x264 HD Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Mar 15, 2008.
  1. yurex
    yurex Newbie
    Another one test result...
    Results for x264.exe v0.58.747
    encoded 1442 frames, 44.52 fps, 3905.08 kb/s
    encoded 1442 frames, 44.58 fps, 3905.08 kb/s
    encoded 1442 frames, 44.50 fps, 3905.08 kb/s
    encoded 1442 frames, 44.43 fps, 3905.08 kb/s
    encoded 1442 frames, 11.43 fps, 3942.92 kb/s
    encoded 1442 frames, 11.45 fps, 3942.92 kb/s
    Results for x264.exe v0.59.819M
    encoded 1442 frames, 50.43 fps, 3889.23 kb/s
    encoded 1442 frames, 50.38 fps, 3889.11 kb/s
    encoded 1442 frames, 50.35 fps, 3887.05 kb/s
    encoded 1442 frames, 50.40 fps, 3887.13 kb/s
    encoded 1442 frames, 12.86 fps, 3953.39 kb/s
    encoded 1442 frames, 12.86 fps, 3953.35 kb/s
    encoded 1442 frames, 12.85 fps, 3953.33 kb/s
    System Details
    Name Intel Core 2 Duo E8200
    Codename Wolfdale
    Specification Intel(R) Core(TM)2 Duo CPU E8200 @ 2.66GHz
    Core Stepping C0
    Technology 45 nm
    Stock frequency 2666 MHz
    Core Speed 3840.0 MHz (8.0 x 480.0 MHz)
    FID range 6.0x - 8.0x
    Northbridge Intel P35/G33/G31 rev. A2
    Southbridge Intel 82801IR (ICH9R) rev. 02
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 18
    Command Rate 2T
    Memory Frequency 480.0 MHz (1:1)
    Memory Type DDR2
    Memory Size 3328 MBytes
    Channels Dual (Symmetric)
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    max VID 1.225 V
    Voltage sensor 0 1.38 Volts [0xAD] (CPU VCORE)
    Number of processors 1
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
    Package Socket 775 LGA (platform ID = 0h)
    Temperature sensor 0 37°C (98°F) [0x25] (SYSTIN)
    Temperature sensor 1 56°C (132°F) [0x70] (CPUTIN)
    Temperature sensor 2 127°C (260°F) [0xFE] (AUXTIN)
    Temperature sensor 0 70°C (157°F) [0x23] (core #0)
    Temperature sensor 1 70°C (157°F) [0x23] (core #1)
    Temperature sensor 0 56°C (132°F) [0x38] (GPU Core)
  2. graysky
    graysky ARP Reviewer
    got it, thanks
  3. JetJock_fl
    JetJock_fl Newbie
    MotherBoard is a Tyan 2466-4m. Dual single core CPU. It's getting long in the tooth and my needs are moving to more encoding so it looks like I will be upgrading. I was hoping to get a processor/motherboard combo that would encode a HD movie in 5 to 10 secs. I see from the results that is a little optimistic.
