x264 HD Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Mar 15, 2008.
  1. Dashken
    Dashken Administrator!
    The x264 HD Benchmark is the “High Definition version” of the x264 Benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts.
    The new x264 HD Benchmark ups the ante by using a new 720p24 high-definition video clip. Therefore, it will be a great test of the processor’s ability to encode HD quality video streams. Give it a try and let us know how your processor fares!
    Here's a quote from the article :-
    Link : x264 HD Benchmark
  2. Mac Daddy
    Cool stuff I am still awaiting my viddy card for the new system and will run both X264 tests stock and O/C Dashken. I tell everyone about this as I feel it is one of the only true CPU benchmarking tests out there Cheers Graysky :cool:
  3. iXX
    iXX Newbie
    results from Intel Skulltrail OC
    ---------- RUN1PASS1.LOG
    encoded 1442 frames, 82.25 fps, 3904.94 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1442 frames, 82.11 fps, 3904.94 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1442 frames, 81.82 fps, 3904.94 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1442 frames, 81.46 fps, 3904.94 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1442 frames, 41.24 fps, 3974.08 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1442 frames, 41.22 fps, 3974.08 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1442 frames, 41.14 fps, 3974.08 kb/s
    ---------- RUN4PASS2.LOG
    Spec is
    Intel Skultrail D5400XS, i5400 express chipset
    Intel Xeon X5460 o/c 3.8GHz (9.5x400)
    8GB DDR2 FB-DIMM 800MHz 5-5-5-18
    Vista Ultimate x64
  4. graysky
    graysky ARP Reviewer
    Cool man, judging by your results, they must be for the HD benchmark, no? I would think that system would give much higher values for the SD benchmark.
    Can a mod please move his reply to the HD benchmark section to avoid confusion?
    Thanks and thanks for the results!
  5. graysky
    Rock on man. Thanks.
  6. paulsz28
    paulsz28 Newbie
    X2 5200+
    encoded 1442 frames, 26.57 fps, 3905.08 kb/s
    encoded 1442 frames, 26.46 fps, 3905.08 kb/s
    encoded 1442 frames, 26.03 fps, 3905.08 kb/s
    encoded 1442 frames, 26.49 fps, 3905.08 kb/s
    encoded 1442 frames, 6.25 fps, 3942.92 kb/s
    encoded 1442 frames, 6.31 fps, 3942.92 kb/s
    encoded 1442 frames, 6.30 fps, 3942.92 kb/s
    encoded 1442 frames, 6.29 fps, 3942.92 kb/s
    X2 5200+ (Windsor F2), 13x200
    [email protected] DDR2 4-4-3-8
    ATI Xpress 3200 (RD580),
    Vista Ultimate 32-bit
  7. graysky
    Got it paul, thanx!
  8. vyedmic
    vyedmic Newbie
    E6600
    encoded 1442 frames, 27.22 fps, 3905.08 kb/s
    encoded 1442 frames, 32.68 fps, 3905.08 kb/s
    encoded 1442 frames, 32.20 fps, 3905.08 kb/s
    encoded 1442 frames, 32.18 fps, 3905.08 kb/s
    encoded 1442 frames, 8.02 fps, 3942.92 kb/s
    encoded 1442 frames, 8.03 fps, 3942.92 kb/s
    E6600 Conroe @ 2.88 GHz
    9*320
    G965
    DDR2 960Mhz 5-5-5-18
    FSB:DRAM 2:3
    Windows XP x86 SP2
    Cheers,
    Martin
  9. Rzooq
    Rzooq Newbie
    encoded 1442 frames, 31.90 fps, 3905.08 kb/s
    encoded 1442 frames, 31.99 fps, 3905.08 kb/s
    encoded 1442 frames, 31.92 fps, 3905.08 kb/s
    encoded 1442 frames, 31.88 fps, 3905.08 kb/s
    encoded 1442 frames, 8.13 fps, 3942.92 kb/s
    encoded 1442 frames, 8.14 fps, 3942.92 kb/s
    encoded 1442 frames, 8.15 fps, 3942.92 kb/s
    C2D E8200 (Wolfdale), 8x340,
    X38, DDR2, 5-5-5-18 @ 510 MHz (FSB:DRAM 2:3)
    XP Pro SP2 32-bit
    Cheers
  10. graysky
    Cool, thanks guys, added and will update soon.
