[highlight]*UPDATE*[/highlight] Latest price (3hrs ago), coz a lot of ppl been asking me: Videopro(photo) $149 Agenuine ----- $145 Prolinkdata --- $145 Alphadigitek -- $145 (i think so)
i juz realized that i can turn the heatsink 90degree anti-clockwise, Advantage: it wouldnt be blocking the ram-flow cooler... allowing better airflow (hot air will be sucked up by the OTES-fans) Disadvantage: i cant see the beautiful green light fr the front!!! its alreadi cool enough
i tried running that setting full load fanless (exept the psu & nF4 fan) temperature shoots up to 73C in 15seconds den shuts down at 75C (my selected shutdown temp)... but under C&Q (100x5=500Mhz), fanless no problem, it has 'problem' going past 30C @ full load..
Would be better if you are using a thermometer the take the temperature readings instead of using the onboard ones Hm... I never know the CNPS9500 has aluminum version
well, i cant afford all those equipments.. i dun mind ARP sponsoring me wif one.. hee hee~ its a 100% pure copper hsf, excatly same specs as S9500-LED, only diff is that AM2 is chromed