    x264 HD BENCHMARK RESULTS
    Please copy/paste everything below the line into the forum post to report your data
    encoded 1442 frames, 15.33 fps, 3905.08 kb/s
    encoded 1442 frames, 15.14 fps, 3905.08 kb/s
    encoded 1442 frames, 15.07 fps, 3905.08 kb/s
    encoded 1442 frames, 15.16 fps, 3905.08 kb/s
    encoded 1442 frames, 4.01 fps, 3942.92 kb/s
    encoded 1442 frames, 4.00 fps, 3942.92 kb/s
    encoded 1442 frames, 15.80 fps, 3889.07 kb/s
    encoded 1442 frames, 15.85 fps, 3886.88 kb/s
    encoded 1442 frames, 15.81 fps, 3889.96 kb/s
    encoded 1442 frames, 15.79 fps, 3889.96 kb/s
    encoded 1442 frames, 4.21 fps, 3953.43 kb/s
    encoded 1442 frames, 4.19 fps, 3953.55 kb/s
    encoded 1442 frames, 4.21 fps, 3953.35 kb/s
    encoded 1442 frames, 4.18 fps, 3953.35 kb/s
    System Details
    Name AMD Athlon MP
    Name AMD Athlon MP
    Codename Barton
    Codename Barton
    Specification AMD Athlon(tm) MP 2800+
    Specification AMD Athlon(tm) Processor
    Core Stepping
    Core Stepping
    Technology 0.13 um
    Technology 0.13 um
    Core Speed 2134.3 MHz (16.0 x 133.4 MHz)
    Northbridge AMD AMD-762 rev. A1
    Southbridge AMD AMD-768 rev. 05
    CAS# 2.0
    RAS# to CAS# 3
    RAS# Precharge 3
    Cycle Time (tRAS) 6
    Memory Frequency 133.4 MHz (1:1)
    Memory Type DDR
    Memory Size 1024 MBytes
    Number of processors 2
    Number of threads 2
    Number of threads 1 (max 1)
    L2 cache 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE
    Package Socket A (462)
  4. Mac Daddy
    Heres an oldie for you Graysky its not a Pentium its a Celeron and I have a reason for posting this ....
    Don't faint on the awesome speed and power lol :haha: :haha:
    encoded 1442 frames, 3.24 fps, 3902.58 kb/s
    encoded 1442 frames, 3.32 fps, 3902.58 kb/s
    encoded 1442 frames, 3.31 fps, 3902.58 kb/s
    encoded 1442 frames, 3.29 fps, 3902.58 kb/s
    encoded 1442 frames, 0.84 fps, 3936.11 kb/s
    encoded 1442 frames, 0.86 fps, 3936.11 kb/s
    encoded 1442 frames, 0.89 fps, 3936.11 kb/s
    encoded 1442 frames, 0.90 fps, 3936.11 kb/s
    encoded 1442 frames, 3.79 fps, 3882.40 kb/s
    encoded 1442 frames, 3.97 fps, 3882.40 kb/s
    encoded 1442 frames, 3.74 fps, 3882.40 kb/s
    encoded 1442 frames, 3.77 fps, 3882.40 kb/s
    encoded 1442 frames, 0.98 fps, 3947.86 kb/s
    encoded 1442 frames, 0.97 fps, 3947.86 kb/s
    encoded 1442 frames, 0.96 fps, 3947.86 kb/s
    System Details
    Name Intel Celeron
    Codename Northwood
    Specification Intel(R) Celeron(R) CPU 2.60GHz
    Core Stepping D1
    Technology 0.13 um
    Stock frequency 2600 MHz
    Core Speed 3121.6 MHz (26.0 x 120.1 MHz)
    Northbridge VIA P4M890 rev. 00
    Southbridge VIA VT8237 rev. 00
    CAS# 2.5
    RAS# to CAS# 3
    RAS# Precharge 3
    Cycle Time (tRAS) 7
    Command Rate 2T
    Memory Frequency 200.1 MHz (3:5)
    Memory Type DDR
    Memory Size 1984 MBytes
    Channels Single
    Voltage sensor 0 1.52 Volts [0x5F] (CPU VCore)
    Number of threads 1
    L2 cache 128 KBytes, 2-way set associative, 64-byte line size
    Package Socket 478 mPGA (platform ID = 2h)
    Temperature sensor 0 34°C (93°F) [0x22] (TMPIN0)
    Temperature sensor 1 35°C (94°F) [0x45] (TMPIN1)
  5. graysky
    Got 'em guys and will include in next update!
    @MD - if you think your numbers are slow, there is a guy running it on his pentium-200 MMX which should be even slower than my PII-450 which currently holds the low speed record :)
  6. Mac Daddy
    Hee hee thats cool man I actually did a couple of mods on this one. Mods are working fine but this cheap ASrock mobo ain't liking it lol. Will post up soon on the O/C section when I get everything stabilized ;)
  7. Dashken
    Dashken Administrator!
