I'm running Vista Ultimate 32-bit so you need to correct that...my bad...will run un-overclocked results tonight
Sorry about that guys, thanks for the proof reading! All errors have been corrected and will update shortly.
Phenom 2400mhz results: ---------- RUN1PASS1.LOG encoded 1442 frames, 52.65 fps, 3904.67 kb/s ---------- RUN2PASS1.LOG encoded 1442 frames, 52.50 fps, 3904.67 kb/s ---------- RUN3PASS1.LOG encoded 1442 frames, 52.60 fps, 3904.67 kb/s ---------- RUN4PASS1.LOG encoded 1442 frames, 52.55 fps, 3904.67 kb/s ---------- RUN1PASS2.LOG encoded 1442 frames, 12.77 fps, 3952.97 kb/s ---------- RUN2PASS2.LOG encoded 1442 frames, 12.77 fps, 3952.97 kb/s ---------- RUN3PASS2.LOG encoded 1442 frames, 12.76 fps, 3952.97 kb/s ---------- RUN4PASS2.LOG encoded 1442 frames, 12.79 fps, 3952.97 kb/s Phenom 9600 (Black Edition with unlocked multiplier) Agena, 12x200 4GB@1066MHz DDR2 5-5-5-15 ATI RD790 Vista 32-bit
@Maikel205 and willco - thanks for the data. Just a quick question for you both: are you sure about your memory clock rate? For Maikel, a fsb:dram divider for your 200:1066 = 3:8 which is kinda odd (at least for intel systems, I dunno about AMD these days) and for willco, your fsb:dram divider is 288:800 = 5:7 which is kinda odd for an intel system. You can get the info from the memory tab of CPU-Z. THanks!
---------- RUN1PASS1.LOG encoded 1442 frames, 66.30 fps, 3905.42 kb/s ---------- RUN2PASS1.LOG encoded 1442 frames, 66.25 fps, 3905.42 kb/s ---------- RUN3PASS1.LOG encoded 1442 frames, 66.54 fps, 3905.42 kb/s ---------- RUN4PASS1.LOG encoded 1442 frames, 66.35 fps, 3905.42 kb/s ---------- RUN1PASS2.LOG encoded 1442 frames, 18.12 fps, 3952.85 kb/s ---------- RUN2PASS2.LOG encoded 1442 frames, 18.15 fps, 3952.85 kb/s ---------- RUN3PASS2.LOG encoded 1442 frames, 18.13 fps, 3952.85 kb/s ---------- RUN4PASS2.LOG encoded 1442 frames, 18.07 fps, 3952.85 kb/s Intel C2Q6600 8x400 Asus P5E x38 (6.01 bios) G.Skill DDR2 800 4.4.3.5 Xp 32-bit
CPU : AMD Athlon XP Barton @2671 Mhz (13x205.5) MB chipset: Nvidia nForce2 Ultra 400 Memory : DDR1 411 Mhz (2.5/3/3/7) OS : WinXP Pro Sp2 x86 ---------- RUN1PASS1.LOG encoded 1442 frames, 10.87 fps, 3902.58 kb/s ---------- RUN2PASS1.LOG encoded 1442 frames, 10.87 fps, 3902.58 kb/s ---------- RUN3PASS1.LOG encoded 1442 frames, 10.85 fps, 3902.58 kb/s ---------- RUN4PASS1.LOG encoded 1442 frames, 10.87 fps, 3902.58 kb/s ---------- RUN1PASS2.LOG encoded 1442 frames, 2.67 fps, 3936.11 kb/s ---------- RUN2PASS2.LOG encoded 1442 frames, 2.67 fps, 3936.11 kb/s ---------- RUN3PASS2.LOG encoded 1442 frames, 2.67 fps, 3936.11 kb/s ---------- RUN4PASS2.LOG encoded 1442 frames, 2.67 fps, 3936.11 kb/s
Thanks for the data, guys. @canuseemygrapes - is your ram running @ 800 MHz? @vandenk - which barton do you have? like 3000+, 3200+, etc.
Yes overcloking setting : CPU : AMD Athlon XP Barton @2671 Mhz (13x205.5) MB chipset: Nvidia nForce2 Ultra 400 Memory : DDR1 411 Mhz (205.5 in cpuz) (2.5/3/3/7) OS : WinXP Pro Sp2 x86
New result @ max overcloking : CPU : AMD Athlon XP Barton @2795 Mhz (13x215) MB chipset: Nvidia nForce2 Ultra 400 Memory : DDR1 430 Mhz (215 in cpuz) (2.5/3/3/7) OS : WinXP Pro Sp2 x86 ---------- RUN1PASS1.LOG encoded 1442 frames, 11.29 fps, 3902.58 kb/s ---------- RUN2PASS1.LOG encoded 1442 frames, 11.32 fps, 3902.58 kb/s ---------- RUN3PASS1.LOG encoded 1442 frames, 11.29 fps, 3902.58 kb/s ---------- RUN4PASS1.LOG encoded 1442 frames, 11.29 fps, 3902.58 kb/s ---------- RUN1PASS2.LOG encoded 1442 frames, 2.81 fps, 3936.11 kb/s ---------- RUN2PASS2.LOG encoded 1442 frames, 2.81 fps, 3936.11 kb/s ---------- RUN3PASS2.LOG encoded 1442 frames, 2.80 fps, 3936.11 kb/s ---------- RUN4PASS2.LOG encoded 1442 frames, 2.80 fps, 3936.11 kb/s
OK Graysky this is the new system with stock settings. Checked the result table and we just have 2 E6550 systems and they are both overclocked so this should be a good reference One thing to note I overrode the Gigabyte default of DDR800 for my ram as it is PC8000 ram and rated @ 1000Mhz out of the package. So made a slight change to compensate and included info in screenshots. Just noted the (CR) is set to 2T read it should be 1T New system: E6550 @ 2.3G (stock) GA-X38-DQ6 OCZ ReaperX HPC PC8000 @1066Mhz Gainward Bliss 9600GT 512 Win XP SP2 Code: ---------- RUN1PASS1.LOG encoded 1442 frames, 27.18 fps, 3905.08 kb/s ---------- RUN2PASS1.LOG encoded 1442 frames, 27.24 fps, 3905.08 kb/s ---------- RUN3PASS1.LOG encoded 1442 frames, 27.20 fps, 3905.08 kb/s ---------- RUN4PASS1.LOG encoded 1442 frames, 27.13 fps, 3905.08 kb/s ---------- RUN1PASS2.LOG encoded 1442 frames, 6.65 fps, 3942.92 kb/s ---------- RUN2PASS2.LOG encoded 1442 frames, 6.66 fps, 3942.92 kb/s ---------- RUN3PASS2.LOG encoded 1442 frames, 6.66 fps, 3942.92 kb/s ---------- RUN4PASS2.LOG encoded 1442 frames, 6.66 fps, 3942.92 kb/s