  11. wolf2009
    wolf2009 Newbie
    encoded 1442 frames, 8.54 fps, 3902.58 kb/s
    encoded 1442 frames, 8.58 fps, 3902.58 kb/s
    encoded 1442 frames, 8.62 fps, 3902.58 kb/s
    encoded 1442 frames, 8.60 fps, 3902.58 kb/s
    encoded 1442 frames, 2.09 fps, 3936.11 kb/s
    AMD Athlon Xp 2800+ Barton , 166.4 x 12.5
    nforce 2 SPP, DDR , 2.5-3-3-7 @ 166 Mhz (FSB: DRAM 1:1)
    Xp Pro SP2 32 Bit
  12. sbarcena
    sbarcena Newbie
    encoded 1442 frames, 35.33 fps, 3905.08 kb/s
    encoded 1442 frames, 35.62 fps, 3905.08 kb/s
    encoded 1442 frames, 35.48 fps, 3905.08 kb/s
    encoded 1442 frames, 35.61 fps, 3905.08 kb/s
    encoded 1442 frames, 8.99 fps, 3942.92 kb/s
    encoded 1442 frames, 9.01 fps, 3942.92 kb/s
    encoded 1442 frames, 9.04 fps, 3942.92 kb/s
    encoded 1442 frames, 9.02 fps, 3942.92 kb/s
    Core2Duo E6750
    8x1600
    Nvidia nForce 680i SLI SPP
    DDR2 550 5-5-5-18
  13. graysky
  14. Teskox
    Teskox Newbie
    encoded 1442 frames, 26.66 fps, 3905.08 kb/s
    encoded 1442 frames, 26.52 fps, 3905.08 kb/s
    encoded 1442 frames, 26.61 fps, 3905.08 kb/s
    encoded 1442 frames, 26.47 fps, 3905.08 kb/s
    encoded 1442 frames, 6.71 fps, 3942.92 kb/s
    encoded 1442 frames, 6.69 fps, 3942.92 kb/s
    encoded 1442 frames, 6.70 fps, 3942.92 kb/s
    Mbp running Boot Camp xp sp2 32 home
    T7700 (12x200 MHz)
    GM 965 Chipset (edit)
    DDR2 333mhz 5.5.5.15
  15. Maikel205
    Maikel205 Newbie
    results
    encoded 1442 frames, 56.87 fps, 3904.62 kb/s
    encoded 1442 frames, 56.72 fps, 3904.62 kb/s
    encoded 1442 frames, 56.48 fps, 3904.62 kb/s
    encoded 1442 frames, 56.89 fps, 3904.62 kb/s
    encoded 1442 frames, 13.78 fps, 3953.18 kb/s
    encoded 1442 frames, 13.76 fps, 3953.18 kb/s
    encoded 1442 frames, 13.85 fps, 3953.18 kb/s
    encoded 1442 frames, 13.81 fps, 3953.18 kb/s
    Phenom 9600 Agena, 13x200
    [email protected] DDR2 5-5-5-15
    ATI RD790
    Vista 32-bit
  16. graysky
    Wow dude, that system smokes the benchmark - especially the 2nd pass. Judging by that motherboard you have you must be running dual processors? If it's a single, that FB memory you have rocks.
  17. graysky
    @Maikel205 - Thanks for the result! Always nice to see some AMD quads, your data is now live.
  18. Maikel205
    Maikel205 Newbie
    you need to correct this:
    core speed of my phenom is 2600mhz; mem speed is 1066mhz.
  19. graysky
    Ooops, fixed and will update ASAP.
  20. Teskox
    Teskox Newbie
    Computer #2 (File Server)
    encoded 1442 frames, 27.97 fps, 3905.08 kb/s
    encoded 1442 frames, 28.03 fps, 3905.08 kb/s
    encoded 1442 frames, 27.87 fps, 3905.08 kb/s
    encoded 1442 frames, 27.84 fps, 3905.08 kb/s
    encoded 1442 frames, 6.57 fps, 3942.92 kb/s
    encoded 1442 frames, 6.56 fps, 3942.92 kb/s
    Athlon 64 x2 4400+ oc'd
    2791 MHz (11.5 x 243 FSB)
    M2A-VM (690G)
    DDR2 400 MHz 5.5.5.15
    xp64 sp2
    Not much faster then my Macbook Pro ...
    2 systems to go!