    I'll try again. Hmm... :think:
  8. voron
    voron Newbie
    Penrium Dual-Core E2180, 10x266, P35, 5-5-5-15 @ 532MHz, Vista Ultimate SP1.
    encoded 1442 frames, 28.42 fps, 3905.08 kb/s
    encoded 1442 frames, 29.07 fps, 3905.08 kb/s
    encoded 1442 frames, 28.96 fps, 3905.08 kb/s
    encoded 1442 frames, 29.24 fps, 3905.08 kb/s
    encoded 1442 frames, 7.08 fps, 3942.92 kb/s
    encoded 1442 frames, 7.14 fps, 3942.92 kb/s
    encoded 1442 frames, 7.16 fps, 3942.92 kb/s
    encoded 1442 frames, 7.13 fps, 3942.92 kb/s
    encoded 1442 frames, 31.35 fps, 3889.96 kb/s
    encoded 1442 frames, 32.14 fps, 3889.96 kb/s
    encoded 1442 frames, 32.22 fps, 3889.96 kb/s
    encoded 1442 frames, 32.01 fps, 3889.96 kb/s
    encoded 1442 frames, 7.91 fps, 3953.35 kb/s
    encoded 1442 frames, 7.96 fps, 3953.35 kb/s
    encoded 1442 frames, 7.92 fps, 3953.35 kb/s
    System Details
    Name Intel Pentium E2180
    Codename Conroe
    Specification Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
    Core Stepping M0
    Technology 65 nm
    Stock frequency 2000 MHz
    Core Speed 2660.1 MHz (10.0 x 266.0 MHz)
    FID range 6.0x - 10.0x
    Southbridge Intel 82801IB (ICH9) rev. 02
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 15
    Command Rate 2T
    Memory Frequency 532.0 MHz (1:2)
    Memory Type DDR2
    Memory Size 3582 MBytes
    Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001)
    max VID 1.300 V
    Voltage sensor 0 1.26 Volts [0x4F] (CPU VCORE)
    Number of threads 2
    L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
    Temperature sensor 0 43°C (109°F) [0x2B] (TMPIN0)
    Temperature sensor 1 57°C (134°F) [0x39] (TMPIN1)
    Temperature sensor 0 74°C (165°F) [0x1A] (core #0)
    Temperature sensor 1 72°C (161°F) [0x1C] (core #1)
  9. graysky
  10. Mac Daddy
    Thats way too hot :shock:
  11. voron
    voron Newbie
    I am not sure it's reported correctly here.
    CoreTemp/Everest/RMClock/Real Temp show max temperature during this test ~58/56 for each core.
    VCore is 1.28V.
  12. graysky
    Just wondering if you minimized it. You'd be amazed just how many degrees you can knock off the load temp by just a few hundred mV's.
