Processor Upgrade: Unknown Socket Designation: U3E1
Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 35.29 fps, 7775.81 kb/s encoded 5906 frames, 35.36 fps, 7775.81 kb/s encoded 5906 frames, 35.43 fps, 7775.81 kb/s encoded 5906 frames, 35.44 fps, 7775.81 kb/s Average: 35.38 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 9.62 fps, 8004.45 kb/s encoded 5906 frames, 9.62 fps, 8004.45 kb/s encoded 5906 frames, 9.62 fps, 8004.45 kb/s encoded 5906 frames, 9.61 fps, 8004.45 kb/s Average: 9.62 fps, 8004.45 kb/s System Details -------------- Name Intel Core i5 2400 Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz Core Stepping D2 Technology 32 nm Stock frequency 3100 MHz Core Speed 1596.7 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel Q65 rev. B2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 665.3 MHz (1:5) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 32-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1)
Core 2 Quad 9300 (32 bit) Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 18.46 fps, 7775.81 kb/s encoded 5906 frames, 20.46 fps, 7775.81 kb/s encoded 5906 frames, 18.50 fps, 7775.81 kb/s encoded 5906 frames, 19.26 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 5.12 fps, 8004.45 kb/s encoded 5906 frames, 5.19 fps, 8004.45 kb/s encoded 5906 frames, 5.24 fps, 8004.45 kb/s encoded 5906 frames, 5.15 fps, 8004.45 kb/s System Details -------------- Name Intel Core 2 Quad Q9300 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz Core Stepping M1 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2500 MHz Core Speed 2499.9 MHz FID range 6.0x - 7.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (5:6) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 38°C (100°F) [0x26] (System) Temperature 1 49°C (120°F) [0x31] (CPU)
Core 2 Quad 9300 (64 bit) Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 24.82 fps, 7752.42 kb/s encoded 11812 frames, 24.50 fps, 7752.53 kb/s encoded 11812 frames, 24.83 fps, 7752.55 kb/s encoded 11812 frames, 24.69 fps, 7752.52 kb/s Pass 2 ------ encoded 11812 frames, 5.12 fps, 8002.69 kb/s encoded 11812 frames, 5.12 fps, 8002.59 kb/s encoded 11812 frames, 5.22 fps, 8002.63 kb/s encoded 11812 frames, 5.77 fps, 8002.58 kb/s System Details -------------- Name Intel Core 2 Quad Q9300 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz Core Stepping M1 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2500 MHz Core Speed 2000.0 MHz FID range 6.0x - 7.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (5:6) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 39°C (102°F) [0x27] (System) Temperature 1 49°C (120°F) [0x31] (CPU)
Core i7 3612QM (64 bit) A friend emailed me these results. The CPU is a Core i7 3612QM (Ivy Bridge). The base frequency is 2.1 GHz. The maximum single core frequency is 3.1 GHz More info about this CPU: Intel® Core? i7-3612QM Processor (6M Cache, up to 3.10 GHz) rPGA Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 51.66 fps, 7753.88 kb/s encoded 11812 frames, 50.53 fps, 7754.28 kb/s encoded 11812 frames, 51.80 fps, 7754.10 kb/s encoded 11812 frames, 51.36 fps, 7754.27 kb/s Pass 2 ------ encoded 11812 frames, 10.84 fps, 8002.25 kb/s encoded 11812 frames, 10.81 fps, 8002.24 kb/s encoded 11812 frames, 10.83 fps, 8002.25 kb/s encoded 11812 frames, 10.80 fps, 8002.28 kb/s The performance is very good considering it is a 35 watt CPU.
I ran the benchmark twice, and neither time did it output my system information. I'm not sure why. I have a Core i7 920. It is running at 2.87MHz, with default settings, Turbo and Hyperthreading are on.
Did you run the "Run Benchmark.vbs" file? Then it should check whether you have your UAC (User Account Control) turned on and will prompt you to turn it off if it's turned on. Once you've done that, you'll need to reboot your system. Here's a clearer picture on how to turn off UAC - How to Disable and Turn Off UAC in Windows 7 My Digital Life UAC needs to be turned off to allow cpuz to grab information from the system as it needs Administrator rights to run.
Athlon 64 x2 4200+ (32 bit) Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 9.25 fps, 7772.80 kb/s encoded 5906 frames, 9.57 fps, 7772.80 kb/s encoded 5906 frames, 9.63 fps, 7772.80 kb/s encoded 5906 frames, 9.53 fps, 7772.80 kb/s Pass 2 ------ encoded 5906 frames, 2.01 fps, 8005.80 kb/s encoded 5906 frames, 2.02 fps, 8005.80 kb/s encoded 5906 frames, 2.02 fps, 8005.80 kb/s encoded 5906 frames, 2.02 fps, 8005.80 kb/s System Details -------------- Name AMD Athlon 64 X2 4200+ Codename Manchester Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ Core Stepping BH-E4 Technology 90 nm vendor Gigabyte Technology Co., Ltd. Stock frequency 2200 MHz Core Speed 2213.3 MHz Northbridge NVIDIA nForce4 rev. A3 Southbridge NVIDIA nForce4 MCP rev. A3 CAS# latency (CL) 2.5 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 7 Command Rate (CR) 2T Memory Frequency 158.1 MHz (CPU/14) Memory Type DDR Memory Size 3072 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 32-bit (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket 939 Temperature 0 25°C (76°F) [0x19] (TMPIN0) Temperature 1 55°C (130°F) [0x37] (TMPIN1) Temperature 2 72°C (161°F) [0x48] (TMPIN2)
That's the funny thing - I have (and had) UAC completely turned off. It is on the option "Never Notify". BTW, when I export the text file manually from CPU-Z with my system info, it contains the info that Turbo is turned on. Is it impossible for you to get that info programatically?