  13. Alexandr82
    Alexandr82 Newbie
    encoded 1442 frames, 53.37 fps, 3905.42 kb/s
    encoded 1442 frames, 52.55 fps, 3905.42 kb/s
    encoded 1442 frames, 52.97 fps, 3905.42 kb/s
    encoded 1442 frames, 52.64 fps, 3905.42 kb/s
    encoded 1442 frames, 13.20 fps, 3952.85 kb/s
    encoded 1442 frames, 13.23 fps, 3952.85 kb/s
    encoded 1442 frames, 13.25 fps, 3952.85 kb/s
    encoded 1442 frames, 53.87 fps, 3891.55 kb/s
    encoded 1442 frames, 54.28 fps, 3891.55 kb/s
    encoded 1442 frames, 54.06 fps, 3891.55 kb/s
    encoded 1442 frames, 54.15 fps, 3891.55 kb/s
    encoded 1442 frames, 14.19 fps, 3963.43 kb/s
    encoded 1442 frames, 14.05 fps, 3963.43 kb/s
    encoded 1442 frames, 14.14 fps, 3963.43 kb/s
    encoded 1442 frames, 14.21 fps, 3963.43 kb/s
    System Details
    Name AMD Phenom X4 9850
    Codename Agena
    Specification AMD Phenom(tm) 9850 Quad-Core Processor
    Core Stepping DR-B3
    Technology 65 nm
    Core Speed 2511.4 MHz (12.5 x 200.9 MHz)
    Northbridge ATI RD790 rev. 00
    Southbridge ATI SB600 rev. 00
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 334.8 MHz (3:5)
    Memory Type DDR2
    Memory Size 8190 MBytes
    Channels Dual (Unganged)
    Voltage sensor 0 1.28 Volts [0x50] (CPU VCORE)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
    Package Socket AM2+ (940)
    Package Type 0x1
    Temperature sensor 0 49°C (120°F) [0x31] (System)
    Temperature sensor 1 47°C (116°F) [0x2F] (CPU)
    Temperature sensor 0 48°C (117°F) [0x17C] (core #0)
    Temperature sensor 1 48°C (117°F) [0x17C] (core #1)
    Temperature sensor 2 47°C (116°F) [0x178] (core #2)
    Temperature sensor 3 47°C (116°F) [0x178] (core #3)
    Temperature sensor 0 70°C (157°F) [0x46] (GPU Core)
  14. Ancient_1
    Ancient_1 Newbie
    Results from my DFI LP LT P35 T2R and 8400 @ 4.2
    encoded 1442 frames, 46.21 fps, 3905.08 kb/s
    encoded 1442 frames, 48.07 fps, 3905.08 kb/s
    encoded 1442 frames, 47.57 fps, 3905.08 kb/s
    encoded 1442 frames, 48.09 fps, 3905.08 kb/s
    encoded 1442 frames, 12.44 fps, 3942.92 kb/s
    encoded 1442 frames, 12.45 fps, 3942.92 kb/s
    encoded 1442 frames, 12.32 fps, 3942.92 kb/s
    encoded 1442 frames, 12.42 fps, 3942.92 kb/s
    encoded 1442 frames, 53.72 fps, 3889.96 kb/s
    encoded 1442 frames, 54.22 fps, 3888.51 kb/s
    encoded 1442 frames, 54.42 fps, 3888.51 kb/s
    encoded 1442 frames, 54.29 fps, 3889.11 kb/s
    encoded 1442 frames, 14.00 fps, 3953.35 kb/s
    encoded 1442 frames, 14.01 fps, 3953.03 kb/s
    encoded 1442 frames, 13.76 fps, 3953.35 kb/s
    System Details
    Name Intel Core 2 Duo E8400
    Codename Wolfdale
    Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
    Core Stepping C0
    Technology 45 nm
    Stock frequency 3000 MHz
    Core Speed 4206.0 MHz (9.0 x 467.3 MHz)
    FID range 6.0x - 9.0x
    CAS# 4.0
    RAS# to CAS# 4
    RAS# Precharge 4
    Cycle Time (tRAS) 12
    Command Rate 2T
    Memory Frequency 467.3 MHz (1:1)
    Memory Type DDR2
    Memory Size 2048 MBytes
    max VID 1.213 V
    Voltage sensor 0 1.38 Volts [0x56] (CPU VCORE)
    Number of threads 2
    Temperature sensor 0 64°C (147°F) [0x40] (CPU)
    Temperature sensor 1 44°C (111°F) [0x2C] (PWM)
    Temperature sensor 2 45°C (112°F) [0x2D] (Chipset)
    Temperature sensor 0 67°C (152°F) [0x26] (core #0)
    Temperature sensor 1 64°C (147°F) [0x29] (core #1)
    Temperature sensor 0 43°C (109°F) [0x2B] (GPU Core)
  15. graysky
    @Alexandr82 - got it, thanks!
    @Ancient - got it (from xtreme), thanks!
  16. bug
    bug Newbie
    not working
    8.5.26
    Trouble getting it to work.
    downloaded both (2.68MB) 'Avisynth 257' (installed and rebooted, shows as AviSynth 2.5 in Start/Programs) in Wxp pro, and extracted the 32.2MB x264 Benchmark HD v2.0 (it only put a [3.41KB] VBScript Script File 'x264 benchmark-720p' in the folder had it extract to; where is the rest of that 32MB?)
    On dbl click that vbs x264 benchmark-720p icon, for like 1/10 a second that black window popup flashes but it does not stay up nor can enter any names.
    ?Does one have to disable Wxp firewall, or the MS Defender spyware programs?
    Am in Administrator mode.
    reinstalled Avisynth, did not fix it; re-extracted the rar, this time it placed the vbs, a test folder and two IE links to techarp. Now the benchmark worked...
    encoded 1442 frames, 21.37 fps, 3901.43 kb/s
    encoded 1442 frames, 21.31 fps, 3905.08 kb/s
    encoded 1442 frames, 21.33 fps, 3905.08 kb/s
    encoded 1442 frames, 21.38 fps, 3901.43 kb/s
    encoded 1442 frames, 4.87 fps, 3942.52 kb/s
    encoded 1442 frames, 4.87 fps, 3942.92 kb/s
    encoded 1442 frames, 4.88 fps, 3942.92 kb/s
    encoded 1442 frames, 22.43 fps, 3888.91 kb/s
    encoded 1442 frames, 22.38 fps, 3886.94 kb/s
    encoded 1442 frames, 22.38 fps, 3888.06 kb/s
    encoded 1442 frames, 22.42 fps, 3886.94 kb/s
    encoded 1442 frames, 5.14 fps, 3953.12 kb/s
    encoded 1442 frames, 5.14 fps, 3955.12 kb/s
    encoded 1442 frames, 5.15 fps, 3953.00 kb/s
    encoded 1442 frames, 5.15 fps, 3955.13 kb/s
    System Details
    Name AMD Athlon 64 X2 3800+
    Codename Windsor
    Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
    Core Stepping BH-F2
    Technology 90 nm
    Core Speed 2010.1 MHz (10.0 x 201.0 MHz)
    Northbridge ATI Xpress 3200 (RD580) rev. 00
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Command Rate 2T
    Memory Frequency 335.0 MHz (CPU/6)
    Memory Type DDR2
    Channels Single
    Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
    max VID 1.350 V
    Voltage sensor 0 1.28 Volts [0xA0] (CPU VCORE)
    Number of threads 2
    L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
    Package Socket AM2 (940)
    Temperature sensor 0 42°C (107°F) [0x2A] (SYSTIN)
    Temperature sensor 1 52°C (124°F) [0x67] (CPUTIN)
    Temperature sensor 2 52°C (124°F) [0x67] (AUXTIN)
    Temperature sensor 0 53°C (127°F) [0x66] (core #0)
    Temperature sensor 1 51°C (123°F) [0x64] (core #1)
    Temperature sensor 0 54°C (129°F) [0x36] (GPU Core)
  17. Adrian Wong
    You need to extra all the files. The rest of the files are within the pics and test folders.
    BTW, the main folder should contain at least four files, one HTM file, one URL file and two BAT files.
  18. graysky
    @bug - thanks for the data, man. I'll update the main page shortly. I dunno why it didn't extract the full rar file for you, but I'm glad you finally got it to work.
    BTW, no reboot is needed when installing avisynth.
    Also, as a cheap plug for everyone, remember that the "database" is freely available on the main page of the benchmark. You can, for example, filter it to see others running your CPU. In bug's case:
  19. Zenphic
    Zenphic Newbie
  20. Chai
